Privileges granted to roles
Privileges are granted to members through roles. Privileges allow role members to perform various tasks and workflows in an organization. For example, some members have privileges to create and publish content, while others have privileges to view content but cannot create their own.
When the organization administrator creates custom roles, the administrator specifies which privileges the custom role includes. Whereas, default roles include a specific set of privileges that cannot be altered.
There are two levels of privileges: General privileges and Administrative privileges.
To view the privilege values, see ArcGIS Enterprise supported privileges.
General privileges
Members who perform specific tasks in the organization—create maps or edit features, for example—can be assigned the general privileges they need to complete their work.
The following table lists privileges, grouped by privilege type, and provides a description of each privilege. The table also lists which default roles include the privilege.
General privileges
Default roles that include the privilege
Members
View
This privilege grants the ability to view members of the organization. When checked, the View privilege allows members to view the Members tab on the Organization page. If not checked, members cannot see the Organization page.
All default roles
Take ArcGIS Pro license offline
This privilege allows members to take their ArcGIS Pro license offline. If the organization option Members cannot take ArcGIS Pro offline is set, it overrides the privilege.
All default roles
Groups
Create, update, and delete
This privilege allows members to create groups and control the groups they own.
User, Publisher, Administrator
Join organizational groups
Members of roles that are granted this privilege can be added to organizational groups or request to join groups in the organization. Members can only request to join organizational groups if you also grant the role the View groups shared with organization privilege. If the role does not have the privilege, members do not see the groups and, therefore, cannot request to join them.
All default roles
Only members of the User, Publisher, and Administrator default roles can join shared update groups.
This privilege allows members to discover groups that are configured to allow organization members to view them.
All default roles
Content
This privilege allows members to create items in the organization and control the items they own. This privilege is required if you grant any of the privileges that allow members to publish, register data stores, or create notebooks. This privilege is also required to be a member of a shared update group.
Publish hosted feature layers
This privilege allows members to publish hosted feature layers from within the organization and from other apps, such as ArcGIS Pro. This privilege is also required when using apps that create hosted feature layers, such as ArcGIS Survey123.
Publish hosted tile layers
This privilege allows members to publish hosted tile layers from tile packages, features, and other clients such as ArcGIS Pro and allows members to publish hosted 3D tiles layers from 3D tiles packages and ArcGIS Pro and allows members to manage layers published from packages.
Publish hosted scene layers
This privilege allows members to publish hosted 3D (scene) layers from the organization and from other apps, such as ArcGIS Pro.
Publish hosted dynamic imagery layers
This privilege is only available when your organization is configured for raster analysis.
Publish server-based layers
This privilege allows members to publish ArcGIS Server web layers to ArcGIS Server sites that are federated with the organization. This privilege is also required for members who will bulk publish layers from a data store item.
Publish hosted knowledge graphs
This privilege allows members to publish hosted knowledge graphs in ArcGIS Pro. This privilege is only available if an ArcGIS Knowledge Server site is configured for your organization.
View content shared with organization
This privilege allows members to access items that are shared with the organization.
All default roles
Register data stores
This privilege allows members of the role to add data store items to the organization.
Create feature layers in bulk from a data store
This privilege allows the owner of a database data store item to publish feature and map image layers from all feature classes and tables that can be accessed in the database.
View location tracks
This privilege grants the ability to view members' location tracks using shared track views when location sharing is enabled.
Administrator
Create and edit notebooks
This privilege allows members to open and run notebooks, including shared notebooks and notebooks created from a notebook file (* .ipynb) imported into the organization, and create and edit notebooks using the ArcGIS Notebooks Standard runtime. This privilege is also required for users who will be running web tools published from a notebook.
This privilege is only available if Notebook Server is configured for your organization. Additional privileges (such as managing content or running specialized analysis tools) may be required depending on the workflows performed by the notebook author.
Administrator
Schedule notebooks
This privilege allows role members to schedule ArcGIS Notebooks to be run in the future. To schedule a particular notebook, the user must own the notebook or have administrative privileges.
This privilege is only available if Notebook Server is configured for your organization. The Create and edit notebooks privilege must be enabled for this privilege to be set.
Administrator
Reassign content
Allows members to transfer ownership of content they own to another member in the same organization. The member to whom ownership is transferred must have the privilege to receive content.
Administrator
Receive content
Allows members to receive content transferred to them from members who have the privilege to reassign content.
