Use custom web tools
Custom web tools are geoprocessing workflows that are published and hosted in your ArcGIS organization. Custom web tools can be added to supported apps, such as Map Viewer and Scene Viewer, and run from the Analysis pane.
Types of custom web tools
Custom web tools include the following item types:
Tool items
Geoprocessing Service items
Open and run custom web tools
Custom web tools can be opened and run in Map Viewer or Scene Viewer.
To access and use custom web tools, complete the following steps:
Open the Analysis pane by doing one of the following:
In Map Viewer, on the Settings (light) toolbar, click Analysis
.In Scene Viewer, on the Designer (dark) toolbar, click Analysis
If you do not see the Analysis button in Map Viewer, contact your organization administrator. Your organization may not be configured or you may not have privileges to perform spatial analysis, or your ArcGIS organization may not have any hosted feature layers (required to enable analysis).
For more information, see FAQ: Why don't I see the Analysis button in Map Viewer in Esri Community.
Click Tools
.Click Open custom web tool.
The Browse custom web tools window appears. By default, the window shows the custom web tools available in My content.
Optionally, click My content and choose My favorites, My groups, My organization, Living Atlas, or ArcGIS Online from the menu to change the source of the items.
Optionally, use the Search bar and Sort by menu to reduce the number of items or reorder the items.
On the desired item, click Select task, and choose a task from the menu.
An item may have multiple tasks associated with it.
You can also click the item to view the item details in a side pane.
Click Confirm.
The custom web tool opens in the Analysis pane.
Update the tool parameters.
Required parameters are marked with a red dot.
Tip:
Click the help icon next to a parameter to view the help, if available.
Click Environment settings to view and update the environments that are used during the processing.
Click Run.
Credits
Custom web tools published from ArcGIS Notebooks may consume credits. Credits are consumed when an analysis tool in the notebook uses ArcGIS Online services.
For more information, visit Understand credits for spatial analysis.
Outputs
Custom web tool outputs vary by tool. For information about the outputs for a specific custom web tool, see the tool description or contact the tool owner.
Some custom web tools create temporary output layers, such as feature collections, as part of their workflow. Temporary layers are only available within the web map where the layers were created until the map is closed, unless the layers are saved to create a hosted layer. The temporary layers will be permanently deleted if the web map is closed without saving the layers. Saving the web map will not save temporary layers.
Temporary layers are not currently supported as outputs in Scene Viewer.
Editing layers is not available for temporary layers. You can save the temporary layer to create a hosted feature layer to enable editing on the layer.
Temporary layers cannot be saved as part of a group layer item. If a custom web tool creates a temporary layer as part of a group layer, you can do one of the following:
Save the temporary layer individually before saving the group layer. The temporary layer will be replaced by a hosted feature layer when it is saved.
Ungroup the group layer or move the temporary layer out of the group and save the temporary layer individually. The temporary layer will be persisted in the web map once it has been saved and replaced with a hosted feature layer.
Temporary layers are indicated in the Layers pane using the following icon: ![]()
Save a temporary layer
To save a temporary layer, complete the following steps:
On the Contents (dark) toolbar, click Layers
if the Layers pane is not open.In the Layers pane, click Options
next to the layer you want to save, and click Save as
.Tip:
You can also save the layer by clicking Properties
, expanding the Information section, and clicking Save as
.Provide the following information for the new item:
A title.
Choose a folder in My content where you want to save the layer.
If your organization has set up content categories, choose categories to help people find the layer.
Tags and a summary that describe the layer.
Click Save.
The current layer properties are saved to a new item in My content. The new item becomes the source for the layer in the map.
Licensing requirements
Custom web tools require the following licensing and configurations:
Creator, Professional, or Professional Plus user type
Publisher or Administrator role, or an equivalent custom role
The Run web tools privilege is required to run custom web tools published from Notebooks.
Additional privileges may be required to run custom web tools published from Notebooks depending on which analysis tools are included in the notebook. For information about the privileges required to run an analysis tool, see the individual tool help.
Custom web tools created in Notebooks are hosted as tool items.
Troubleshooting
Use the sections below to troubleshoot potential issues when adding or running custom web tools.
Custom web tool fails to open
Custom web tools may fail to open in the following situations:
If a custom web tool fails to open from the Browse custom web tools window, the tool may be temporarily unavailable.
If a custom web tool fails to open from the tool history, the tool item may have been deleted or you no longer have permission to use the tool (for example, the item is no longer shared). Contact the tool owner for information about the tool status.
Unsupported parameter type
Some parameter types are not currently supported for custom web tools. If an unsupported parameter is marked as required and no default is set, the tool cannot be run. The following parameter types are not currently supported:
GPMultivalue:GPComposite
GPMultivalue:GPBoolean
GPMultivalue:GPDataFile
GPMultivalue:GPRasterDataLayer
Unsupported parameter configuration
Parameters using the GPValueTable parameter type do not support empty or duplicate parameter names. If an empty or duplicate name is used, the parameters will not be available in the web tool. Contact the tool owner to update the empty or duplicate parameter names.
Some parameter types, such as GPLinearUnit and GPDataFile, do not support default values stored as strings. If a string is used as the default, the value will be ignored and the tool pane will show no default value.
Unsupported output parameter configuration
Some web tools may be configured to create outputs that are not supported in Map Viewer, such as layers nested within GPValueTable results. These output layers will not be added to the web map when the web tools is run. Depending on the output type, the results may have been generated and saved in your content.
Custom web tools with no input parameters
Some custom web tools may not have input parameters. Custom web tools without input parameters have been configured to use a default input dataset and parameters that cannot be configured. Environment settings, such as Processing extent, can be used to customize the output of the tool. For information about the tool inputs and parameters, review the description on the item page or contact the item owner.
Parameters not repopulated when opened from history
Tool runs can be reopened from the analysis history. If a custom web tool has been updated since the tool was run, some parameters may not be repopulated to match the settings used when the tool was run. Updated parameters will not be populated in the following cases:
A parameter is added
A parameter is deleted
A parameter name is changed
A parameter type is changed
Resources
Use the following resources to learn more:
