Configure security settings
As a default administrator or member with the appropriate privileges, you determine whether HTTPS is required for all transactions and whether anonymous access is allowed to your portal. You can also configure security settings for sharing and searching, password policies, sign in options, access notices, information banners, trusted servers, and more.
Tip:
Visit ArcGIS Trust Center for more in-depth security, privacy, and compliance information.
  1. Confirm that you are signed in as a default administrator or as a member of a custom role with the administrative privilege to manage security and infrastructure enabled.
  2. At the top of the site, click Organization and click the Settings tab.
  3. Click Security on the side of the page.
  4. Configure any of the following security settings:
Policies
Change any of the following policy settings as needed:
  • Allow access to the portal through HTTPS only—By default, the portal enforces HTTPS-only communication to ensure that your organization's data as well as any temporary identification tokens that allow access to your data are encrypted during communications over the internet. Turning off this toggle button allows both HTTP and HTTPS communication. Changes to this setting may affect the performance of the site.
  • Allow anonymous access to your portal—Enable this option to allow anonymous users access to your organization's website. If this option is not enabled, anonymous access is disabled, and anonymous users cannot access the website.
    If you enable anonymous access, ensure that the groups selected for the site configuration groups are shared with the public; otherwise, anonymous users may not be able to properly view or access the public content of those groups.
  • Allow members to edit biographical information and who can see their profile—Enable this option to allow members to modify the biographical information in their profile and specify who can see their profile.
  • Allow your portal to access KML layers—Enable this option to allow members to view or add KML layers to the content page or web maps.
  • Allow your portal to access GeoRSS feeds—Enable this option to allow members to view or add GeoRSS feeds to web maps.
Sharing and searching
Change any of the following sharing and search settings as needed:
  • Members who are not administrators can make their content, groups, and profile public—Enable this option to allow members to make their profile or groups visible to everyone (public), share their web apps and other items with the public, and embed their content or groups in websites. If you disable this option, default administrators and members assigned the administrative privilege to share member content with the public can still make other members' content, groups, and profiles public.
  • Show social media links on item and group pages—Enable this option to include links to Facebook and X on item and group pages.
Sign-in policy
Configure a password policy and lockout settings as required for your organization.
Password policy
When members change their passwords, they must conform to the organization's policy. If they don't, a message appears with the policy details. The password policy of the organization does not apply to organization-specific logins, such as SAML logins, or app credentials that use app IDs and app secrets.
Click Manage password policy to configure the password length, complexity, and history requirements for members with built-in accounts. You can specify the character length and whether the password must contain at least one of any of the following: uppercase letter, lowercase letter, number, or special character. You can also configure the number of days before the password expires and the number of past passwords that the member cannot reuse. Passwords are case sensitive and cannot be the same as the username. Click Use portal defaults to reset the organization to use the standard ArcGIS Enterprise password policy (at least eight characters with at least one letter and one number; spaces are not allowed).
Weak passwords may not be accepted. A password is considered weak if it's a commonly used password such as password1 or includes repetitive or sequential characters—for example, aaaabbbb or 1234abcd.
If email settings are configured in your organization, an automatic email notification will be sent to your administrative contacts when the password policy is changed.
Lockout settings
By default, when a member attempts to sign in to their ArcGIS Enterprise organization using a built-in account, they are locked out of the website for 15 minutes after five failed attempts in a 15-minute period. Click Manage lockout settings to change the number of failed sign-in attempts permitted, or the lockout duration if that number is exceeded, or both. Click Restore defaults to return to the default lockout settings.
Logins
You can customize the organization's sign-in page to allow members to sign in using any of the following methods: ArcGIS logins, Security Assertion Markup Language (SAML) logins (previously known as enterprise logins), and OpenID Connect logins.
You can also customize the order in which the login methods appear on the organization's sign-in page. To reorder a login method, click its handle and drag it to a new position. Click Preview to see what the sign-in page will look like.
Turn on the ArcGIS login button to allow users to sign in to ArcGIS using their ArcGIS logins. When enterprise logins have been configured, you can turn off the ArcGIS login toggle button to direct users to the external identity provider's sign-in page instead of the organization's sign-in page.
The ArcGIS login option only hides the ArcGIS option on the organization's sign-in page. You can still access resources hosted by ArcGIS in your ArcGIS applications by manually generating a token or by using ArcGIS APIs and SDKs. To disable an ArcGIS account, see Disable member accounts.
Use the New SAML login button to configure a SAML-compliant identity provider with your portal if you want members to sign in to the portal using your organization's existing SAML identity provider.
Use the New OpenID Connect login button to configure OpenID Connect logins if you want members to sign in using your organization's existing OpenID Connect identity provider.
Create a custom sign-in category
You can customize your organizational sign-in experience by using custom sign-in categories. Once you create a custom sign-in category, OAuth 2.0 applications managed in your organization can inherit these categories or can have their own sign-in categories.
To create a custom sign-in category for your organization, complete the following steps:
  1. Confirm that you are signed in as a member with the default administrator role or as a member with a custom role with the administrative privilege to manage security settings.
  2. Click Security on the Settings tab of your organization page.
  3. Turn on the Allow customization of the sign-in experience for your organization and OAuth 2.0 applications toggle button. This option is disabled by default.
  4. Click Create a custom sign-in category.
    You can configure a maximum of 100 custom sign-in categories.
    The Create sign-in category pane appears.
  5. Optionally, in the Choose how to start pane, you can choose a category other than the Organizational default option. Click the drop-down arrow under Select a sign-in category to start from and choose an option.
    The sign-in methods will reflect what is authorized under the Logins section for your organizations, such as ArcGIS login, Open ID, or SAML.
  6. Click Next.
  7. Provide a title and description in the Title and Description fields, respectively, for your category.
    The title you choose will appear as an option under Select account type when a user signs in to the organization.
  8. Click Next.
  9. Optionally, use the Login types pane to enable access to login categories and alter the Title of login categories once they are enabled.
    At least one login method must be enabled to create a category.
    Tip:
    Uncheck the box next to Enable sign-in category if you want to set up the category but are not ready for users to sign in with the category. You can enable the category by turning on the toggle button next to the category name in the Custom sign-in section of the Security section in your organizational settings.
  10. Click Create category.
    Once you create and enable a custom sign-in category, the organizational default will not appear when users sign in to the organization.
    The category appears under the Custom sign-in section of the Security section in your organizational settings.
  11. Optionally, click Preview sign-in page to see what users will see when they sign in. To update the custom sign-in category, click Configure.
Multifactor authentication
This option controls multifactor authentication for built-in accounts. To configure multifactor authentication for accounts based on SAML or OpenID Connect logins, go to your identity provider to configure the corresponding options.
Multifactor authentication for built-in accounts can only be enabled if your organization has email settings configured.
Organizations that want to allow members to set up multifactor authentication for signing in to ArcGIS can turn on the Enable multifactor authentication for organization toggle button. Multifactor authentication provides an extra level of security by requiring a verification code in addition to a username and password when members sign in.
If you enable this setting, organization members can set up multifactor authentication through their settings page and receive verification codes on their mobile phones or tablets from a supported authenticator app (currently, Google Authenticator for Android and iOS and Authenticator for Windows Phone).
Tip:
Members who enable multifactor authentication have a check mark in the Multifactor Authentication column of the member table on the Members tab on the Organization page.
If you enable multifactor authentication for your organization, you must designate at least two administrators who will receive email requests to disable multifactor authentication as needed on member accounts. ArcGIS Enterprise sends emails on behalf of members who request help with multifactor authentication through the Still having trouble signing in? link (on the page where the member is asked to provide the authentication code). At least two administrators are required to ensure that at least one will be available to help members with any multifactor authentication issues.
Multifactor authentication works with Esri apps that support OAuth 2.0. This includes the portal website, ArcGIS Pro, ArcGIS apps, and My Esri.
Multifactor authentication must be disabled to access apps without OAuth 2.0 support. This includes geocoding and geoprocessing services that perform routing and elevation analysis. Multifactor authentication must also be disabled when storing credentials with Esri premium content.
Enforce multifactor authentication
Administrators can enforce multifactor authentication across their organization to ensure that members with ArcGIS logins are in compliance with security policies when signing in to ArcGIS Enterprise, improving the security of their organization. When multifactor authentication is enforced, members with ArcGIS logins will be required to set up multifactor authentication for their accounts in order to sign in. Members will no longer be able to disable multifactor authentication for their own account, but they will be able to reset it.
Disabling multifactor authentication enforcement allows members to disable multifactor authentication for their own account and does not disable multifactor authentication for members that have it set up. They will continue to be prompted to sign in using multifactor authentication.
Administrators can also exempt members using ArcGIS logins from being required to set up multifactor authentication in order to sign in. Members on the exemption list can enable and disable multifactor authentication for their own account through their settings page.
Enforcing multifactor authentication signs out any members with ArcGIS logins who have not yet enabled multifactor authentication, interrupting all ongoing work and processes. Reach out to your members in advance to give them enough time to set up multifactor authentication before enabling multifactor authentication enforcement. To avoid unwanted disruptions, you can temporarily add members to the multifactor authentication exemption list.
Follow these steps to enforce multifactor authentication:
  1. Confirm that you are signed in as a default administrator or as a member of a custom role with the administrative privilege to manage security and infrastructure.
  3. Under Security, click Enforce MFA.
    Tip:
    Optionally, you can click Manage exemption list to add any users that will retain the ability to enable or disable multifactor authentication. If multifactor authentication is not enforced, the exemption list will have no effect. Click Save when finished.
    A window appears.
  4. Click Enforce.
    An MFA enforcement is currently in effect label appears in the security settings under MFA Enforcement.
  5. To disable multifactor authentication, click Disable MFA enforcement. To manage the exemption list, click Manage exemption list.
Access notice
You can configure and display a notice of terms for users who access your site.
You can configure an access notice for organization members or all users who access your organization, or both. If you set an access notice for organization members, the notice is displayed after members sign in. If you set an access notice for all users, the notice is displayed when any user accesses your site. If you set both access notices, organization members see both notices.
To configure an access notice for organization members or all users, click Set access notice in the appropriate section, turn on the toggle button to display the access notice, and provide a notice title and text. Choose the Accept and Decline option if you want users to accept the access notice before proceeding to the site, or select OK only if you want users to only click OK to proceed. Click Save when finished.
HTML tags are not permitted in the access notice.
To edit the access notice for organization members or all users, click Edit access notice in the appropriate section and make changes to the title, text, or action button options. If you no longer want the access notice displayed, use the toggle button to disable the access notice. After disabling the access notice, the previously typed text and configuration will be retained if the access notice is re-enabled in the future. Click Save when finished.
Information banner
You can use information banners to alert all users who access your organization about your site's status and content. For example, inform users about maintenance schedules, classified information alerts, and read-only modes by creating custom messages to appear at the top and bottom of your site. The banner appears on the Home, Gallery, Map Viewer, Scene Viewer, Notebook, Groups, Content, and Organization pages, and on sites created in ArcGIS Enterprise Sites if enabled in the app.
To enable the information banner for your organization, click Set information banner and turn on Display information banner. Add text in the Banner text field and choose a background color and font color. A contrast ratio appears for the selected text and background color. Contrast ratio is a measure of legibility based on WCAG accessibility standards; a contrast ratio of 4.5 is recommended to adhere to these standards.
HTML tags are not permitted in the information banner.
You can preview the information banner in the Preview pane. Click Save to add the banner to your organization.
To edit the information banner, click Edit information banner and make changes to the banner text or styling. If you no longer want the information banner displayed, use the toggle button to disable the information banner. After disabling the information banner, the previously typed text and configuration will be retained if the information banner is re-enabled in future. Click Save when finished.
