ArcGIS Data Interoperability for Server
The extension allows you to share Spatial ETL (extract, transform, load) tools as web tools in ArcGIS Enterprise or publish geoprocessing services on a stand-alone ArcGIS Server.
The ArcGIS Data Interoperability for Server extension allows you to share Spatial ETL (extract, transform, load) tools as web tools in ArcGIS Enterprise or publish geoprocessing services on a stand-alone ArcGIS Server.
The extension must be installed on the server running ArcGIS Server that will host web tools. See the ArcGIS Data Interoperability for Server extension installation guide for more information.
Web tools hosted on ArcGIS Enterprise can be used in client applications, including Map Viewer and ArcGIS Pro; used in custom apps; or run as part of a Python script tool.
You can create Spatial ETL tools in ArcGIS Pro using a no-code integration approach with the ArcGIS Data Interoperability extension. For more information on Spatial ETL tools, refer to the ArcGIS Pro documentation.
What’s included with the ArcGIS Data Interoperability for Server
The ArcGIS Data Interoperability for Server extension includes the following.
Feature Manipulation Engine
The extension uses Feature Manipulation Engine (FME) technology from Safe Software. To share Spatial ETL tools authored using ArcGIS Pro, as web tools to ArcGIS Enterprise, both extensions must use the same version of FME. See the ArcGIS Data Interoperability for Server extension system requirements for a list of the versions of FME included with each version of ArcGIS Pro and ArcGIS Server.
The extension supports the same formats as ArcGIS Pro as long as they both use the same version of FME. For a complete list of supported formats, see Supported formats with the Data Interoperability extension.
ArcGIS Data Interoperability desktop applications
The extension installation includes the following desktop applications:
  • Workbench
  • Data Inspector
  • Quick Translator
Unlike the ArcGIS Pro extension, no shortcuts or user interfaces are provided for these installed apps. They can only be accessed from the installation directory of the extension by launching their respective executables. These applications are used for authoring workspaces, troubleshooting and testing packages, web and database connections and Spatial ETL tools hosted on the server.
Web tools and geoprocessing services
Web tools and geoprocessing services are the foundation of ArcGIS Data Interoperability for Server. They enable Spatial ETL tools authored in ArcGIS Pro to be deployed as server-based services using the ArcGIS geoprocessing framework. Once published, these services can be used across ArcGIS Enterprise, ArcGIS Server, custom applications, and scripting environments, providing a centralized and scalable approach to data integration, transformation, and automation.
When shared as web tools or geoprocessing services, ArcGIS Pro users can run data workflows without requiring a license for the ArcGIS Data Interoperability for ArcGIS Pro extension.
Lifecycle of a server-based Spatial ETL workflow
ArcGIS Data Interoperability for Server provides an end-to-end workflow for authoring, deploying, using, and automating Spatial ETL tools through web tools and geoprocessing services built on the ArcGIS geoprocessing framework.
Stage Description
Author Design, build, and validate Spatial ETL workflows in ArcGIS Pro.
Deploy Make Spatial ETL workflows available as web tools and geoprocessing services.
Use Access and run services from desktop, web, and programmatic clients.
Automate Execute workflows on a schedule to support operational business processes.
Additional Capabilities
  • Configurable user input
Workbench user parameters can be exposed as geoprocessing parameters in published web tools and geoprocessing services. For supported parameter types and considerations, see Understand Spatial ETL tool parameters.
  • Scalable processing
Web tools support asynchronous execution and instance pooling, allowing workloads to be distributed across multiple service instances to improve performance and scalability for large data integration jobs. Instance settings can be configured during publishing or updated later in ArcGIS Server Manager. For steps to configure, see Configure the shared instance pool.
  • Cloud deployment support
Published web tools and geoprocessing services support ArcGIS Enterprise deployments on Microsoft Azure and Amazon Web Services (AWS). Geoprocessing job directories and outputs can be stored in cloud storage, enabling scalable cloud-based data integration workflows. For more information, see Add cloud storage on Microsoft Azure.
  • Workflow integration
With ArcGIS Rest API, published web tools and geoprocessing services can be integrated into scheduled processes, scripts, custom applications, and enterprise workflows.
Learn more about web tools and geoprocessing services.
