Generate encrypted passwords
Before deploying and configuring ArcGIS Enterprise on Kubernetes silently, it is recommended that you use the password-encrypt.sh tool to generate an encrypted string that can be used as input in the deploy.properties and configure.properties files.
Run the password-encrypt.sh tool
The password-encrypt.sh tool can be run interactively or silently. It encrypts a user-generated password and outputs it as an encrypted string using AES-256 encryption.
The client workstation used to run this tool must be in accordance with supported environments.
To run the tool, two inputs are required:
  • The path to your plain text keyfile
  • A specified password to encrypt
To run the tool, do the following:
  1. On your Kubernetes client machine, open a terminal as an administrator.
  2. Using a local or shared network path, create a text file, for example, one named keyfile.txt.
  3. Edit the keyfile.txt file to contain plain text that will be converted to an encrypted string.
    Do not enter sensitive information in this file.
  4. Save the file.
  5. Run the password-encrypt.sh tool interactively or silently.
  6. Add the encrypted string to each properties file before you run the deployment script and create an organization.
