Licensing requirements for spatial analysis
The organization administrator must grant you the required privileges to perform analysis. You must have the privileges to create, update, and delete content; publish hosted feature layers; and perform standard feature analysis.
The required privileges for feature and raster analysis are available through the following user types and roles:
  • Creator, Professional, or Professional Plus user type
  • Publisher or Administrator role, or an equivalent custom role
Raster analysis requires the user to be granted with a premium capability license and the organization be configured for raster analytics.
Additional privileges may be required for some tools. The tables below summarize the licensing requirements for all tools.
Summarize data tools
The following table summarizes the licensing requirements for tools in the Summarize data category:
Tool
Additional privileges or utility services
Aggregate Points
None
Join Features
Summarize Within
Summarize Center and Dispersion
Summarize Nearby
Network Analysis (required to use travel modes)
The following routing services are required to use travel modes:
  • Service Area (Asynchronous)
  • Routing utility service
Tabulate Area
None
Zonal Geometry as Table
Zonal Statistics
Zonal Statistics as Table
Find locations tools
The following table summarizes the licensing requirements for tools in the Find locations category:
Tool
Find by Attributes and Location
None
Find Centroids
None
Find Similar Locations
Create Viewshed
ArcGIS Online World Elevation service
Create Watersheds
ArcGIS Online Hydrology service
Trace Downstream
Choose Best Facilities
Network Analysis
The following routing services are required:
  • Location Allocation (Asynchronous)
Geocode Locations from Table
Geocoding privilege (required to perform geocoding using the ArcGIS World Geocoding Service)
Locate Regions
None
Enrich data tools
The following table summarizes the licensing requirements for the tool in the Enrich data category:
Tool
Enrich Layer
GeoEnrichment privilege
ArcGIS GeoEnrichment Service or a custom GeoEnrichment service
Analyze patterns tools
The following table summarizes the licensing requirements for tools in the Analyze patterns category:
Tool
Calculate Density
None
Interpolate Points
Calculate Composite Index
GeoEnrichment (required to use Esri population data)
ArcGIS GeoEnrichment Service or a custom GeoEnrichment service (required to use Esri population data)
Find Hot Spots
Find Outliers
Find Point Clusters
None
Calculate Density (raster analysis)
None
Interpolate Points (raster analysis)
Use proximity tools
The following table summarizes the licensing requirements for tools in the Use proximity category:
Tool
Calculate Travel Cost
  • Route (Asynchronous)
Create Buffers
None
Distance Accumulation
None
Distance Allocation
Optimal Path as Line
Optimal Path as Raster
Optimal Region Connections
Find Closest
  • Closest Facility (Asynchronous)
Generate Travel Areas
Network Analysis
Plan Routes
Network Analysis
  • Vehicle Routing Problem (Asynchronous)
Manage data tools
The following table summarizes the licensing requirements for tools in the Manage data category:
Tool
Convert Feature to Raster
None
Convert Raster to Feature
Nibble
Sample
Dissolve Boundaries
None
Extract Data
Generate Tessellations
Merge Layers
Overlay Layers
None
Analyze terrain tools
The following table summarizes the licensing requirements for tools in the Analyze terrain category:
Tool
Derive Continuous Flow
None
Derive Stream As Line
Derive Stream As Raster
Fill
Flow Accumulation
Flow Direction
Flow Distance
Geodesic Viewshed
Geomorphon Landforms
Stream Link
Surface Parameters
Watershed
Use deep learning tools
The following table summarizes the licensing requirements for tools in the Use deep learning category:
Tool
Classify Objects Using Deep Learning
None
Classify Pixels Using Deep Learning
Detect Change Using Deep Learning
Detect Objects Using Deep Learning
Use multidimensional analysis tools
The following table summarizes the licensing requirements for tools in the Use multidimensional analysis category:
Tool
Aggregate Multidimensional Raster
None
Find Argument Statistics
Generate Multidimensional Anomaly
Generate Trend Raster
Multidimensional Principal Components
Predict Using Trend Raster
Summarize Categorical Raster
Custom web tools
Custom web tools require the same user type and privileges as spatial analysis.
Custom web tools published from ArcGIS Notebooks also require the Run web tools privilege and any privileges required to run the individual tools in the notebook. The Run web tools privilege is included with the Administrator role.
Custom web tools created in Notebooks are hosted as tool items.
Learn more about custom web tools
Resources
Use the following resources to learn more:
