Overview settings
When you sign in to ArcGIS Enterprise Manager, the Overview page provides an active view of your organization where you can monitor recent log messages, view index status and reindex as needed, check the status of required storage, and more.
Refresh interval
The refresh interval setting identifies the frequency at which information such as health and status for each resource type is pulled and cached. If a refresh interval is specified as 0, no information is collected and cached for that resource type.
From Overview settings, set the refresh interval for each functional area of this page. The following are the default interval values for each resource type:
Critical logs—0 minutes
Index status—0 minutes
System storage—1 minute
System services pods—1 minute
Utility services pods—1 minute
After updating a refresh interval to increase or decrease the frequency at which the status is retrieved, click Save.
To update the refresh interval settings back to the default values, click the Reset all to default button and click Save.
Critical logs
In the Critical logs section, you can review the most recent logs, for example, those logged at the Severe level. Logs are displayed with a time stamp of when they occurred, along with severity level, a brief message, and the pod source from which the log originates. To view additional logs, details, and settings, click View all logs.
Index status
In the Index status section, you can verify that the index and index store counts of your organization's users, groups, and items are in sync. Following an upgrade, you may find that the index store values no longer match the index values. This indicates that the index store is out of date, and you must run a reindex.
An out of date index store will cause you to encounter issues when searching for content within your organization. Content that is missing when you search for it may be available elsewhere in your organization. You will still need to run a reindex for your organization to optimally function.
When values are out of sync, click the Reindex all button.
System storage
In this section, you can view and validate the health status of your organization's required storage.
The following are the data store types:
Object store—Storage for uploaded and saved content, hosted tile and image layer caches, and geoprocessing output.
Relational store—Storage for hosted feature data and administrative items such as customization and configuration settings. Two relational stores are configured: a primary and a standby.
Spatiotemporal and index store—Storage for logs and indexes as well as hosted feature data. If the status of the spatiotemporal and index store is unhealthy, logs will be inaccessible.
Next to each data store type, the health status for the pods is available. To refresh the status, click Validate. For more information about validating data store health, see Manage data stores
The number of dedicated pods for each storage type is determined by the availability profile chosen during deployment.
To determine the available storage or memory for each dedicated storage pod, expand the data store type. The memory size is predefined and cannot be scaled at this release. If the available storage space of the relational store and spatiotemporal and index store reaches the threshold limit, the stores will enter read-only mode and not accept new data.
Available storage and memory usage information is not available for cloud object stores. To help locate and manage storage on its dedicated platform, relevant information such as the service provider, defined region or storage domain, bucket or container name, and authentication type is available on this page.
System and utility services pods
System and utility pods provide the underlying framework to support your organization's workflows to share items such as maps, apps, and scenes; publish GIS services; and generate statistics and monitoring tools. In both the system and the utility services sections, you can verify the number of pods allocated to support these resources and determine whether any are unexpectedly low or unhealthy.
To increase or decrease the number of pods for system and utility services, use the settings on the Service deployments page. You can reallocate resources for the services in these pods on the Services page.
View deployment summary
The About this organization link gives you access to the following information about your ArcGIS Enterprise organization:
Version
Organization URL
Portal URL
Administrator API URL
Licenses
Federated ArcGIS Server sites
