Use a template to create an AMI with ArcGIS on a Linux operating system
The arcgis-ami-linux.template.json Amazon Web Services (AWS) CloudFormation template creates an Amazon Machine Image (AMI) with a Linux operating system and ArcGIS Enterprise components that you choose.
See Operating systems supported when using CloudFormation to deploy ArcGIS on AWS for a list of supported Linux operating systems.
Prerequisites
Prerequisites can be grouped by the items—such as files and accounts—that you must obtain and the tasks you must perform before running the CloudFormation template.
Required items
You need the following to run this template:
An Amazon Web Services account.
The account must have access to basic AWS services such as CloudFormation, Amazon Elastic Compute Cloud (EC2), Amazon Virtual Private Cloud (VPC), Systems Manager, Amazon CloudWatch, AWS Identity and Access Management (IAM), and Secrets Manager.
An Amazon Virtual Private Cloud (VPC) and subnets.
You can use one of the following CloudFormation templates to create a VPC: VPC with two public subnets or VPC with two public and private subnets with a NAT Gateway.
The Linux operating system AMI ID. You can get the AMI ID from Amazon Web Services Management Console. If you are using an AMI from AWS Marketplace, you must subscribe to use CloudFormation before you use it in this CloudFormation template.
The
arcgis-ami-linux.template.jsonCloudFormation template.
Required tasks
Ensure the AWS Systems Manager agent is installed in the base AMI you plan to use to create an ArcGIS Enterprise AMI using this CloudFormation template. The AWS Systems Manager agent is installed on AWS base Ubuntu AMIs by default. But if you plan to use an AMI other than an AWS base Ubuntu AMI, you must configure the AWS Systems Manager agent in the base Linux operating system AMI. Follow the steps below to install AWS Systems Manager in a base Linuxoperating system AMI:
Create an Amazon Elastic Compute Cloud (EC2) instance from a base AMI using AWS Management Console.
Install the AWS Systems Manager agent on the EC2 instance you created in the previous step.
See the instructions in the AWS documentation.
Create an AMI from the EC2 instance using AWS Management Console.
Use the AMI you created in the previous step in this CloudFormation template to create an ArcGIS Enterprise AMI.
Parameters
Refer to the following tables for descriptions of the parameters used in this CloudFormation template. Tables are grouped by parameter type.
Amazon EC2 Configuration
Parameter name |
Required or not |
Parameter description |
Source Amazon Machine Image (AMI) ID |
Required |
Provide the source Amazon Machine Image (AMI) ID. See Operating systems supported when using CloudFormation to deploy ArcGIS on AWS for a list of supported Linux operating systems. If you use a base AMI from AWS Marketplace, you must subscribe to use that AMI before using it in this template. Ensure that the AWS Systems Manager is configured in the source AMI. |
Target AMI Name |
Required |
Provide a name for the AMI. It must start with a letter. The name must be alphanumeric and can contain underscore (_), dot (.), or dash (-) characters or spaces. The minimum length is 6 and maximum length is 127 characters. The AMI name must also be unique. |
Target AMI Description |
Required |
Provide a description for the AMI. It must start with a letter. The description must be alphanumeric and can contain underscore (_), curly brackets ({}), and colon (:) characters. The minimum length is 6 and maximum length is 255 characters. The default AMI description is EsriLinuxAmi_from_{{SourceAmiId}}_on_{{global:DATE_TIME}}. If you use the default description, {{SoureAmiId}} will be replaced with the Source Amazon Machine Image ID parameter value, and {{global:DATE_TIME}} will be replaced with the date and time that the AMI is created. |
EC2 Instance Type |
Required |
Provide an EC2 instance type. The default is m5.2xlarge. The instance type must have a minimum of 4 vCPU and 8 GB RAM. |
Device Name for EBS Volume |
Required |
Choose the device name for the EBS volume included in the image. You must choose the same device name that is used by the AMI that you specified with the Source Amazon Machine Image ID parameter. The available values are as follows:
