Manage image data
Once you create a project and you're on its home screen, you can start processing imagery. To update image information before processing, use the Flight Data tab.
You can perform the following tasks in the Manage group:
  • View the Images table.
  • Configure radiometric calibration.
  • Add and remove images.
  • Enable and disable images.
  • Edit the camera model.
Images table
The Images table provides information about each image in a collection. Use this table to obtain information and sort the images.
The following table describes the fields in the Images table:
Field name
The name of the image.
DateTaken
The date and time the image was taken.
File
The path to the image on disk.
Latitude
The latitudinal coordinates of the image.
Longitude
The longitudinal coordinates of the image.
Altitude
The altitude of the image.
Yaw
The left or right rotation of the drone platform around its vertical axis.
Pitch
The up or down tilt of the drone platform around its side-to-side axis.
Roll
The rotation of the drone platform around its front-to-back axis.
XY Accuracy
The combined horizontal image accuracy of the x,y-axes. (This is defined by image metadata if available; otherwise, it's hidden.)
Z Accuracy
The vertical image accuracy of the z-axis. (The is defined by image metadata if available; otherwise, it's hidden.)
AccX
The horizontal image accuracy of the x-axis. (This is defined by RTK image metadata if available; otherwise, it's hidden)
AccY
The horizontal image accuracy of the y-axis. (This is defined by RTK image metadata if available; otherwise, it's hidden)
AccZ
The vertical image accuracy of the z-axis. (This is defined by RTK image metadata if available; otherwise, it's hidden.)
Adjusted
Displays True when the altitude has been adjusted and False when it hasn't been adjusted.
Status
Displays Enabled when the image is enabled for processing and Disabled when it is disabled for processing.
If you are using certain supported multispectral cameras in your projects, you can configure radiometric calibration before processing products. For steps and more details, see Radiometric calibration.
You can add images to and remove images from a project to determine how multiple flights and collections affect your products.
Add images
To add images, complete the following steps:
  1. On the Flight Data tab, in the Manage group, click Add Images.
  2. Follow the steps in Create a project to add images to a project.
Remove images
To remove images, complete the following steps:
  1. Select one or more images from the map or the Images table.
  2. On the Flight Data tab, in the Manage group, click Remove Images.
  3. Click Yes to confirm, or click No to cancel.
Images that you add to a project are enabled by default, meaning they are included during processing. You can disable select images before processing but keep them in the project. Disabled images remain in the project but are not included during processing.
Enable images
To enable images, complete the following steps:
  2. On the Flight Data tab, in the Manage group, click Enable Images.
  3. Click Yes to confirm.
Disable images
To disable images, complete the following steps:
  2. On the Flight Data tab, in the Manage group, click Disable Images.
To edit the parameters in the camera model, click the Edit Camera button to open the Edit Camera Parameters pane. For steps and more details, see Edit the camera model.