This privilege is not required to receive content transferred by organization administrators.
Administrator
Generate API keys
Allows members to create and embed API keys as a longer-term authentication option in app items.
Administrator
Assign privileges to OAuth 2.0 applications
Allows members to define privileges for OAuth 2.0 credentials in app items. The privileges a member can assign are based on their privileges to perform location service analyses.
This privilege also allows members to specify which of their own items can be accessed by the OAuth app.
Administrator
Create workflow item
Allows members to create Workflow Manager items.
You can only create Workflow Manager items if workflow management services or a federated Workflow Manager Server site is configured for your organization.
Sharing
Share with groups
This privilege allows members to share items they own with any groups to which the member belongs.
Share with the organization
This privilege allows members to share any items they own with the organization.
Share with public
This privilege allows members to share items they own with everyone, even users who do not sign in to the organization.
Make groups visible
When you create a group, you specify who can see the group or search for the group. This privilege is required to allow group creators to configure the group to allow organization members to view the group. This privilege is only useful if the role also includes the privilege to create, update, and delete groups.
Make groups visible to public
When you create a group, you specify who can see the group or search for the group. This privilege is required to allow group creators to configure the group to allow anonymous organization users to view the group. This privilege is only useful if the role also includes the privilege to create, update, and delete groups.
Content and Analysis
Geocoding
Use ArcGIS World Geocoding Service to convert addresses or places to map points and store the results—for example, when publishing spreadsheets (.csv or Microsoft Excel files) as hosted feature layers. This does not apply to your locators configured for the organization.
All default roles
Network Analysis
This privilege grants the ability to perform network analysis tasks such as creating drive-time areas.
All default roles
Standard Feature Analysis
This privilege grants the ability to perform spatial analysis tasks such as creating buffers.
GeoEnrichment
This privilege grants the ability to use the GeoEnrichment service to access demographic information.
Imagery Analysis
This privilege grants the ability to use raster analysis tools. This privilege requires that your deployment be configured for raster analysis.
Advanced notebooks
This privilege grants the ability to author notebooks using advanced runtimes.
This privilege is only available if a Notebook Server is configured for your organization. Additional privileges (such as managing content or running specialized analysis tools) may be required depending on the workflows performed by the notebook author.
Administrator
Run web tools
This privilege allows a member to run web tools published from notebooks.
Administrator
Reality Mapping
This privilege allows a member to perform reality mapping tasks.
This privilege is only available if a Reality Server is configured for your organization. Additional privileges may be required depending on the workflows performed by reality analysts.
Administrator
Features
Edit
This privilege grants the ability to edit features based on permissions set on the layer and update schema on a knowledge graph layer.
Data Editor, User, Publisher, Administrator
Edit with full control
Add, delete, and update features and attributes in editable hosted feature layers, even if the layers are configured to allow fewer editing operations. This privilege also allows members to update schema on a knowledge graph layer.
Administrator
Version Management
Manage all
This privilege allows role members to view, alter, and delete all branch versions accessed through an ArcGIS Server web feature layer. This privilege also allows role members to manage version locks on these layers.
When you enable this privilege, the following privileges are also enabled by default:
  • The Edit privilege, under Features, is granted to allow role members to edit data in all versions and perform reconcile and post operations between the default and named branch versions.
  • The Edit with full control privilege, under Features, is also granted to allow role members to perform all editing operations when the web feature layer has fewer editing capabilities enabled. This is helpful to facilitate quality assurance work during the review of versioned edits. For example, if the web feature layer only has the update operation enabled, the Edit with full control privilege additionally allows the reviewer to perform insert and delete operations.
Members of a custom role that has these three privileges are referred to as version administrators.
Webhooks
Feature layer
This privilege allows role members to create, edit, and delete their own feature layer webhooks.
Administrator
At this release, privileges that correspond to unsupported apps and capabilities in ArcGIS Enterprise on Kubernetes are not supported.
The privileges in the table below are included in the default administrator role and can also be assigned to custom roles. Including administrative privileges in custom roles allows members to assist default administrators with a subset of administration tasks, such as managing members, groups, and content in the organization.
When you create a custom role that includes administrative privileges, only members assigned a Creator, Professional, or Professional Plus user types can be assigned to the custom role.
Some administrative privileges are reserved for members of the default administrator role and are not available for custom roles.
Members
View all
View all member account information.
