System requirements
This page lists the minimum hardware and infrastructure required to run ArcGIS Enterprise on Kubernetes when deploying in either a connected environment or a disconnected environment.
Supported environments
System requirements and specifications apply across all supported environments except where noted. For this release, the following environments are supported:
ArcGIS Enterprise on Kubernetes is only supported on CPUs that adhere to the x86_64 architecture (64 bit). Worker nodes must be Linux based.
It is recommended that you disable auto-upgrade in your Kubernetes cluster. When your cluster is enabled with auto-upgrade, the nodes will automatically be updated with the latest version of Kubernetes and these future versions may not yet be supported for ArcGIS Enterprise.
Caution:
To ensure full compatibility and support, confirm that your Kubernetes version falls within the supported range before upgrading ArcGIS Enterprise on Kubernetes.
The following versions for each environment have been tested and are supported:
Supported Kubernetes version
Managed Kubernetes services on the cloud (AKS, EKS, GKE)
Red Hat OpenShift (self-managed Kubernetes engine, ROSA, and ARO) [4.20-4.21]
RKE2
VMware Tanzu
1.33 - 1.35
Container registry
Container images for ArcGIS Enterprise on Kubernetes are accessible from a private Docker Hub organization. Esri will provide access to this organization's repositories to those who are deploying ArcGIS Enterprise on Kubernetes.
When using your organization's container registry, you will need to prepare it with the Esri images. This is required when deploying in a disconnected environment.
Obtain an Esri license
To authorize your ArcGIS Enterprise organization during deployment, you need an ArcGIS Enterprise on Kubernetes license file in JSON format (.json file). To obtain this license file, visit My Esri with privileges to take licensing action.
Worker nodes
It is recommended that each worker/agent node have a minimum of 200 GiB root disk size. Work with your cluster administrator to increase the system resources for worker/agent nodes if necessary.
The pods in the ArcGIS Enterprise on Kubernetes deployment are distributed across the worker nodes in the cluster. The worker node clocks must be synchronized to a common source so that times are consistent within the cluster.
When scaling the deployment or adding another ArcGIS Enterprise deployment to the cluster, you need to provision nodes accordingly. This may require an increase in the default maximum number of pods per node.
Resource requirements
The total amount of CPU and memory required for ArcGIS Enterprise on Kubernetes depends on the number of pod replicas and the resource requests and limits set for those pods.
If you are upgrading an existing organization to this release, overall resource requirements are based on the number of pod replicas and resource requests and limits you have configured. If your current resource allocation is enough to meet your needs, you can use that same level of resource allocation after upgrading.
For new deployments, the initial resource requirements depend on the selected architecture profiles. The following table lists the minimum resource requirements to install the software and configure a new organization. You may need to allocate additional resources beyond these minimum values to support scaling workloads and enabling capabilities in your organization.
Standard performance
Enhanced performance
Development and test environments
  • 56 vCPU
  • 111 GiB memory
  • 84 vCPU
  • 135 GiB memory
Standard high availability
  • 74 vCPU *
  • 153 GiB memory
  • 104 vCPU
  • 182 GiB memory
Enhanced high availability
  • 99 vCPU
  • 204 GiB memory
  • 140 vCPU
  • 230 GiB memory
* The default pod configuration for a combination of standard high availability and standard performance is covered by your license.
The number of nodes required to meet these requirements depends on the node size. For example, using a node size of 8 vCPU and 32 GiB of memory, a combination of standard performance and standard high availability would require a minimum of 10 nodes. Using nodes with 16 vCPU and 32 GiB of memory would require a minimum of 5 nodes for this same combination of profiles.
When integrating with cloud services for the object or relational stores, the application resource requirements are reduced by the following amounts, depending on availability profile:
Architecture profile
Object store
Relational store
4 vCPU/ 64 GiB
1 vCPU/ 4 GiB
1.5 vCPU/ 24 GiB
1 vCPU/ 4 GiB
0.5 vCPU/ 8 GiB
1 vCPU/ 4 GiB
Security
The following sections describe the security requirements for ArcGIS Enterprise on Kubernetes.
