Upgrade a single-machine ArcGIS Enterprise deployment on AWS
This information applies to upgrading an ArcGIS Enterprise base deployment that has all base components configured on a single Amazon Elastic Compute Cloud (EC2) instance.
How you upgrade depends on how and when you created the ArcGIS Enterprise deployment on Amazon Web Services (AWS).
To determine what method to use to upgrade, see ArcGIS upgrades on Amazon Web Services ArcGIS upgrades on Amazon Web Services.
Before you upgrade
Regardless of the upgrade method you use, review the following information before you upgrade the deployment:
  • Read ArcGIS upgrades on Amazon Web Services to determine what method to use to upgrade and discover whether you must perform extra tasks before upgrading to 12.1. Complete all required tasks before upgrading.
  • Obtain the required ArcGIS licenses for the current software version. Download the license files from your account in My Esri.
  • Create a backup of the deployment so you can restore if there are any problems with the upgrade procedure.
    You can use the webgisdr utility provided with Portal for ArcGIS to create a backup of most components in an ArcGIS Enterprise deployment.
    Depending on what version you are upgrading from, some data store types may not be included in this backup. If you are upgrading a deployment that includes data store types not included when you run the webgisdr utility, use the ArcGIS Data Store backupdatastore utility to create backups of those data store types before you upgrade.
Upgrade using manual upgrade procedures
The manual upgrade procedure for updating software on your single-machine ArcGIS Enterprise deployment on Amazon Web Services is similar to updating software on-premises; download software updates from My Esri onto your Amazon Elastic Compute Cloud (EC2) instance, and apply the updates directly to your existing deployment. All ArcGIS Enterprise components must be running the same software version. The main difference in updating on AWS is how you create a backup of the existing deployment.
If the starting version or components in your deployment require you to upgrade to an interim version, follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
  1. Sign in to AWS Management Console and create an Amazon Machine Image (AMI) from your existing instance.
    This is your backup that you can use to redeploy if any issues arise during upgrading. If you have to redeploy, you must deploy using the same portal URL.
  2. Obtain new Portal for ArcGIS and ArcGIS GIS Server licenses from Esri.
  3. Download new versions of Portal for ArcGIS, ArcGIS Web Adaptor, ArcGIS Server, and ArcGIS Data Store from My Esri.
  4. Make a remote desktop connection (Microsoft Windows) or SSH (Linux) connection to the machine on AWS. Connect as the arcgis user. Place all the software downloads on this machine.
    If this is the first time you are upgrading a deployment on a Windows AWS instance, change the arcgis user's password.
    If you deployed ArcGIS Enterprise on this machine using the AWS Management Console, be sure this machine is allowed to create Amazon Simple Storage Service (S3) buckets in your AWS account, as the Portal for ArcGIS upgrade procedure creates an S3 bucket for temporary storage of the content directory. If you deployed using a CloudFormation template provided by Esri, the template already configured this.
  5. Follow the steps in Upgrade Portal for ArcGIS to update your portal and its web adaptor, and update your Portal for ArcGIS license.
  6. Follow the single-machine site steps in Upgrade ArcGIS Server to update ArcGIS Server and its web adaptor, and update your ArcGIS Server site with an ArcGIS GIS Server license.
    You must upgrade ArcGIS Server before upgrading ArcGIS Data Store.
  7. Follow the steps in Upgrade ArcGIS Data Store to update the data store.
  8. When you finish upgrading and testing your updated deployment, you can delete the backup AMI.
Upgrade using Cloud Builder
If you used ArcGIS Enterprise Cloud Builder for Amazon Web Services to create the deployment and the deployment meets version and functionality requirements described in ArcGIS upgrades on Amazon Web Services, you can use Cloud Builder to upgrade. See Upgrade using the ArcGIS Enterprise Cloud Builder for AWS app for instructions.
Upgrade using Chef scripts
If you created the deployment using a 10.8 or 10.8.1 Esri Amazon Web Services CloudFormation template, you can upgrade using Chef scripts.
As indicated in ArcGIS upgrades on Amazon Web Services, if the deployment is still at version 10.8, 10.8.1, 10.9, or 10.9.1 or if the deployment includes components that are no longer supported, you must first upgrade to an interim version before upgrading to 12.1. Follow the instructions provided in the interim help version before following instructions to upgrade to 12.1.
Upgrade steps are different for deployments on Microsoft Windows and Ubuntu. Follow the instructions applicable to the operating system of your deployment.
Upgrade a single-machine ArcGIS Enterprise deployment on Windows
Follow these steps to use Chef to upgrade ArcGIS Enterprise on a single Amazon Elastic Compute Cloud (EC2) instance.
  1. Make a remote desktop connection to the EC2 instance.
  2. Download and install a supported Cinc or Chef client.
    See the ArcGIS Cookbook compatibility matrix for supported versions.
