System requirements
Before installing ArcGIS Documentation Center, make sure that your machine meets the minimum hardware and software requirements to run the application.
Supported operating systems
The application is supported on the Microsoft Windows operating systems, as long as the operating system is also currently supported by its provider for general or public use.
Windows 11 Home, Pro, and Enterprise (64 bit)
Windows Server 2025 Standard and Datacenter (64 bit)
Windows Server 2022 Standard and Datacenter (64 bit)
The operating system version and updates must also be supported by the operating system provider.
Software requirements
ArcGIS Documentation Center requires the following Microsoft .NET components, version 10.0.2 or later but earlier than 11.0.0:
.NET Desktop Runtime
ASP.NET Core Runtime
The versions should be the same for both components.
