Frequently asked questions
What is ArcGIS Data Reviewer?
ArcGIS Data Reviewer is an extension to ArcGIS Pro and ArcGIS Enterprise that automates, simplifies, standardizes, and improves quality control workflows to enable delivery of geospatial data you can trust. Lower data management costs reduce risk in decision-making through this unified set of capabilities that support detection, management, and reporting of errors in your data.
How is Data Reviewer licensed?
Data Reviewer is an integrated extension to ArcGIS Pro and ArcGIS Enterprise that supports quality control workflows across multiple industries and data types. In ArcGIS Pro, Data Reviewer is available for all license levels as an add-on to a Named User or Single Use type.
Learn more about ArcGIS Pro license types
In ArcGIS Enterprise, Data Reviewer is available for Standard and Advanced editions of ArcGIS GIS Server. This extension is a CPU-based license that is required for each GIS Server that is federated with the organization.
Learn more about ArcGIS GIS Server capabilities and extensions
Can Data Reviewer detect errors in web layers shared from Enterprise?
To use Data Reviewer in a server environment, you must use branch-versioned data. You can evaluate the data using the Validation Service. Starting at Enterprise 11.3, you can use visual review capabilities on feature services to browse and flag missing features.
To use Data Reviewer in a server environment, you must use branch-versioned data. You can evaluate the data using the Validation Service. Starting at Enterprise 12.1, you can use visual review capabilities on feature services to browse and flag missing features.
What Data Reviewer capabilities are deprecated?
Services published from ArcMap are not supported after Enterprise 10.9. For Data Reviewer users, this change impacts capabilities delivered by the extension's ArcMap runtime-based server object extension (SOE) and associated geoprocessing service. Starting at Data Reviewer 3.0, these capabilities will not be supported after an upgrade to an existing deployment or in new deployments.
Learn more about the deprecation of the ArcMap runtime-based SOE
It is recommended that you begin migrating your quality control workflows to the Data Reviewer attribute rule-based workflows in ArcGIS Pro. The workflows in ArcGIS Pro are equivalent to those of the ArcMap runtime-based SOE.
What is the difference between Topology Rules and Data Reviewer?
Geodatabase topology and Data Reviewer are both capabilities that support the creation and management of high-quality data. There are advantages to using both capabilities in data management workflows. A key difference between these capabilities is the aspects of a feature's quality that can be assessed. Data Reviewer checks are used to assess multiple aspects of a feature's quality. This includes the ability to identify data quality issues related to a feature's integrity, attribution, as well as a feature's spatial relationship to other features. For a complete list of Data Reviewer checks, review the ArcGIS Data Reviewer Checks poster.
A geodatabase topology is used to enforce a spatial relationship between features in a geodatabase. This includes assessment of spatial relationships such as overlaps, intersections, and gaps. For a complete list of topology rules, review the ArcGIS Geodatabase Topology Rules poster.
Learn more about the components that define GIS data quality
Is there a limit to the number of features that can be validated using automated checks?
No, there is no limit to the number of features that can be validated using automated checks.
The more features and quality checks there are, the longer it may take to validate. In extreme cases, the resulting errors from the validation process could exceed the number of features in the database.
What is the difference between Attribute Rules and Data Reviewer?
Data Reviewer provides a library of no-code, ready-to-use checks based on attribute rule workflows. These checks can identify common errors in GIS data by filling out two to three parameters with just a few clicks. Additionally, Data Reviewer facilitates error life cycle management by highlighting the specific feature that is causing the error and tracking both the error and the review process. By comparison, ArcGIS Arcade-based attribute rules can provide more precise control in identifying errors but require familiarity with coding Arcade scripts.
Learn more about Data Reviewer checks
Can I run Data Reviewer validation rules using ArcGIS Server?
Yes. When you share web feature layers that contain validation attribute rules, you can enable the Validation capability to use the Validation Service. You can use the Validation Service to assess the quality of features using validation attribute rules authored in ArcGIS Pro.
What types of features are supported by Data Reviewer checks?
Data Reviewer checks support the following data types:
  • Point Features
  • Line Features
  • Polygon Features
  • Standalone Tables
Data Reviewer-based constraint and validation rules support these feature types in file, mobile, and feature services published from branch versioned enterprise geodatabases. Constraint attribute rules support these feature types in traditional versioned enterprise geodatabases.
Why are some error features removed while others remain in the Error Inspector after I fix the errors in my data?
Data Reviewer attribute rule error features remain in the Error Inspector pane after they are fixed for traceability and error life cycle management. Traceability allows you to track and manage errors throughout the data validation process, ensuring that errors have been properly addressed. The error management process records which errors were identified and fixed, allowing you to track the history of data quality improvements.
The only error features that are removed are Arcade-based attribute validation rules. These errors only persist if the error condition they search for is still present. Once an error is fixed and the validation rules are re-evaluated, the Arcade-based validation errors are removed.
Learn more about the Data Reviewer error life cycle management
Can I remove the Validation status field from my data?
No. Once a batch calculation or validation attribute rule has been authored on a dataset, the Validation status field is automatically generated and can no longer be deleted, even if you delete all other rules.
Learn more about the Validation Status field
