Polyline and polygon construction tools
On the Mapview toolbar, feature construction tools for polyline and polygon layers create features using the pointer. Segment construction tools for the active tool are available on the construction toolbar in the map view and above the context menu when you right-click the map.
Polygon feature tools
Polygon feature construction tools are described in the following table:
Tool
Polygon Polygon
Create irregular polygon features. Feature geometry can comprise straight and curvilinear segments using the segment tools that appear on the construction toolbar.
Circle Circle
Create planar circular features using the pointer or numeric values to specify a center and a radius.
Rectangle Rectangle
Create planar rectangular or square features using the pointer or numeric values.
Ellipse Ellipse
Create planar ellipse features using the pointer or numeric values.
Freehand New Freehand Line
Create a free-form polygon with the pointer. When you finish the sketch, all segments are converted to Bézier curves.
Polyline feature tools
Polyline feature construction tools are described in the following table:
Tool
Line Line
Create polyline features comprising multiple straight and curvilinear segments.
Right Angle Right Angle Segment
Create straight segments constrained to 90 degrees from each previous segment.
Split Split
Create a polyline feature across an existing line feature on the same layer and split both lines where they intersect.
Two-point Line 2-Point Line
Create two-point line features. The feature is automatically finished when you create the second vertex.
Create a free-form polyline feature that follows the pointer. Clicking the map a second time finishes the feature and automatically converts the segments to a series of Bézier curves.
Back to top
