Configure servers
Once you have federated a server site with your organization, you can manage the server site from your organization's Settings page. You can perform actions such as configuring a server role, updating the alias, viewing licenses, and validating the server site.
To manage a server site, do the following:
Sign in to your ArcGIS Enterprise organization as a member with the administrative privileges to manage server settings.
You must connect to the website through the Web Adaptor URL (such as
https://webadaptorhost.example.com/webadaptorname/home). Do not use the internal URL on port 7443.Click Organization at the top of the site and click the Settings tab.
Click Servers on the left side of the page.
The following sections describe the management options available for federated server sites.
Configure server role
Configure a server role on a federated server site to make server capabilities available in your organization.
To configure a server role, locate the site in the federated server sites list and open the Configure server role window by doing one of the following:
Next to Server role, click the current server role or Configure server role if no role is currently assigned.
Click the More options button
and select Configure server site.
Once the Configure server role window is open, use the toggle buttons to select the roles you want to configure or remove for your federated server site. You can configure multiple server roles on a server site as long as it meets the requirements for each role. If requirements are not met, click Requirements missing for more information or review the requirements in the table below. Click Save to configure or remove the selected server roles.
A hosting server is required for an ArcGIS Enterprise base deployment. For steps and requirements, see Configure a hosting server.
After configuring a base deployment, you can configure additional server roles for your organization. Review the available server roles below and use the links for detailed configuration instructions.
| Server role | Server license | Additional requirements |
| Raster Analysis Server | ArcGIS Image Server | A raster store must be configured with the server site. |
| Image Hosting Server | ArcGIS Image Server | A raster store must be configured with the server site. |
| Notebook Server | ArcGIS Notebook Server | |
| Mission Server | ArcGIS Mission Server | |
| Workflow Manager Server | ArcGIS Workflow Manager Server | |
| Knowledge Server | ArcGIS Knowledge | A graph store must be configured with the server site. |
| Data Pipelines Server | ArcGIS Data Pipelines | |
| Video Server | ArcGIS Video Server | |
| Reality Server | ArcGIS Reality Server | A raster store must be configured with the server site. |
A server site licensed with ArcGIS Velocity is automatically configured as a Velocity site when it is federated with the organization. No server role configuration is required.
Edit server name
You can provide a user-friendly alias to help identify your federated server site by clicking the Edit button
next to the server name and entering a new name. Click Save to update the server name.
This name is used for display purposes only and updating it will not modify the URLs associated with your server site.
View licenses
You may view the licensed roles, extensions, and associated expiry dates authorized on a server site. Click the More options button
and select View licenses.
Validate server site
You can validate a server site to verify the status of your server. Click the More options button
and select Validate server site. You can also validate all federated server sites by clicking the Validate server sites button above the list of servers. A general status message appears in the Status row for the server sites being validated. Hover over the status message to view additional information.
