Deploy an ArcGIS Reality Server site
For members of your organization to use reality service tools in ArcGIS Enterprise, you must set up a base ArcGIS Enterprise deployment, a reality server and raster store. ArcGIS Reality Server does have image hosting capabilities to serve its results but we recommend having a dedicated Image Server to handle the creation and sharing of image services for better performance.
Review the best practices for setting up a reality server
The following instructions may require changes to the way you've deployed ArcGIS in your organization; review them carefully before proceeding.
Create an ArcGIS Reality Server site
Install ArcGIS Server authorized with Reality Server license.
After authorization is complete, ArcGIS Server Manager opens automatically, otherwise, find and open
ArcGIS Server Managerapp on the machine.Sign in to ArcGIS Server Manager and create a site.
If your Reality Server site requires multiple machines, install ArcGIS Server on each additional machine, authorize each installation with Reality Server license and join them to the Reality Server site.
Install Reality server runtime on each of the Reality Server machines.
Install and configure ArcGIS Web Adaptor for the Reality Server site.
Register a raster store with ArcGIS Reality Server.
Reality services store processed rasters in a data store, referred to as raster store. This can be either of the following:
Cloud store with enterprise geodatabase types of raster store—In this configuration, the reconstruction output (recon and products folder) will be stored in the cloud raster store and the mosaic dataset will be stored in the enterprise geodatabase raster store.
Tip:
This type of configuration is recommended for better scalability for hosted imagery layers.
File share type of raster data store—In this configuration, both the reconstruction output (recon and products folder) and the mosaic dataset will be stored at the file share raster store.
Cloud store with file share type of raster data store—In this configuration, the products folder will be stored at the cloud raster store and the recon folder and mosaic dataset will be stored at the file share raster store.
Important:
Additional steps are needed to set up the file share raster store for Reality Server on Linux.
Federate your Reality Server site with your portal.
Important:
All ArcGIS Reality Server sites that are federated with the ArcGIS Enterprise deployment must match the version of the ArcGIS Enterprise deployment.
Configure Reality Server role.
Click the More options button of the Reality Server site and select Configure server role to open the
Configure server rolewindow.Toggle on the reality Server role.
Click Save.
Optional: Follow the same general process described in steps 2 through 5 to deploy a dedicated ArcGIS Image Server site for improved imagery hosting performance.
Optional: Install other additional recommended software components, depending on use case:
Deep Learning Libraries - required for Gaussian Splats processing.
ArcGIS Raster Data — Provides an offline version of the elevation source used throughout the workflow.
DJI Thermal Camera Support - required for specified DJI thermal cameras.
ArcGIS Coordinate System Data - required for coordinate system transformation.
