Use URL parameters to create and modify maps
A map authored in ArcGIS Enterprise contains a basemap; data layers; an extent; a legend; and navigation tools such as zoom, pan, place finders, and bookmarks. Many maps also contain interactive elements such as a basemap gallery, measure tools, pop-ups, and buttons for playing data over time.
In addition to creating maps with Map Viewer, you can create and modify maps directly with URL parameters.
For example, you can construct a map with URL parameters that shows biomes and ecoregions.
myportal.example.com/arcgis/apps/mapviewer/index.html?basemapUrl=https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer&url=https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/Resolve_Ecoregions/FeatureServer
For example, you can use a map viewer URL in the following circumstances:
If you don't need to include a lot of reference or operational layers and you don't need to apply specific styles to the map's content, use a URL to open one of the map viewers. For example, if your website allows people to look up an address or view a single layer related to your site, you can include a link in the website that opens Map Viewer with the specified basemap and the single layer required.
You need to link to a saved web map from a website or email. You can use a URL that opens the specific web map.
What to include in the URL
The URL always begins with the fully qualified ArcGIS Enterprise name and web adaptor or load balancer context, plus apps/mapviewer/index.html? and one or more of the query parameters listed below. To include more than one parameter, use an ampersand (&) to separate the parameters. You'll find examples of using multiple parameters throughout this page.
See the following example:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?center=20,45&level=8
If any of the resources in the URL parameter are provided as HTTP, the URL for the map must also be HTTP. For added security, use an HTTPS URL if possible.
Encode the query parameters
All query parameters must be encoded. URL encoding ensures that valid characters are sent to the portal. Encoding replaces invalid characters with % followed by their hex equivalent.
For example, here is an unencoded URL parameter:
basemapUrl=https://myportal.example.com:7443/arcgis/rest/services/Ocean/World_Ocean_Base/MapServer
Here is the same parameter encoded:
basemapUrl=https%3A%2F%2Fservices.arcgisonline.com%2FArcGIS%2Frest%2Fservices%2FOcean%2FWorld_Ocean_Base%2FMapServer
Parameters within parameters must also be encoded, for example:
urls=https%3A%2F%2Fmyportal.example.com:7443%2Farcgis%2Frest%2Fservices%2Fweb_mercator%2Ftrackline_gravity%2FMapServer%2Chttps%3A%2F%2Fmaps.ngdc.noaa.gov%2Frest%2Fservices%2Fweb_mercator%2Fhazards%2FMapServer%3Flayers%3Dshow%3A5%2C6
The internet has many free sites and tools for generating encoded URLs. For readability, the rest of the examples in this topic are not encoded.
Open a saved map
To open a saved map created with Map Viewer, use webmap= and the unique ID of the map.
In this example, a web map with an ID of 75a3ce8990674a5ebd5b9ab66bdab893 will open in Map Viewer:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?webmap=75a3ce8990674a5ebd5b9ab66bdab893
In this example, a web map with an ID of 29990ur6423j1180p53f9t30019491 will open in Map Viewer with the extent set to -117.996342,33.841078,-117.993692,33.844375:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?webmap=29990ur6423j1180p53f9t30019491&extent=-117.996342,33.841078,-117.993692,33.844375
Define the basemap
To define the basemap, set basemapUrl= to the layer. If a basemap is not defined, the default basemap, World Topographic basemap, is used.
In this example, Map Viewer opens with OpenStreetMap used as the basemap:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?basemapUrl=https://basemaps.arcgis.com/arcgis/rest/services/OpenStreetMap_v2/VectorTileServer&layers=9e2f2b544c954fda9cd13b7f3e6eebce
In this example, Map Viewer opens with the World physical map used as the basemap and an operational layer with item ID 9e2f2b544c954fda9cd13b7f3e6eebce present in the map:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?basemapUrl=https://services.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer&layers=9e2f2b544c954fda9cd13b7f3e6eebce
Include a reference layer
To include a reference layer with the basemap, set basemapReferenceUrl= to the layer. The basemapReferenceUrl= parameter must be used in addition to the basemapUrl parameter.
In this example, Map Viewer opens with the World Imagery basemap layer and the reference layer set to the World Boundaries and Places layer:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?basemapUrl=https://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer&basemapReferenceUrl=https://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer
Define the operational layers
To define the operational layers that overlay the basemap, use webmap=, layers=, layerIds=, url=, or urls=. If the layer is an item in the website, use layers= so you get all the layer configurations. To add individual sublayers from a feature layer that contains multiple sublayers, use layerIds=. If the layer isn't in the website, use url= or urls=.
