ArcGIS Server site mode
ArcGIS Server provides a read-only mode that allows you to control changes to the site. Enabling this mode prohibits publishing new services and blocks most administrative operations. Your existing services continue to function as before. For example, you can still edit data in feature services when the site is in read-only mode.
By default, your site is in editable mode. This means you can administer the site and publish new services. See Change the ArcGIS Server site mode for steps on how to switch between site modes in Manager.
Certain administrative operations are still available in read-only mode, such as adding or removing machines from a site and querying logs. See Administrative operations and ArcGIS Server site mode for a list of which administrative actions are available and which are disabled when the site is in read-only mode.
ArcGIS Enterprise also has a read-only mode, which places all federated servers into read-only mode. That mode is separate from the stand-alone ArcGIS Server read-only mode, but you can set a federated ArcGIS Server site to read-only from either option.
Server directories
When you switch to read-only mode, site configuration files are copied to a local repository on each machine in the site. This allows the site to read from the local repository in the event of a failure connecting to the configuration store and input directory. The site can operate in a degraded capacity that allows access to the ArcGIS Server Administrator Directory, ArcGIS Server Manager, and ArcGIS Services directory, and keeps most services running as expected.
If the site is operating in a degraded capacity, the limited administrative operations that function when the site is in read-only mode are no longer available. Your services function as expected, with the following exceptions:
  • Geoprocessing services do not work.
  • Cached services do not work unless they are highly available.
  • Exporting a map or image service using a URL is not possible.
The jobs and output directories for a multiple-machine site remain in their shared location when the site is in read-only mode. They are not copied to each local machine.
Federation
You cannot federate a site that is in read-only mode. Only editable sites allow federation. After you federate the site, however, you can switch the mode to read-only.
Hosting servers
You cannot set hosting server sites to read-only mode. Sites in read-only mode cannot be designated as hosting server sites. To place a hosting server into read-only mode, use the organization mode setting.
Advanced site mode configuration
By default, switching to read-only mode copies site configuration files to a local repository on each machine in the site. Your services also restart. To change this default behavior, edit properties in the ArcGIS Server Administrator Directory. For instructions or more information about advanced site mode configuration, see Advanced site mode configuration.
Recovery of a site
You can recover a site that is in read-only mode if its connection to the shared configuration store is lost. See Recover a site for details.
Upgrades
When you upgrade your site, the mode is set to editable if you have not already switched to editable mode. After all machines in your site are successfully upgraded, the site remains in editable mode. You can switch back to read-only mode once your upgrade is complete.