Update
Update member account information, reset passwords, and assign (and unassign) member categories.
Only members of the default administrator role can reset the passwords of other members of the default administrator role or members of custom administrator roles.
Delete
Remove member accounts from the organization.
Add
Add member accounts to the organization.
Disable
This privilege grants the ability to disable and enable member accounts.
Change roles
Change the role assigned to organization members.
Only members of the default administrator role can add members to or remove members from the default administrator role.
Manage licenses
Manage licenses for organization members.
Manage categories
Configure member categories for the organization
Groups
View all
View groups owned by organization members.
Update
Update groups owned by organization members.
Delete
Delete groups owned by organization members.
Reassign ownership
Reassign ownership of groups.
Assign members
Assign members to, update your members' group role in, and remove members from groups in the organization.
Link to organization-specific group
Link group membership to organization-specific groups.
Create with leaving disallowed
Create and own groups that do not allow group members to leave (administrative groups).
Create with update capabilities
Create and own groups that allow group members to update all items in the group (shared update groups).
Content
View all
View content owned by all organization members.
Update
Update and categorize content owned by all organization members, and edit data in all hosted feature layers and hosted feature layer views, even when editing is not enabled on those layers. View, modify, and delete all branch versions accessed through an ArcGIS Server web feature layer, and manage version locks on these layers.
Delete
Delete content owned by any organization member.
Reassign ownership
Reassign ownership of content.
Manage categories
Configure content categories for the organization.
Publish web tools
Allows role members to publish web tools.
Share member content with organization
Allows role members to share content owned by other members of your organization with the organization.
Share member content with public
Allows role members to share content owned by other members of the organization with the public.
Create and manage administrative reports
Allows role members to create and manage administrative reports for the organization.
Webhooks
Geoprocessing
Create, edit, and delete geoprocessing webhooks.
Portal settings
Security and infrastructure
Manage the portal's security settings.
Members of roles with this privilege can configure the following in the organization settings:
  • General—Administrative contacts
  • About—Deployment summary
  • Items—Comments
  • New member defaults—User type, Role, Add-on licenses, Groups, Member categories, Username format
  • Security—Policies (HTTPS, Access and permissions, Sharing and searching), Sign-in policy, Logins, Multifactor authentication, Access notice, Information banner, Trusted servers, Allow origins, Allowed proxy hosts, Allow organization access, Apps, Developer credentials, Email settings
Members of roles with this privilege can also import a new license file, view the organization logs, update log settings, and clean the logs.
Organization website
Manage the organization settings.
  • General—Organization profile (Name, Summary), Contact link, Organization defaults (Language, Number and date format), Shared theme, Navigation bar, Help source
  • Home page—Launch editor
  • Gallery—Show in gallery
  • Map and scene—Basemap gallery for maps and scenes, Map and scene defaults, Web styles
  • Items—Metadata, Organization categories, Item classification, Search using related terms
  • Groups—Featured groups
  • Living Atlas—Content version, Configuration, Deep learning models
Members of roles with this privilege can also view the logs.
Collaborations
Manage collaborations.
Members of roles with this privilege can configure and manage Collaborations in the organization settings. These members can also view the logs.
Member roles
Manage the organization's member roles.
Members of roles with this privilege can configure Member roles in the organization settings and change a member's role. These members can also view the logs.
Servers
Manage the organization's server settings.
Members of roles with this privilege can configure the federated server sites for the organization in the Servers section of the organization settings.
Members of roles with this privilege can also view the logs, update the log settings, and clean the logs.
Utility services
Manage the utility service settings.
Organization webhooks
Create, edit, and delete organizational webhooks and manage all webhooks in the organization.
Privileges that correspond to unsupported apps and capabilities in ArcGIS Enterprise on Kubernetes are not supported.
Privileges and workflows reserved for members of the default administrator role
Some administrative privileges and workflows are reserved for members of the default administrator role and are not available for custom roles. For example, only members of the default administrator role can remove other administrators from the organization. The following is a list of privileges and workflows reserved for members of the default administrator role:
  • Change member role to or from administrator.
  • Delete other administrators from the organization.
  • Reset the passwords of other members of the default administrator role or members of custom administrator roles.
  • Serve as the administrative contact for the organization.
  • Create backups of the ArcGIS Enterprise deployment.
  • Assign custom roles with administrative privileges to new members when adding them to the organization.
  • Export and import items shared with a group.