The layers= parameter accepts a single item ID or multiple item IDs. For multiple layers, use a comma-separated list of IDs (&layers=<itemID>,<itemID>,<itemID>).
https://myportal.example.com/arcgis/apps/mapviewer/index.html?webmap=8152694dd9594393a1db4d62d2020fe3&layers=9e2f2b544c954fda9cd13b7f3e6eebce,dece90af1a0242dcbf0ca36d30276aa3
The layerIds= parameter accepts a single layer ID or multiple layer IDs. If a feature layer contains multiple sublayers, use the layerIds= parameter to add individual sublayers. For multiple sublayers, use a comma-separated list of IDs (&layerIds=0,1,2).
https://myportal.example.com/arcgis/apps/mapviewer/index.html?layers=025063719c32408dbd4fb608faa28d2a&layerIds=0,2
The url= parameter accepts a single layer URL.
https://myportal.example.com/arcgis/home/webmap/viewer.html?
url=https://services.myportal.example.com:7443/arcgis/rest/services/Demographics/USA_Population_Density/MapServer
Use urls= to include more than one layer. Separate layers with a comma. The map extent is based on the last layer in the list or the slowest one to load. To zoom to a specific extent, include the extent= parameter.
https://myportal.example.com/arcgis/apps/mapviewer/index.html?urls=https://services9.arcgis.com/RHVPKKiFTONKtxq3/arcgis/rest/services/NOAA_METAR_current_wind_speed_direction_v1/FeatureServer,https://services9.arcgis.com/RHVPKKiFTONKtxq3/arcgis/rest/services/NOAA_storm_reports_v1/FeatureServer?layers=show:4&extent=-108,31,-85,40
As of ArcGIS 10.5, you can use the ?layers operation on a feature service.
https://myportal.example.com/arcgis/home/webmap/viewer.html?url=https://sampleserver6.arcgisonline.com/arcgis/rest/services/RedlandsEmergencyVehicles/FeatureServer?layers=show:1,2
Define the scale level and center the map
Scale is automatically set for a map in Map Viewer when you use the webmap or find parameter. If you use the webmap parameter, the map is automatically zoomed to the full extent of the map, unless other URL parameters such as level and center or extent are used to override the web map scale. If you use the find parameter, the map is automatically zoomed to the best extent of the found location.
To define a specific scale level, use the center and level parameters. The level parameter accepts the level ID of the cache scale as listed in the REST service endpoint of the tiled basemap. The resolution is inversely related to the scale. The level parameter is only supported for tiled basemaps, not for basemaps created from dynamic map services and other nontiled data.
To center the map at a particular location, set center using geographic coordinates (x,y) or projected coordinates (x,y,WKID). You can use commas or semicolons as separators. Use semicolons if your numbers use commas as their decimals.
The level and center parameters must be used together. The level parameter is ignored if it's used on its own.
See the following geographic coordinates example:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?center=20,45&level=4
See the following projected coordinates example:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?center=500000,5500000,102100&level=4
Define the extent
To define the extent of the map, use extent. The extent parameter accepts geographic coordinates (GCS) as MinX,MinY,MaxX,MaxY or projected coordinates (PCS) as MinX,MinY,MaxX,MaxY,WKID. You can use commas or semicolons as separators. Use semicolons if your numbers use commas as their decimals.
https://myportal.example.com/arcgis/apps/mapviewer/index.html?extent=-117.20,34.055,-117.19,34.06
https://myportal.example.com/arcgis/apps/mapviewer/index.html?extent=-13079253.954115,3959110.38566837,-12918205.318785,4086639.70193162,102113
Set the layer visibility
To set the visibility of sublayers for a layer that you open in the map, use layers=show:.
In this example, sublayer 3 is visible but other sublayers are not visible:
https://myportal.example.com/arcgis/home/webmap/viewer.html?url=https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/BLS_Monthly_Unemployment_Current_14_Months/FeatureServer?layers=show:2&find=Pennsylvania
Find a location or feature to open the map
To find a location or feature immediately upon opening the map, use find. The map is automatically zoomed to the closest match and a callout marker is added to the map. The find parameter accepts single-line addresses, partial addresses (such as city only or country only), place-names, and longitude-latitude coordinates.
The following example uses a single-line address in Map Viewer:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?find=380 new york st,redlands,ca
Tip:
To find a location or feature in a searchable layer, include the webmap= parameter with the unique ID of the map.
Add a point
To add a point to the map, use marker=<x>,<y>. You can also include the following optional properties:
<wkid>—Spatial reference of the x,y coordinates to be added to the map. If you do not include a WKID, GCS coordinates are used.<encoded title>—Title of the point pop-up. If you do not include a title, the pop-up will be empty.<encoded icon URL>—Symbol for the point. If you do not include a symbol, a blue marker symbol is used.<encoded label>—Label next to the point symbol.
Example
The following example uses semicolon separators:
https://myportal.example.com/arcgis/home/webmap/viewer.html?marker=-79.234826;38.147884;;Race start and finish;;Grindstone 100 Ultra Marathon&level=7
Considerations
Keep the following in mind when adding a point to a map:
The
<x>,<y>coordinates are required to add a point.You must encode the
title,icon, andlabelparameters.You must add properties in this order:
marker=<x>,<y>,<wkid>,<encoded title>,<encoded icon URL>,<encoded label>.You can use commas or semicolons as separators. Use semicolons if your numbers use commas as their decimals.
Use empty values. Do not use spaces. For example, to specify a label and no other optional properties, add the label as the sixth parameter with empty values for the others (
x;y;;;;label).If you want the map to zoom in (in addition to centering on the point), include the
levelparameter.You can edit and save the map notes layer as a map or item.
Organizational accounts can use the point to get directions and perform analysis.
Hide the Contents and Settings toolbars
To hide the Contents (dark) and Settings (light) toolbars in Map Viewer, use mapOnly=true. Click Show interface
to show the toolbars in the map view.
The following example uses the mapOnly=true parameter:
https://myportal.example.com/arcgis/apps/mapviewer/index.html?webmap=29990ur6423j1180p53f9t30019491&mapOnly=true