Role-based access control
Role-based access control (RBAC) must be enabled on the Kubernetes cluster. To deploy ArcGIS Enterprise on Kubernetes, you do not need cluster-admin privileges. If you do not have cluster-admin privileges, you must have at least namespace administrative privileges. You can assign the user a default ClusterRole by creating a RoleBinding in the namespace. For more information, review the RBAC role resource.
SELinux support
The Security-Enhanced Linux (SELinux) module is supported on worker nodes running ArcGIS Enterprise on Kubernetes. Because the default policy of SELinux may prevent ArcGIS from reaching internal components, administrators may need to modify the SELinux policy. To do so, temporarily set the SELinux policy mode to permissive. This will record the violations of the policy, such as actions taken by ArcGIS to access internal resources, but will allow them to occur. Administrators can note these violations and modify the SELinux policy configuration to allow them before resetting the policy mode to enforced.
Register a data folder
To publish items using file-based data, such as items published from a file geodatabase on a network share, collections of cache tiles, or locators, you can host the data in an NFS shared location or add a PV-based folder data store. To ensure that GIS and system services can access the shared location as appropriate, the user and group ID for the running service pods or others directory permissions must provide read access to the share, its subdirectories, and the files contained within it. After registering this folder data store with the organization, you can avoid the need to copy data to the organization during publishing. For NFS servers, you can manage security at the network or infrastructure level by only allowing network access to the pod IP range for the export.
Network
Network requirements include a fully qualified domain name (FQDN) and a load balancer or reverse proxy that directs traffic from clients over the standard HTTPS port (443) to the configured back-end targets. Details for each are provided below.
Fully qualified domain name
ArcGIS Enterprise on Kubernetes requires a FQDN (for example, map.company.com). You can use an existing domain name system (DNS) service to create a CNAME or A record, or integrate with a cloud provider's DNS service such as Amazon Route 53. You can create the DNS record after deployment; however, the FQDN must be provided during the deployment process. At this release, the FQDN cannot be modified after deployment.
The AWS Load Balancer Controller add-on is required to create either a Network or Application Load Balancer for an Amazon EKS cluster.
Load balancer
You can use a load balancer to direct traffic to your ArcGIS Enterprise on Kubernetes deployment. You can provision both layer 4 and layer 7 load balancers from the deployment script without manual configuration. Load balancers that are integrated with your deployment from the deployment script route traffic to the in-cluster NGINX ingress controller pod directly.
Alternatively, you can use ArcGIS Enterprise on Kubernetes Web Adaptor to route traffic to your deployment, which requires that incoming traffic be sent to the deployment's worker nodes on a specific port.
The following layer 4 load balancers can be provisioned from the deployment script without manual configuration:
  • Azure Load Balancer (public or internal)—A preprovisioned static public IP address and DNS label can be specified in the deployment script.
  • AWS Network Load Balancer (internet-facing or internal)—Custom annotations can be used to customize the load balancer when deploying silently. See the custom ingress annotations section of additional silent deployment properties for more information.
  • Google Cloud Platform TCP Load Balancer (internet-facing or internal)—A preprovisioned static public IP address can be specified in the deployment script.
  • Generic load balancer—Supports layer 4 solutions like MetalLB, Traefik, HAProxy, and others that an organization may already be familiar with operating in their on-premise infrastructure. When using a managed cloud provider's Kubernetes cluster, the corresponding integrated cloud option should be chosen, while for self-managed clusters, the generic load balancer option appends any annotations defined in the deployment properties file as custom annotations.
The load balancers specified above can be customized using annotations on the underlying Kubernetes Service object. For example, you can enable cross-zone load balancing on a Network Load Balancer in AWS or place an Azure Blob Load Balancer into a specific resource group. The deploy.properties template file included with the deployment script contains examples of how these annotations can be specified during silent deployment.
