Direction, distance, and elevation commands
Direction, distance, and elevation commands specify x-, y-, and z-coordinate values for the current feature segment you are actively sketching. They are available as individual commands that operate with the active construction tool.
Command
Direction Direction
Constrains the current segment to the specified direction value. Pitch in the z-direction can be specified when the feature is z-aware. To complete the segment, specify a distance.
This tool is Ground to Grid and COGO aware.
Distance Distance
Constrains the current segment to the specified distance. To complete the segment, specify a direction.
Direction/Distance Direction-Distance
Creates a vertex at the specified horizontal direction and distance measured from the last vertex. Pitch in the z-direction can be specified when the feature is z-aware.
Deflection Deflection
Constrains the current segment to the specified angle measured from the last segment. To complete the segment, specify a distance.
Segment Deflection Segment Deflection
Constrains the current segment to a specified angle measured from an existing right-clicked feature segment.
Absolute X,Y,Z Move To
Creates a vertex or a point feature at the specified x- and y-coordinate location. A z-value can be specified when the feature is z-aware.
Delta X,Y,Z Move
Creates a vertex at the specified x- and y-coordinate location measured from the last vertex. A z-value can be specified when the feature is z-aware.
Constant .
Specifies a constant z-value when sketching z-aware features. In a 3D scene, click the active view to autofill this value.
Surface Surface
Specifies a z-value from a clicked elevation surface in the map. This is available only with maps containing one or more elevation surfaces.
Back to top
