Configure ArcGIS Pro licenses
The ArcGIS Pro application allows you to create and work with spatial data on your desktop. It provides tools to visualize, analyze, compile, and share your data in 2D and 3D environments.
You have the following options for licensing ArcGIS Pro:
  • Provision named-user licenses to ArcGIS Enterprise members.
  • Provision named-user licenses to members of an ArcGIS Online organization.
  • Use a single-use license.
Learn more about licensing ArcGIS Pro.
Once your ArcGIS Pro installation has been licensed using any of these methods, you can connect to other portals from ArcGIS Pro.
This topic covers the first licensing option: provisioning named-user licenses to ArcGIS Enterprise members.
As an administrator of an ArcGIS Enterprise organization that will provision ArcGIS Pro licenses to members, you must first purchase and download a license file through My Esri and assign your organization members user types that include ArcGIS Pro.
Configure ArcGIS Pro licenses for your organization
As of ArcGIS Enterprise 11.4, ArcGIS License Manager is no longer required to enable named user licensing for ArcGIS Pro, and members assigned a Creator, Professional, or Professional Plus user type include a license for ArcGIS Pro Basic, ArcGIS Pro Standard, and ArcGIS Pro Advanced, respectively.
The portal you specify to manage licenses is known as the licensing portal. This is important, as ArcGIS Pro connects to this portal to obtain licensing information for members of your organization. If your organization has multiple portals, ensure the portal you specify is the one you want to use to manage licenses.
Provision ArcGIS Pro licenses in ArcGIS Enterprise
Once you configure ArcGIS Pro licenses for your organization, assign organization members user types that include the desired ArcGIS Pro license. See Manage licenses for full instructions. After you provision licenses, members can connect ArcGIS Pro to the licensing portal as described below.
Organizations that require greater control over offline use of ArcGIS Pro can manage this capability at both the organization and member level. Administrators or members with licensing privileges can prevent all ArcGIS Pro licenses in the organization from being taken offline with the Members cannot take ArcGIS Pro offline setting. Organizations can also use the dedicated member privilege to control which members are allowed to take ArcGIS Pro licenses offline. The organization-wide setting overrides the member privilege.
When the Members cannot take ArcGIS Pro offline option is set, members who are already working offline will still be able to check their licenses back in. However, any subsequent attempts to take their ArcGIS Pro license offline—regardless of assigned privilege—will result in an error.
Connect to the licensing portal in ArcGIS Pro
Connect ArcGIS Pro to your licensing portal. The licensing portal controls software authorizations for each member account in the portal. If your organization has multiple portals, ensure the portal is the one you configured to manage licenses.
  1. Start ArcGIS Pro.
  2. At the bottom of the ArcGIS Sign In page, click Configure your licensing options.
    If you bypass the ArcGIS Sign In page, click Settings in the lower left corner of the ArcGIS Pro start page. On the Settings page, click Licensing on the left and click Configure your licensing options.
  3. Select ArcGIS Enterprise and enter the URL of the licensing portal.
    The URL is formatted as https://webadaptorhost.example.com/webadaptorname. ArcGIS Pro must have access to the licensing portal.
  4. Click OK.
  5. Enter your credentials and click Sign In.
ArcGIS Pro is now connected to the licensing portal. ArcGIS Pro continues to connect to the licensing portal during each startup. You can change the licensing portal by following the steps above.
If you're working in ArcGIS Pro but see a Not signed in indication in the corner of the application, you may need to sign in to the portal containing your content to be able to browse and share files. You can view the available portals by clicking the Project tab and selecting Portals. To connect to a different portal, right-click the portal's URL and select Set As Active Portal. You can also add another portal by clicking Add Portal.
Distribute ArcGIS Pro through ArcGIS Enterprise
You can create a portal application item for the ArcGIS Pro installation files so members licensed to use ArcGIS Pro can install.
Make ArcGIS Pro installation available through a URL
Deploy the ArcGIS Pro installation files to a web server.
  1. Download the ArcGIS Pro installation files from My Esri.
  2. Host the ArcGIS Pro self-extracting .exe installation file on a web server.
    This provides you with the URL needed to add an application item.
Create a group
Create a group and invite or add members of your organization to the group.
  1. Sign in to your ArcGIS Enterprise organization.
  2. Create a group.
  3. Invite or add all members who you want to access and install ArcGIS Pro.
    This would be any members who are licensed to use ArcGIS Pro.
Add and share an ArcGIS Pro application item
Add an application item to the portal that points to the ArcGIS Pro URL. Share the application item with the group you created.
  1. Click the My content tab of the content page.
  2. Click Add Item.
  3. On the Add Item dialog box, choose An application from the drop-down list.
  4. Choose Application.
  5. Type a title for the item; for example, ArcGIS Pro.
  6. Type tags that will help your members find the item.
  7. Click Add Item.
    The item page for the item opens.
  8. Click Share and choose the group you created for sharing the installation files.
  9. Click OK to close the Share dialog box.
  10. Click Edit and update the item.
  11. Type a short description of the installation item in the Summary field.
  12. Type a more detailed description and create a link to the installation file in the Description field.
    1. Click the Create Link button in the Description field.
    2. On the Link Properties dialog box, type or paste the URL to the ArcGIS Pro file. For example, type http://webserver.example.com/ArcGISPro/ArcGISPro.exe.
    3. Type descriptive text for the link, such as Download ArcGIS Pro installation.
    4. Click Set to create the link.
  13. Type information about who can use this application in the Access and Use Constraints field.
  14. Click Unregister App in the App Registration section.
  15. Type the URL to the installation file in the URL field in the Properties section.
  16. Click Save.
The ArcGIS Pro installation file is now available to all members of the group with which you shared it.
ArcGIS Enterprise members can sign in and search for the application item or access the item from the group. They can then download the installation file to their local machine and install ArcGIS Pro.
