Manage licenses
As an administrator or member of a custom role with the privilege to manage licenses, you can specify which members have access to licensed apps that aren't already included in their assigned user type. You can also assign add-on licenses for apps that were purchased separately, for capabilities and apps included in organization extensions, or for user type extensions.
Organization extensions in ArcGIS Enterprise have unique configurations. Refer to the extension documentation for details. You can view license and user type details and configure add-on licenses for a single product at a time and multiple products at once.
Import licenses
Licenses are managed through a single .json file downloadable from My Esri. If there are any changes to your organization's licensing, you must obtain a new .json file containing all licenses, which will overwrite the old license file when imported.
You can import the new license file through the portal or the command line.
Import licenses in the portal
You can import a new license file in the portal.
Verify that you are signed in as an administrator of your organization or a member of a custom role with the privilege to manage licenses.
At the top of the site, click Organization, and click the Licenses tab.
Click Import Licenses.
Choose the
.jsonlicense file and click Open.Click Import.
The new licensing is reflected on your Licenses page, and you can assign licenses to members here.
When importing a new license file, any user types or app licenses in your portal are overwritten by the new license file. For example, if you had apps in your portal that are no longer included in your new license file, these apps are removed when the new license file is imported.
Import licenses using the command line
You can use the importlicense command line utility to import a new license file.
To use the importlicense command line utility, run the importlicense.sh script with -h or -help as follows:
<Portal for ArcGIS Installation Directory>/tools/importlicense/importlicense.sh -help
Example usage with the utility: importlicense.sh [-u <arg>] [-p <arg>] [-lf <arg>]
To use the importlicense command line utility, run the importlicense.bat script with -h or -help as follows:
<Portal for ArcGIS Installation Directory>\tools\importlicense\importlicense.bat -help
Example usage with the utility: importlicense.bat [-u <arg>] [-p <arg>] [-lf <arg>]
Option |
Description |
Username for an account with administrative privileges to the portal |
Password of the account specified for the |
The path to the portal license file |
Displays the tool help and exits |
View license and user type details
The licensing page includes details about your organization's add-on licenses and user types, including compatibility tips that help you make decisions when managing licenses.
Tip:
For a preview of the number of licenses and user types available and assigned to members, refer to the Add-on licenses and Members cards on your organization's Overview tab.
Click the User types tab to see the assigned and available user types in your organization, as well as the included licenses, compatible add-on licenses, and compatible roles for each user type.
Click the Add-on licenses tab to see the add-on licenses you have available and assigned in your organization, as well as compatible user types for each.
In the ArcGIS Pro section, click View license activity to see which members are currently using ArcGIS Pro, the last time they used the app, and whether members have checked out their license (if offline usage is permitted in the organization). You can only view license activity for members currently assigned ArcGIS Pro.
You can search the members by name to filter the list. A green dot next to the last used date indicates that the member has used ArcGIS Pro in the last 30 minutes. A red dot and an Offline label indicate that the member has checked out their ArcGIS Pro license for offline use.
Configure add-on licenses for one product
To configure add-on licenses for a particular product, complete the following workflow. You can use this workflow to assign or unassign the same product for one or more members at a time.
Locate the add-on license you want to change. If necessary, search the licenses by name. Click Manage.
In the window that appears, find the member or members whose license you want to manage. To search the list of organization members, type the member's name in the search box. Use the filters to narrow the list of members.
For example, you can filter the list to show only members with a particular user type and role, those who have signed in in the last day or a specified date range, or members in a specific group who are assigned an ArcGIS Pro license.
If you're assigning a license, turn on the license assignment next to each member. To assign the specified add-on license to all assigned members that appear on the page, click Manage all on page.
If you can't assign the license to a particular member because it's not compatible with their user type, you can update user types on the Members tab.
If you're unassigning a license, turn off the license assignment next to each member. To unassign the specified add-on license from all applicable members, turn on the filter to show only members with that license assigned and click Manage all on page.
You cannot unassign ArcGIS Pro or ArcGIS Drone2Map licenses from users who checked out a license.
Close the window to return to the licenses page.
End an active ArcGIS Pro session
Sometimes you may need to end a member's active ArcGIS Pro session to release an add-on license for another member to use.
In the ArcGIS Pro section, click License activity.
In the window that appears, search the members list and click the row for the member to view activity details.
Click End session, then click Yes to confirm.
If the member has set an alias name for the workstation from within ArcGIS Pro, you can use that to help confirm the session to close. In ArcGIS Pro, the member starts receiving notifications about the session ending as the app begins to shut down. The member can have up to three simultaneous ArcGIS Pro sessions.
Configure add-on licenses for multiple products
To configure add-on licenses for multiple products at once, complete the following workflow. You can use this workflow to change the add-on licenses for one member or a selected set of members.
At the top of the site, click Organization, and click the Members tab.
Search for members by name or username and apply filters to narrow the members list. Sort the list as desired, such as by name or last login date.
Click the More options button
in the member's row and click Add-on licenses.Tip:
To change multiple members at once, check the box next to the name of each member for whom you want to assign or unassign the same add-on licenses. You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise your selection once you've modified your initial search or filter. Above the list of members, click Manage add-on licenses.
In the window that appears, select or deselect the add-on licenses that you want to change.
If you selected multiple members, you can only assign add-on licenses that are compatible with all the selected members' user types. If necessary, click the members selected drop-down menu to remove any members with an incompatible user type. To review what's compatible with your organization's user types, go to the Licenses tab and click User types.
You cannot unassign ArcGIS Pro or ArcGIS Drone2Map licenses for members who checked out a license.
Click Save.