  3. Download the 12.1 installation files from your account in My Esri and upload the files to a folder on the EC2 instance:
    • ArcGIS_Web_Adaptor_for_Microsoft_IIS_121_200166.exe
    • Portal_for_ArcGIS_Windows_121_200161.exe
    • Portal_for_ArcGIS_Windows_121_200161.exe.001
    • Portal_for_ArcGIS_Web_Styles_Windows_121_200163.exe
    • ArcGIS_Server_Windows_121_200157.exe
    • ArcGIS_Server_Windows_121_200157.exe.001
    • ArcGIS_DataStore_Windows_121_200164.exe
    • ArcGIS_DataStore_Windows_121_200164.exe001
  4. Obtain the Portal for ArcGIS 12.1 authorization file (.json) and ArcGIS Server authorization licensed for ArcGIS GIS Server (.epc or .prvc) and place them on the EC2 instance.
  5. Download the ArcGIS Cookbook version 5.4.0 (arcgis-5.4.0-cookbooks.zip) to the EC2 instance, unzip the file, and place the contents of the unzipped file in the C:\chef folder.
  6. Delete the following folders:
    • C:\chef\nodes
    • C:\Users\Administrator\.chef\local-mode-cache
  7. Create a copy of the C:\chef\node.json file and rename it to upgrade_base_enterprise_allinone_windows.json.
  8. Open the upgrade_base_enterprise_allinone_windows.json file in a text editor and modify the following parameters:
    • Set the ArcGIS version to 12.1.
      "arcgis" : {
          "version": "12.1",
    • Set the ArcGIS archive repository to the folder where you placed the software files on the EC2 instance.
      "arcgis" : {
          "repository": {
         "archives": "<drive>\\<folder>"
    • Set the server authorization to the location of your ArcGIS Server 12.1 authorization file.
      "server" : {
          "authorization_file" : "<drive>:\\<folder_path>\\My_New_Server.prvc"
    • Set the portal authorization to the location of your Portal for ArcGIS 12.1 authorization file.
      "portal" : {
          "authorization_file" : "<drive>:\\<folder_path>\\my_new_portal.json",
    • Modify the run list to use the following recipes:
      "recipe[arcgis-enterprise::install_portal]",
      "recipe[arcgis-enterprise::webstyles]",
      "recipe[arcgis-enterprise::portal]",
      "recipe[arcgis-enterprise::portal_wa]",
      "recipe[arcgis-enterprise::server]",
      "recipe[arcgis-enterprise::server_wa]",
      "recipe[arcgis-enterprise::datastore]"
  9. Save and close the upgrade_base_enterprise_allinone_windows.json file.
  10. Open a command line window as an administrator, change the directory to C:\chef, and run the following command: chef-client -z -j c:\chef\upgrade_base_enterprise_allinone_windows.json
The script runs to upgrade your deployment. This can take up to several hours, depending on the size of your deployment.
If the deployment upgrade fails, contact Esri support (in the United States) or your distributor (outside the United States) to help you troubleshoot.
Upgrade a single-machine ArcGIS Enterprise deployment on Ubuntu
Follow these steps to use Chef to upgrade ArcGIS Enterprise on a single EC2 instance.
  1. Make an SSH connection to the EC2 instance as the ubuntu user.
  2. Use one of the following commands to download and install a supported Chef or Cinc client.
    See the ArcGIS Cookbook compatibility matrix for supported versions. Replace the version number text in the following statements with the client version you install.
    • Chef client: sudo curl -L https://omnitruck.chef.io/install.sh | sudo bash -s -- -v <version_number>
    • Cinc client: sudo curl -L https://omnitruck.cinc.sh/install.sh | sudo bash -s -- -v <version_number>
    • ArcGIS_Web_Adaptor_Java_Linux_121_200209.tar.gz
    • Portal_for_ArcGIS_Linux_121_200206.tar.gz
    • ArcGIS_Server_Linux_121_200205.tar.gz
    • ArcGIS_DataStore_Linux_121_200208.tar.gz
    • Portal_for_ArcGIS_Web_Styles_Linux_121_200207.tar.gz
  5. Download the ArcGIS Cookbook version 5.4.0 (arcgis-5.4.0-cookbooks.tar.gz) to the EC2 instance, untar and unzip the file, and place the files contents in the /var/chef directory.
  6. Delete the /var/chef/nodes directory.
  7. Create a copy of the /etc/chef/node.json file and rename it to upgrade_base_enterprise_allinone_ubuntu.json.
  8. Open the upgrade_base_enterprise_allinone_ubuntu.json file in a text editor and modify the following parameters:
      "arcgis" : {
          "version": "12.1",
      "arcgis" : {
          "repository": {
        "archives": "/<path and folder>"
      "server" : {
          "authorization_file" : "/<path>/my_new_server.prvc"
      "portal" : {
          "authorization_file" : "/<path>/my_new_portal.json",
  9. Save and close the upgrade_base_enterprise_allinone_ubuntu.json file.
  10. As the ubuntu user, change the directory to /var/chef, and run the following command: sudo chef-client -z -j /etc/chef/upgrade_base_enterprise_allinone_ubuntu.json
Upgrade using a CloudFormation template
If you used the 10.9 or later arcgis-enterprise-allinone.template.json CloudFormation template to create a highly available ArcGIS Enterprise deployment, you can use the 12.1 arcgis-enterprise-allinone-upgrade.template.json file to upgrade to 12.1. See Upgrade ArcGIS Enterprise on one machine using CloudFormation for instructions.