  • Manage scheduled administrative reports owned by members.
  • Create a custom sign-in category for an app owned by another member.
  • Create folders on behalf of members in your organization.
  • Enable the Workflow Management organization extension to allow ArcGIS Workflow Manager perform tasks on behalf of members in your organization.
Privileges for common workflows
Some workflows require a combination of privileges. If you are unable to perform a function that you think your role should allow you to perform, verify that the organization administrator has enabled the full set of privileges required for the function.
The required privileges in the following table indicate the type of privilege (for example, Content) followed by the privilege name. Privileges are general privileges unless noted to be administrative privileges.
Workflow
Required privileges
Use the standard feature analysis tools
  • Content > Create, update, and delete
  • Content > Publish hosted feature layers
  • Content and Analysis > Standard Feature Analysis
Some tools require additional privileges to use GeoEnrichment or network analysis. See Perform analysis for requirements per tool.
Use raster analysis tools
  • Content and Analysis > Imagery Analysis
Publish hosted feature and WFS layers
  • Content > Publish hosted tile layers
  • Content > Publish hosted scene layers
Publish hosted imagery layers
  • Content > Publish dynamic imagery layers
Publish feature layers from custom data providers
  • Content > Publish server-based layers
Create knowledge graphs from ArcGIS Pro
  • Content > Publish hosted knowledge graphs
Publish apps from Map Viewer or a group page
  • Content > Share with groups
  • Content > Share with portal
  • Content > Share with public
Customize app sign-in categories
To customize app sign-in categories, your administrator must enable custom sign-in for the organization.
Author notebooks
  • Content > Create and edit notebooks
  • Content and Analysis > Advanced notebooks (required to use ArcPy in notebooks)
Add, update, and delete features on editable hosted feature layers even if the hosted feature layer is configured to only update feature attributes or only add new features
  • Features > Edit features
  • Features > Edit with full control
Perform quality assurance reviews, reconcile, and post edits between ArcGIS Server feature services that contain branch versioned data
  • Version Management > Manage all
Reassign ownership of your items to another member
  • Members > View
  • Content > Reassign content
Only members who have the privilege to receive content can become owners of the reassigned content.
Manage content owned by members
  • Members > View all (Administrative privilege)
  • Groups > View all (Administrative privilege)
  • Content > View all (Administrative privilege)
  • Content > Update (Administrative privilege)
  • Content > Delete (Administrative privilege)
  • Content > Reassign ownership (Administrative privilege)
  • Content > Share member content with organization (Administrative privilege)
  • Content > Share member content with public (Administrative privilege)
  • Sharing > Share with portal
  • Sharing > Share with public
Manage groups owned by members
  • Groups > Update (Administrative privilege)
  • Groups > Delete (Administrative privilege)
  • Groups > Reassign ownership (Administrative privilege)
  • Groups > Assign members (Administrative privilege)
Manage member profiles
  • Members > Update (Administrative privilege)
Delete members, which also involves managing (reassigning or deleting) their content and groups
  • Members > View
  • Members > Delete (Administrative privilege)
If you want members of the custom administrator role to always reassign groups and content owned by the members they're deleting from the organization rather than deleting those groups and content, do not assign the Content > Delete and Groups > Delete privileges to the custom role.
Manage the organization's security and infrastructure
  • Members > View
  • Groups > View groups shared with organization
  • Portal settings > Security and infrastructure (Administrative privilege)
Manage the organization's website settings
  • Members > View
  • Content > View content shared with organization
  • Sharing > Share with groups
  • Sharing > Make groups visible to the portal
  • Sharing > Make groups visible to the public
  • Content > Manage categories (Administrative privilege)
  • Portal settings > Organization website (Administrative privilege)
  • Members > View
  • Groups > Create, update, and delete
  • Portal settings > Collaborations (Administrative privilege)
  • Members > View
  • Members > Change role (Administrative privilege)
  • Portal settings > Member roles (Administrative privilege)
Change a member's user type
  • Members > View
  • Members > Manage licenses (Administrative privilege)
  • Members > View
  • Portal settings > Servers (Administrative privilege)
  • Portal settings > Utility services (Administrative privilege)
Manage the organization's utility service settings
  • Members > View
Create and manage administrative groups
  • Groups (general) > Create, update, and delete
  • Groups (administrative) > Update
  • Groups (administrative) > Create with leaving disallowed
Import new license file
  • Members > View
