When to use Doc Center in offline scenarios
ArcGIS Documentation Center supports workflows where internet access is limited, unreliable, or unavailable. This section explains how to plan for and work with documentation in offline and restricted environments.
Offline use relies on downloading documentation sets ahead of time and storing them locally so they can be opened without an internet connection. Once documentation is available locally, you can browse it, search it, and open help topics from supported ArcGIS products even when you are disconnected.
The topics in this section focus on when why offline workflows are needed, as well as common scenarios such as field work, secure networks, and restricted environments. They provide context and guidance rather than step‑by‑step instructions.
If you are looking for instructions on downloading documentation, opening documentation sets, or sharing documentation between machines, see Use the app.
Common offline scenarios
You may need to work offline when:
  • You are in the field without reliable internet access
  • Your organization operates in a secure or restricted network
  • Internet access is intermittent or intentionally limited
  • Documentation must be reviewed or transported between environments
In these scenarios, documentation is typically downloaded or prepared in advance and then accessed locally when needed.
What offline use does and does not require
Offline use does require:
  • Installing ArcGIS Documentation Center
  • Downloading documentation sets before disconnecting
Offline use does not require:
  • A continuous internet connection
  • Separate help applications for each product
Once documentation sets are stored locally, the experience is similar to viewing web help, but all content is served from your local machine.
Next steps
To learn how to prepare documentation for offline use in specific situations, see the topics in this section.
To learn how to download, import, or share documentation sets, see Use the app.
Back to top
