Review the deployment process
Steps to deploy ArcGIS Enterprise on Kubernetes vary depending on your environment. Before deploying, review these steps.
Deploy in a connected environment
When your organization is connected to the internet, steps to deploy include the following:
  1. Confirm that your system meets the minimum system requirements.
  2. Consider cloud service integration options for your organization.
  3. Select the architecture profiles that meet your organization's requirements.
  4. Obtain an authorization file for ArcGIS Enterprise on Kubernetes.
  5. If you are not deploying to an existing cluster, set up a Kubernetes cluster. For guidance on deploying a cluster in each supported Kubernetes platform, see the following:
  6. Prepare the cluster for deployment.
  7. Provide all nodes in your cluster access to registered GIS data folders to be used in publishing workflows across the organization.
    When creating the organization, you can register these paths.
  8. Run the deployment script.
  9. If you're not using a preconfigured load balancer with a static IP and Domain Name System (DNS) record assigned, create a DNS record to access your cluster.
  10. Use the setup wizard or configure.sh script to create an ArcGIS Enterprise organization.
  11. Configure authentication to define how users will sign in to ArcGIS Enterprise on Kubernetes.
    If you plan on using web-tier authentication, you will need to install and configure ArcGIS Enterprise on Kubernetes Web Adaptor as part of this step.
Deploy in a disconnected environment
When your organization is disconnected from the internet, steps to deploy include the following:
  1. Confirm that your system meets the minimum system requirements for a disconnected environment.
  8. Populate your container registry with Esri container images.
  9. Run the deployment script.
  10. If you're not using a preconfigured load balancer with a static IP and Domain Name System (DNS) record assigned, create a DNS record to access your cluster.
  11. Use the setup wizard or configure.sh script to create an ArcGIS Enterprise organization.
  12. Use the create-offline-manifest.sh tool to download the Esri-published version manifest file and import it into your organization.
  13. Configure authentication to define how users will sign in to ArcGIS Enterprise on Kubernetes.
  14. Configure the organization by disabling external content, setting your own basemap gallery, and so on.