The deployment script can be used to employ layer 7 load balancing capabilities such as a web application firewall or to meet organization requirements for ingress to the deployed application using a pre-existing ingress controller. The following layer 7 load balancers can be deployed or integrated directly from the deployment script:
  • AWS Application Load Balancer
  • Azure Application Gateway
  • Google Cloud Platform Application Load Balancer
Red Hat OpenShift provides Routes, which is an integrated construct to direct traffic from external clients to services that exist within the cluster. This option requires an administrator to create the Route outside of the deployment script as the properties may vary based on organizational requirements. The Route object can be created from the console or from a YAML and should use end-to-end TLS encryption to proxy traffic to the bundled ingress controller, but it can use passthrough or re-encryption mode.
An ingress controller implemented at the cluster-level will use these load balancers to implement cluster-level Ingress rules to route incoming traffic to an ArcGIS Enterprise on Kubernetes deployment. To implement these load balancers from the deployment script prior to silently deploying, you can modify a template YAML file in the layer-7-templates folder, save it to your client workstation, and specify this location for the CLUSTER_INGRESS_CONTROLLER_YAML_FILENAME parameter. See Cluster-level ingress controllers for more information.
To support notebook services, any external reverse proxies or load balancers must be able to pass websocket traffic to the backend targets and have requirements set so that sessions remain open for 10 minutes.
When using a self-managed load balancer or reverse proxy such as NGINX, the X-Forwarded-Host header must be set to the Host header value of the client-facing URL to ensure that traffic is properly routed to your ArcGIS Enterprise organization's URL. In NGINX, this can be achieved using the following directive: proxy_set_header X-Forwarded-Host $host;.
ArcGIS Enterprise does not support SSL offloading through a reverse proxy/load balancer. If your configuration uses a reverse proxy, it must redirect to either the ArcGIS Web Adaptor or directly to the organization over HTTPS.
IP requirements
Planning your cluster network in advance is essential for ensuring a successful deployment, appropriate scaling requirements, and the ability to upgrade. The number of pods that ArcGIS Enterprise on Kubernetes deploys initially depends on its availability profile. The number of pods will increase as additional capabilities are added, the deployment is scaled, and during the upgrading process.
Each pod is assigned a unique IP address, and depending on the cluster network configuration, pods can either get their IP addresses from a logically different address space from that of the host network (an overlay network) or from the host subnet. For example, if you configure your cluster to use Kubenet in Azure (default), pods will receive an IP address from a logically different address space and will be able to reach Azure resources using NAT.
Kubernetes supports Container Network Interface (CNI) and platforms such as AKS and EKS, which use platform-specific CNI plug-ins for cluster networking. For example, EKS clusters use Virtual Private Cloud (VPC) CNI by default. If the cluster is configured with a CNI plug-in, pods will receive IP addresses from the host subnet and a corresponding pool of IPs available in the VPC/VNet.
If you do not have a sufficient number of IPs available in the host subnets, the deployment will either fail, or you will not be able to scale the deployment. For example, if an EKS cluster is configured with two subnets each and a /26 IPv4 address prefix (64 available IPv4 addresses each), there cannot be more than 126 IP addresses available for the pods. While you may be able to deploy ArcGIS Enterprise on Kubernetes in this cluster, you will not be able to scale the deployment to have 80 feature service pods, as this scaling requirement will exceed the number of IP addresses available.
System storage
ArcGIS Enterprise on Kubernetes requires persistent volumes (PVs) for system storage, which can be provisioned dynamically through a storage class or statically by an administrator prior to creating the organization. Learn more about static provisioning and dynamic provisioning.
Stateful workloads of ArcGIS Enterprise include relational database management systems and NoSQL databases. It is recommended that you provision PVs on block storage devices that provide low latency, such as EBS volumes when using EKS, Azure Disks when using AKS, Persistent Disks when using GKE, and vSphereVolume or Longhorn volumes when deploying to self-managed clusters.
Because these PVs store your organization's data and settings, you must protect them using restrictive security policies. For PVs based on network file storage, such as NFS, Azure Files, and GlusterFS, ensure that the permissions are set to prevent unauthorized access. For block storage, such as EBS, Azure Disk, vSphereVolume, and Longhorn volumes, ensure that access to the storage volumes is restricted to only those users who need it.