Trusted servers
For Trusted servers, configure the list of trusted servers you want your clients to send credentials to when making Cross-Origin Resource Sharing (CORS) requests to access services secured with web-tier authentication. This applies primarily to editing secure feature services from a stand-alone (unfederated) server running ArcGIS Server or viewing secure Open Geospatial Consortium (OGC) services. ArcGIS Server hosting services secured with token-based security do not need to be added to this list. Servers added to the trusted servers list must support CORS. Layers hosted on servers without CORS support may not function as expected. ArcGIS Server supports CORS by default at versions 10.1 and later. To configure CORS on non-ArcGIS servers, refer to the vendor documentation for the web server.
The host names must be provided individually. Wildcards cannot be used and are not accepted. The host name can be provided with or without the protocol in front of it. For example, the host name secure.esri.com can be provided as secure.esri.com or https://secure.esri.com.
Editing feature services secured with web-tier authentication requires a web browser enabled with CORS. The latest versions of Mozilla Firefox, Google Chrome, and Safari are CORS enabled. To test if your browser has CORS enabled, open https://caniuse.com/cors.
Allow origins
By default, ArcGIS REST API is open to CORS requests from web applications on any domain. If your organization wants to limit the web application domains that are allowed to access ArcGIS REST API through CORS, you must specify these domains explicitly. For example, to restrict CORS access to web applications on acme.com only, click Add, type https://acme.com in the text box, and click Add domain. You can specify up to 100 trusted domains for your organization. It's not necessary to specify arcgis.com as a trusted domain, as applications running on the arcgis.com domain are always allowed to connect to ArcGIS REST API.
Allowed proxy hosts
Configure a list of host names or domains that the portal is allowed to access. This restriction applies to several scenarios, including when the portal accesses resources from a domain that does not support Cross-Origin Resource Sharing (CORS) or when saving credentials used to access a secured service. In ArcGIS Enterprise, certain proxy hosts are allowed by default. You can update this list to fit your organization's security requirements. For instructions, see Restrict the portal's proxy capability.
Allow portal access
Configure a list of portals (for example https://otherportal.example.com/arcgis) with which you want to share secure content. This allows members of your organization to use their organization-specific logins to access the secure content when viewing it from these portals. Portals that your organization collaborates with are included automatically and do not need to be added to this list. This is only applicable for portals at ArcGIS Enterprise version 10.5 and later. This setting is not needed for sharing secured content with an ArcGIS Online organization.
The portal URLs must be provided individually and must include the protocol. Wildcards cannot be used and are not accepted. If the portal being added allows both HTTP and HTTPS access, two URLs must be added for that portal (for example http://otherportal.example.com/arcgis and https://otherportal.example.com/arcgis). Any portal added to the list is validated first and, therefore, must be accessible from the browser.
Apps
You can specify which external apps can be accessed by organization members and, optionally, make approved web apps available to organization members in the app launcher. You can also specify a list of Esri apps that should be blocked from members to comply with regulations, standards, and best practices.
Approve apps
All Esri apps and licensed apps are automatically approved for member access. To give organization members access to other types of apps without a Request for Permissions prompt, you must specify a list of approved apps for the organization. Approved apps can include web, mobile, or native apps hosted in your organization or outside your organization. For access to external apps, you can also restrict member sign-in to only those apps added to the approved apps list.
Approved web apps can also be made available to organization members in the app launcher. Licensed apps automatically appear in the app launcher for members with appropriate licenses. For more information, see Manage apps in the app launcher.
Do the following to approve apps for access by organization members:
  3. Click Security on the side of the page and click Apps to move to the Apps section of the page.
  4. Under Approved apps, click Add approved app.
  5. Search for an app using one of the following methods:
    • Browse to the app in the list—By default, the list only includes apps that are of type Web Mapping Application or Application and are registered with your organization.
    • Search by name—When searching by app name, you can only find apps that are hosted in your organization.
    • Search by item URL—The item URL appears in the browser's address bar when you access the app's item page.
    • Search by client ID—If you own or have access to the app item, you can find the client ID on the registered app's item page.
      If the app item is of type Desktop Application, you must search by the app ID, which can be found on the Settings tab (Desktop Application > App Registration > Registered Info) of the app's item page.
  6. Select an app to approve.
  7. Optionally, if you selected a web app, turn off the Show in app launcher toggle button to hide the web app in the app launcher.