EBS Volume Size |
Required |
Specify the size (in GB) of an EBS volume that will be included in the image. The default size is 500 GB. The minimum is 200 GB, and the maximum is 2048 GB. Ensure this size is equal to or greater than the snapshot volume size attached to the source AMI you specified for the Source Amazon Machine Image (AMI) ID parameter. |
EC2 Instance Keypair Name |
Required |
Choose an EC2 keypair name to allow remote access to EC2 instances. |
VPC ID |
Required |
Choose a VPC ID. If you need to create a VPC, you can use one of the VPC sample templates: VPC with public subnets or VPC with public and private subnets and a NAT Gateway. |
Subnet ID |
Required |
Choose a subnet ID. The subnet ID that you select must be within the VPC you have selected above. If you used an Esri CloudFormation template to create the VPC, you can get the subnet ID from that template's output parameters. |
ArcGIS Software Configuration
Parameter name |
Required or not |
ArcGIS Enterprise Component |
Required |
Choose the ArcGIS Enterprise component to be installed on the AMI. Available values are as follows:
Note:When you choose ArcGIS Enterprise Base, Portal for ArcGIS including ArcGIS Web Adaptor with a context name portal, ArcGIS Server including ArcGIS Web Adaptor with a context name server, and ArcGIS Data Store are installed on the AMI. |
ArcGIS GeoEvent Server |
Optional |
Choose whether to install ArcGIS GeoEvent Server. Available values are true or false. Note:This parameter is applicable only if you set the ArcGIS Enterprise Component parameter to ArcGIS Enterprise Base or ArcGIS Server. |
ArcGIS Web Adaptor |
Optional |
Choose whether to install ArcGIS Web Adaptor. Available values are true or false. Note:This parameter is ignored if you set the ArcGIS Enterprise Component parameter to any of the following:
ArcGIS Web Adaptor Name |
Conditional |
Provide an ArcGIS Web Adaptor context name. This appears in the portal, ArcGIS Server, or ArcGIS Mission Server URL. The name must begin with a letter and contain only alphanumeric characters. This parameter is required if you set the ArcGIS Web Adaptor parameter to true and ignored if you set the ArcGIS Web Adaptor parameter to false. |
ArcGIS User Account Name |
Optional |
Provide a name for a local login that the template creates to run the ArcGIS software. If you do not provide a name, arcgis is used for the login name. The login name must be between 3 and 32 characters. Uppercase and lowercase letters, numbers, dots (.), underscores (_), and dashes (-) are supported. Caution:If you will use this AMI in ArcGIS Enterprise Cloud Builder for Amazon Web Services, the login name must be arcgis. |
Outputs
When your stack is created successfully, you can see the following output parameters on the Outputs tab of the CloudFormation stack in AWS Management Console.
Output name |
Output description |
TargetAMIName |
The name of the AMI created using this CloudFormation template. You can retrieve the AMI ID in AWS Management Console by using the AMI name. |
DeploymentLogsURL |
This is the URL for the Amazon CloudWatch logs where all deployment logs are stored. You can refer to these logs for troubleshooting purposes if your deployment fails. |
Considerations
Consider the following when creating a CloudFormation stack for a custom AMI:
This template creates a CloudFormation stack and a custom AMI.
After creating a CloudFormation stack, retrieve the AMI ID from AWS Management Console using the TargetAMIName CloudFormation output parameter value.
This CloudFormation template creates EBS volumes with the type set to GP3. The
IOPSandThroughputvalues for the volumes use AWS defaults. You can use the AWS Management Console or AWS CLI to modify theIOPSandThroughputvalues after the deployment is created to meet your specific requirements.You can delete the CloudFormation stack after the AMI is created. This will not delete the AMI created with the CloudFormation stack. To delete the stack (or the AMI), use AWS Management Console.
Troubleshooting
If you observe any failures when creating this CloudFormation stack, see Troubleshoot ArcGIS deployments on AWS.
