Configure AI
Members of the default administrator role or custom roles with appropriate administrative privileges can enable geospatial AI capabilities and external AI client access for their organization.
AI
AI capabilities include assistants, agents, and premium services available through supported ArcGIS apps, APIs, and SDKs. These capabilities may be available at different life cycles, including general availability and beta. For a summary of features and their status at this release, see What's new in ArcGIS Enterprise.
To configure AI capabilities, complete the following steps:
Verify that you are signed in as a member of the default administrator role or a custom role with administrative privileges to manage the organization's security settings.
At the top of the site, click Organization and click the Settings tab.
Click AI on the side of the page.
Under AI, turn on the Allow members to use AI features in ArcGIS toggle button.
Enable any of the following AI capabilities:
An ArcGIS Online organizational account and internet access are required to enable and use AI capabilities in ArcGIS Enterprise. The account you specify when enabling the capabilities must be of a supported ArcGIS Online organizational account type. The capabilities must be enabled in ArcGIS Online before you can enable them in ArcGIS Enterprise.
Data and prompts used in conjunction with AI capabilities will be processed in ArcGIS Online. Any data used in conjunction with an AI capability can be sent to this external service managed by Esri.
AI assistants
AI assistants include generative AI capabilities that help members perform tasks such as generating code, managing content, storytelling, translating, and streamlining existing workflows. This setting controls access to AI assistants available across supported ArcGIS apps.
To enable this capability for your organization, click Enable, provide the credentials for an ArcGIS Online organizational account, and click Accept and enable. If the capability is already enabled and you need to update the credentials, click Update credentials, provide the new credentials, and click Update ArcGIS Online credentials.
The account must belong to a member who has been assigned either the Use AI or Use AI assistants privilege.
Once you enable AI assistants for your organization, they are available in supported ArcGIS apps. In ArcGIS Enterprise 12.2, all AI assistants are in beta. For a list of supported apps and the AI assistants available in each, see Beta and preview features.
AI agents
AI agents perform multi-step tasks on your organization members' behalf, such as finding data, running analysis, and preparing results. Members describe a goal, and the agent carries out the steps needed to achieve it and reports the results. This setting controls access to AI agents available across supported ArcGIS apps.
The account must belong to a member who has been assigned the Use AI privilege.
Once you enable AI agents for your organization, they are available in supported ArcGIS apps. In ArcGIS Enterprise 12.2, all AI agents are in beta. For a list of supported apps and the AI agents available in each, see Beta and preview features.
AI premium services
AI premium services provide natural language processing, prompt-based image analysis, and other AI-powered capabilities. This setting controls access to AI premium services available through supported ArcGIS apps and APIs.
The account must belong to a member who has been assigned either the Use AI or Use AI premium services privilege.
Once you enable AI premium services for your organization, they are available through supported ArcGIS apps and APIs. These services may be available at different life cycles, including general availability and beta.
| Product | Premium service functionality |
| ArcGIS Arcade Functions | Translate text |
| ArcGIS Python API | Translate text, analyze text, analyze image, image extract text, analyze file, transcribe audio, generate speech |
| ArcGIS Survey123 | Analyze text and analyze image |
| ArcGIS Instant Apps | Analyze text and analyze image |
For a summary of these AI premium services and their status at this release, refer to the ArcGIS Online documentation.
External AI client access
External AI client access allows organization members to connect external AI clients to their organization through the Model Context Protocol (MCP).
To enable external AI client access for your organization, complete the following steps:
Before you can enable external AI client access, you must configure MCP services for your organization. For more information, see MCP in ArcGIS Enterprise.
Under External AI client access, turn on the Allow members to connect external AI clients through MCP toggle button.
All MCP catalogs in ArcGIS Enterprise will now be accessible through external agentic clients.
