ArcGIS Enterprise software setup guide
Before installing ArcGIS Enterprise, it's important to understand prerequisites for and what's included in a base deployment. Additionally, learn how to deploy or upgrade it and extend functionality and capacity by adding capability-based servers and extensions.
ArcGIS Enterprise servers
Beyond the functionality that's available in a base deployment, additional servers can be added to extend functionality to your organization. With the exception of the ArcGIS GIS Server, each added server is optional and licensed separately from the base deployment.
Deployment options
Esri offers several methods you can use to deploy ArcGIS Enterprise such as ArcGIS Enterprise Builder, cloud deployment tools, and script-based tools. Each method has advantages and intended uses. To learn more, review the ArcGIS Enterprise Functionality Matrix and ArcGIS Enterprise deployment methods.
Get started
Before installing ArcGIS Enterprise components, be sure to review and meet system requirements. When you're ready to begin downloading licenses and components, visit My Esri.
Review and meet prerequisites
Keep the following prerequisites in mind:
Ensure your infrastructure meets the system requirements for each ArcGIS Enterprise component.
Administrative privileges are required for installation.
For Windows environments, Microsoft .NET 10 is required to install the ArcGIS Server .NET Extension Support feature.
Review the ArcGIS Web Adaptor (IIS) system requirements for the latest requirements.
You can install a base deployment across one or more machines, any of which can be physical, virtual, or cloud machines.
Setup temporary storage
During setup, if the required space is not available in the /tmp directory, the setup program will attempt to extract resources to the user's HOME directory. If the required space is not available in the user's HOME directory, the setup program will report an error. During installation, if more space is needed for installed resources than is available in the default /tmp directory, you can specify an alternate setup temp location by setting the IATEMPDIR environment variable to a larger directory.
Obtain licenses and downloads from My Esri
Visit My Esri with privileges to take licensing action.
Under My Esri > Licensing > License Esri Products, select Start Licensing to begin the process of obtaining your licenses.
Select ArcGIS Enterprise and the version of the software you want to license.
Proceed through the steps to generate license files for ArcGIS Server and Portal for ArcGIS, including your added servers, user types, and applications, as applicable. For the Portal for ArcGIS license file, provide your ArcGIS Enterprise organization URL. See Organization URL for more information about how this URL can be determined in your environment.
Download your license for each ArcGIS Enterprise component, server, and extension as applicable.
Language packs
Language packs are separate and optional setups that are available as help language packs and resource language packs.
Help language packs
Help language packs can be used to view installed documentation in additional languages. Help language packs are available in the following setups:
ArcGIS Server
Portal for ArcGIS
ArcGIS Data Store
ArcGIS Data Pipelines Server
ArcGIS Notebook Server
ArcGIS Mission Server
ArcGIS Velocity
ArcGIS Video Server
Resource language packs
Resource language packs can be used to localize log messages and capabilities in additional languages.
Upgrades
When performing an upgrade of ArcGIS Enterprise, consider the following:
The ArcGIS setup packages are designed to detect and upgrade an existing installation of the same ArcGIS product. The settings for the installation location are retained in the upgrade. See Upgrade ArcGIS Enterprise for more information.
If you are upgrading from a version from an earlier release series, you must obtain a new portal license file from My Esri.
