Create a classic load balancer for an ArcGIS Enterprise deployment using CloudFormation
Rather than create an Elastic Load Balancer in AWS Management Console, you can use the arcgis-classic-loadbalancer.template.json Esri Amazon Web Services (AWS) CloudFormation template to create a classic load balancer, as shown in the following diagram:
Classic elastic load balancer
License:
Certain icons in the diagram are used with permission from Amazon Web Services.
The template links the imported SSL certificate to the load balancer. You can use a single classic load balancer per site. This means you must have a different load balancer for the base ArcGIS Enterprise deployment and for each ArcGIS Server site.
Prerequisites
Prerequisites can be grouped by the items—such as files and accounts—that you must obtain and the tasks you must perform before running the CloudFormation template.
Required items
You need the following before running this template:
  • An Amazon Web Services account.
    The account must have access to basic AWS services such as CloudFormation, Amazon Elastic Compute Cloud (EC2), Amazon Virtual Private Cloud (VPC), Amazon Simple Storage Service (S3), Systems Manager, Amazon CloudWatch, Lambda, AWS Identity and Access Management (IAM), Amazon DynamoDB, Secrets Manager, AWS Certificate Manager, and Amazon Relational Database Service (RDS).
  • An SSL certificate file (a .pfx file) and corresponding password.
    The certificate must be from a certifying authority.
  • An Amazon Virtual Private Cloud (VPC) and subnets.
    You can use one of the following CloudFormation templates to create a VPC: VPC with two public subnets or VPC with two public and private subnets with a NAT Gateway.
  • The arcgis-classic-loadbalancer.template.json CloudFormation template.
    Tip:
    There is a separate template to create an application load balancer.
Required tasks
Complete the following task before running this template:
  • Upload your SSL certificate in the AWS Certificate Manager service and copy the SSL Certificate Amazon Resource Name (ARN).
    See the AWS documentation for instructions on how to upload an SSL certificate into AWS Certificate Manager.
Parameters
Refer to the following tables for descriptions of the parameters used in this CloudFormation template. Tables are grouped by parameter type.
Amazon VPC Configuration
Parameter name
Required?
Parameter description
VPC ID
Required
Choose a VPC ID.
All ArcGIS Enterprise components that are part of the same deployment must be deployed in the same VPC.
If you need to create a VPC, you can use one of the VPC sample templates: VPC with public subnets or VPC with public and private subnets and a NAT Gateway.
Subnet ID 1
Required
Choose a subnet ID. The subnet ID that you select must be within the VPC you have selected above.
If you used an Esri CloudFormation template to create the VPC, you can get the subnet ID from that template's output parameters.
Subnet ID 2
Required
Choose a second subnet ID. This must be a different subnet ID than you used for the Subnet ID 1 parameter. The subnet ID that you select must be within the VPC you specified for this deployment.
Amazon Elastic Load Balancer Configuration
Parameter name
Required?
SSL Certificate ARN
Required
Provide the ARN of the SSL certificate imported in AWS Certificate Manager.
It must be in the following format: aws:acm:<region>:<account-id>:certificate/<resourceid>.
Load Balancer Scheme
Optional
Choose a load balancer scheme. The default scheme is internet-facing.
Load Balancer Name
Optional
If you specify a name for the load balancer, it must begin with a letter and contain only alphanumeric characters and hyphens (-). The name must contain a minimum of five characters up to a maximum of 100 characters.
Outputs
When your stack is created successfully, you can see the following output parameters on the Outputs tab of the CloudFormation stack in AWS Management Console.
Output name
Output description
ELBDNSName
The Elastic Load Balancer domain name system (DNS) name.
ELBName
The Elastic Load Balancer name.
After the load balancer is created, map it to the domain name for your deployment.
