Introduction to licensing user type extensions
User type extensions are licenses that extend the capabilities of ArcGIS Enterprise for specific users in an organization. They can be included in a user type or as an add-on license that you assign to members of your organization.
Although user type extensions provide access to this functionality, administrators must ensure that organization members are assigned appropriate user types and roles to do their work. For example, if a member is assigned the Viewer user type and the Viewer role, they can only view services and other content across ArcGIS Enterprise.
Available user type extensions are described below.
ArcGIS Advanced Editing
In ArcGIS Enterprise 11.1 and earlier releases, the ArcGIS Utility Network, ArcGIS Trace Network, and ArcGIS Parcel Fabric user type extensions were separate. These are now consolidated into the ArcGIS Advanced Editing user type extension. For information about configuring user type extensions, see Manage licenses.
The ArcGIS Advanced Editing user type extension provides access to the following advanced geodatabase functionality and frameworks when accessed through feature layers that reference data in a registered data store:
To use these with ArcGIS Enterprise, your organization members must be assigned a license for the ArcGIS Advanced Editing user type extension. This user type extension is included in the Professional and Professional Plus user types. It can also be included as an add-on for user types with at least the capability to view and edit data, such as Mobile Worker, Contributor, and Creator user types.
ArcGIS Location Sharing
ArcGIS Location Sharing is an organization-wide extension, allowing users to share where they are and where they have been.
Organization administrators or members with the correct privileges can enable location sharing for members. When location sharing is enabled, licensed users in the organization can use the Field Maps, QuickCapture, or Indoors mobile apps to upload their locations to the location sharing layers. Organization members must be assigned a license for the ArcGIS Location Sharing user type extension to share their location. This user type extension is included with the Mobile Worker user type or it can be included as an add-on for other user types.
For more information about using ArcGIS Location Sharing, see Location sharing.