The following are descriptions of storage volumes and their intended purpose:
  • In-memory—Stores temporary system resources.
  • Item packages—Stores large uploads and packages to support publishing workflows.
  • Object—Stores uploaded and saved content, hosted tile, image, and scene layer caches, and geoprocessing output.
  • Queue—Stores asynchronous geoprocessing jobs.
  • Relational—Stores hosted feature data and administrative aspects such as customization and configuration settings. Two are required for deployment.
  • Spatiotemporal and index—Stores logs and indexes as well as hosted feature data.
  • Usage metric data—Stores GIS service usage data.
Consider the storage requirements for your organization and define the size for each PV accordingly.
Client workstation
The deployment scripts are bash scripts that can be run from a remote client workstation. You must run the scripts as a user with read and write access for the scripts to write temporary resource files to subdirectories.
The following operating systems are supported to run the deployment script, configure script, and other packaged scripts and tools:
Supported operating system
Latest update or service pack tested
Red Hat Enterprise Linux Server 8
Update 10
Red Hat Enterprise Linux Server 9
Update 7
AlmaLinux 8
Update 10
AlmaLinux 9
Update 7
SUSE Linux Enterprise Server 15
Service Pack 7
Ubuntu Server 24.04 LTS
24.04.4
Ubuntu Server 22.04 LTS
22.04.5
Oracle Linux 8
Update 10
Oracle Linux 9
Update 7
Rocky Linux 8
Update 10
Rocky Linux 9
Update 7
Client workstations are tested with these operating systems installed as native Linux systems, not as subsystems or containerized environments. While other untested shell environments, Linux compatibility layers, or operating systems may work, unforeseen issues may arise when deploying and configuring the organization. If you encounter an issue with an environment, it is recommended to provision a client workstation that matches an environment listed above.
You need the following when setting up your client workstation (download links are provided):
  • Kubectl
  • An environment-specific command line interface (CLI)
Kubectl is a prerequisite to run the deployment script. Use Kubectl installation and setup to download a version of the Kubernetes command line tool compatible with the Kubernetes version of your cluster.
When managing your deployment, you can use environment-specific command line tools. Use the following links to download an environment-specific CLI:
TLS certificate
ArcGIS Enterprise on Kubernetes uses an NGINX-based ingress controller. This ingress controller is namespace scoped and is deployed to listen to only ingress traffic for the ArcGIS Enterprise namespace. A Transport Layer Security (TLS) certificate is required with the FQDN in the certificate common name and subject alternate name. Either a CA-signed certificate or a self-signed certificate can be used; however, for security reasons, a CA-signed certificate is recommended. This is the default TLS certificate for the ingress controller.  The following certificate options are available in the deployment script to apply a TLS certificate for ingress traffic:
  • An existing TLS secret that contains a private key and certificate
  • A .pfx file that contains a private key and certificate
  • A PEM-formatted private key and certificate
  • A self-signed certificate
ArcGIS Enterprise on Kubernetes supports using a TLS certificate for the ingress controller that is issued and managed by Kubernetes cert-manager. This certificate must be stored in a TLS secret in the same namespace as ArcGIS Enterprise. The TLS secret can then be referenced either during deployment or after the ArcGIS Enterprise organization is created.
ArcGIS Pro
  • ArcGIS Pro 3.7 is the companion release for ArcGIS Enterprise 12.1 on Kubernetes. To benefit from the latest features available, use ArcGIS Pro 3.7.
  • To publish services to ArcGIS Enterprise on Kubernetes, ArcGIS Pro 2.8 or later is required.
  • To consume services from ArcGIS Enterprise on Kubernetes, ArcGIS Pro 2.7 or later is required.
When registering a data store item from an enterprise geodatabase, the geodatabase version must be 10.9.0.2.8 or later.
For more information, review Client and geodatabase compatibility.
ArcGIS Enterprise on Kubernetes Web Adaptor can be integrated with either an IIS web server on Windows or a Java web server on Windows or Linux. See the ArcGIS Enterprise on Kubernetes Web Adaptor system requirements for specific prerequisites and version requirements.