Unassign duplicate add-on licenses
When one or more add-on licenses assigned to members are included with their user types after upgrading the portal, you will see a notice on the Overview tab of the organization page stating that some members have licenses assigned twice. You can unassign duplicate add-on licenses from all applicable members to free up those licenses.
To check which add-on licenses are included with a member's user type, go to their profile, click View <member name>'s settings, and click Licenses.
To unassign duplicate add-on licenses, complete the following steps:
In the notice, click Unassign duplicate add-on licenses.
Choose the add-on license you want to unassign from the Choose an add-on license drop-down menu.
Review the list of members and click Unassign duplicate licenses.
Manage ArcGIS Pro settings
Organizations requiring more control over ArcGIS Pro licenses, including offline usage, can manage ArcGIS Pro settings from the Licenses tab.
Do the following to manage ArcGIS Pro settings:
Click the Add-on licenses tab.
In the ArcGIS Pro section, click Manage ArcGIS Pro settings.
Optionally, under ArcGIS Pro offline settings, choose one of the following:
Members can take ArcGIS Pro offline for the maximum allowed duration—This option allows organization members to take their ArcGIS Pro license offline until it expires. This option is only applicable to ArcGIS Pro 3.4 or later.
Members can take ArcGIS Pro offline for a set period—This option allows you to specify the number of days that members can take their ArcGIS Pro license offline before it is automatically returned. The maximum number of days you can set is 360. If a member's ArcGIS Pro license is set to expire before the specified time, the maximum duration they can take their license offline is until it expires. This option is only applicable to ArcGIS Pro 3.4 or later.
Members cannot take ArcGIS Pro offline—This option prevents members from taking their ArcGIS Pro license offline, overriding the related privilege. ArcGIS Pro users who are already working offline when this setting is enabled will be allowed to check back in, but any future attempts to take an ArcGIS Pro license offline will generate an error.
Optionally, under License expiration notice, modify the notification period for alerting ArcGIS Pro users when their ArcGIS Pro license is about to expire.
You can have ArcGIS Pro display notifications starting 1 to 15 days (including weekends) before the expiration date. Once the license has been renewed, notifications are no longer displayed. A longer notification period is recommended for organizations that rely on ArcGIS Pro users alerting administrators that their licenses will expire soon.
Click Save.
Configure user type extensions
User type extensions are licenses that extend the capabilities of ArcGIS Enterprise for specific users in an organization. They can be included as part of a user type or as an add-on license.
Assign a user type extension license on the Licenses tab
To assign a user type extension license to a member of the organization on the Licenses tab, do the following:
In the User type extensions section, find the license you want to manage. Click Manage.
You can also click Compatible user types to see the list of user types that are compatible with the extension, based on the privileges granted to those user types.
Turn on the license assignment next to each member and choose whether or not you want to notify the member by email. To assign the specified user type extension license to all applicable members that appear on the page, click Manage all on page.
If you can't assign the license to a particular member because it's not compatible with their user type or role, you can update user types and roles on the Members tab, or you can assign them a role with the privileges required for the capabilities provided by the extension.
To unassign a license, turn off the license assignment next to each member. To unassign the specified user extension license from all applicable members, turn on the filter to show only members with that license assigned and click Manage all on page.
You can also manage user type extensions from the Members tab.
Assign a user type extension license on the Members tab
To assign a user type extension license to one or more members of the organization on the Members tab, do the following:
In the window that appears, select or deselect the user type extension licenses that you want to change.
If you selected multiple members, you can only assign user type extension licenses that are compatible with all the selected members' user types. If necessary, click the members selected drop-down menu to remove any members with an incompatible user type. To review what's compatible with your organization's user types, go to the Licenses tab and click User types.
Click Save.
Release a checked-out license
If a user checks out a license for use in a disconnected environment and the device using the license is lost or destroyed, you'll need to release the license using the Portal Administrator Directory. This frees the outstanding license and allows the user to check out a new license or use ArcGIS Pro, ArcGIS Drone2Map, or ArcGIS AllSource in a connected environment.
Open a web browser and sign in to the Portal Administrator Directory as an administrator of your organization.
The URL is formatted as
https://organization.example.com:7443/arcgis/portaladmin.Click Home > License > Release License.
Type the username of the user who checked out the license (for example, jcho).
Click Release License.
Considerations for managing licenses
Keep the following in mind when managing licenses:
If an app is included with a member's assigned user type, you don't need to assign the member an add-on license for that app. If you're not sure which apps a member can already access, view their profile to see the licenses included with their user type and any assigned add-on licenses. (Go to the Organization page and click the Members tab. Find the member whose profile you want to view, click the More options button
, and click View profile.)Your organization must have licenses available for ArcGIS Pro extensions or add-on licenses such as ArcGIS AllSource before you see those products on the Licenses tab and can manage add-on licenses for those products.
You can configure email settings for your organization's administrative contacts to receive automatic email notifications when licenses in your organization are about to expire.
Each product has a corresponding card on the licenses page that shows the number of add-on licenses available to assign and compatible user types.
It is possible for your organization to have a negative number of licenses available. This can happen if you assign licenses to your members but are later entitled to fewer licenses, for example when licenses expire or if you import a new license file with less licenses. Upon the expiration of any license in your organization, you must unassign the expired license so your organization's members are only assigned valid licenses. Members with an expired user type will not be able to sign in. Members with an expired add-on license will not be able to use the license.
If an incorrect organization URL is entered when generating the license file in My Esri, named user licensing of ArcGIS Pro, ArcGIS Drone2Map, and ArcGIS AllSource will fail. Verify that the URL specified in the license file matches the organization URL using the
validateURLoperation.