    To show the web app in the app launcher, leave this toggle button turned on and follow the steps in Manage apps in the app launcher.
  8. Click Save to add the app to the approved apps list.
Blocked Esri apps
If your organization wants to restrict access to some of the apps that are included with user types and cannot be controlled through licensing, you can configure a list of blocked apps and capabilities.
Blocked apps and capabilities are removed from the app launcher and their items cannot be created from the content page or from a web map. Administrators can still see blocked apps and capabilities when managing licenses and adding new members but cannot select them.App items that are created before an app is blocked remain visible in the organization, but members cannot sign in to them. If a blocked app is shared with your organization, members cannot sign in and use the app.
To block apps, click Manage blocked Esri apps and capabilities, select the apps and capabilities you want to block, and click Save.
Administrators can remove apps from their organization's blocked apps list by deselecting them in the Manage blocked Esri apps and capabilities window or by clicking the Remove button next to the app in the list.
Developer credentials
As a developer, you can add and register an app using developer credentials.
You can find a developer credential item by clicking Find API key, token, or client ID and entering a value. You can also click View API keys by expiration date to sort by a specific time period, such as a week or month.
Configure email settings
You can configure email settings for your organization, which can be used to send email notifications to members. The following email notifications can be configured:
  • Password policy notifications—An automatic email notification will be sent to your administrative contacts when the password policy is changed. If no administrative contacts are set, the oldest administrator account in the organization or the initial administrator account will receive the email notification.
  • Reset password notifications—Administrators can reset a member's password on the Members tab, which will send an email to the member with a temporary password. A member can also request a reset password link when they indicate they have forgotten their password on the organization sign-in page. Emails will be sent to the email address associated with a member's profile.
  • License expiration notifications—An automatic email notification will be sent to your administrative contacts when licenses in your organization are about to expire. These members will begin receiving emails 90 days before the license's expiration and will continue to receive notifications at set intervals up until one day before expiry. If no administrative contacts are set, the oldest administrator account in the organization or the initial administrator account will receive the email notification.
  • Multifactor authentication notifications—Your organization must have email settings configured to enable multifactor authentication. If multifactor authentication is configured, designated administrators will receive email notifications to disable multifactor authentication for specific members if needed.
  • Item comment notifications—When comments are enabled in the organization, item owners will receive email notifications of new comments published to their items.
  • Profile and settings notifications—Members will be notified of changes to their profile and settings such as their password, security question, and profile visibility.
Follow these steps to configure email settings:
  1. To configure email notifications for your organization, under Email settings, click Configure.
    If email settings are already configured, click Manage email settings to open the Configure email settings window.
  2. On the SMTP settings page, do the following:
    1. Provide the SMTP server address.
      This is the IP address or fully qualified domain name (FQDN) of the SMTP server, for example, smtp.example.com.
    2. Provide the SMTP port.
      This is the port the SMTP server will communicate over. Some of the most common communication ports are 25, 465, and 587. The default value is 25.
    3. Under Encryption method, select the encryption method for email messages sent from your organization.
      You can select Plain Text, STARTTLS, or SSL.
    4. Turn on SMTP authentication required if authentication is required to connect with the SMTP server specified.
      You can leave this option off if SMTP authentication is not required.
    5. If SMTP authentication required is enabled above, provide the username and password of a user who is authorized to access the SMTP server.
    6. Provide the email address from which organization emails will be sent.
      It is recommended that the member associated with this email address be listed under the Administrative contacts for your organization.
    7. Provide the email address label that will display with the sent from email address.
      The information is displayed as the sender in the from line for all email notifications. You can use the name associated with the from email address, or use a label such as DO NOT REPLY to discourage members from replying directly to the from email address.
  3. Click Next.
    It is recommended that you send a test email to verify that you have configured your email settings correctly.
  4. Provide an email address that you can use to verify that the test email is delivered successfully, and click Send Email.
    A notification appears to indicate whether the email is sent successfully. You can check the portal logs for more information.
  5. Click Finish to configure email settings.
To disable email notifications from your organization, click Disable email settings.
