Configure items
Members of the default administrator role and members of custom roles with the appropriate administrative privileges can control the following settings that affect the items in an organization:
  • Enable a comments section on the item page of each item in the organization.
  • Allow the storage of metadata for items, and configure the default metadata style used by the organization.
  • Create hierarchical categories to help organize items in a systematic and centralized way.
Follow these steps to configure item settings for the organization:
  1. Verify that you are signed in as a member of the default administrator role or a custom role with the set of administrative privileges required to manage the organization website.
  2. At the top of the site, click Organization and click the Settings tab.
  3. Click Items on the side of the page.
  4. Configure any of the following item settings:
Comments
Keep the Show and allow comments on items in the organization toggle button turned on to show and allow comments on items in the organization. When turned off, comments cannot be added and are not displayed for items owned by the organization.
Metadata
Keep the Enable editing metadata on item pages toggle button turned on to allow members to edit metadata for items in your organization. Choose a metadata style from the drop-down list, or use the default (Dublin Core+).
The style controls how the metadata appears and which elements are available for creating it. By enabling metadata, members of your organization can include additional standards-based metadata in their items using a built-in metadata editor. When this metadata is included, anyone with access to the item can view the metadata in the style configured for the organization.
If you later turn off metadata editing, existing metadata is not lost. The metadata is still part of the item, but the editing experience is no longer available in the portal website. Any standards-based metadata authored while metadata was enabled can still be viewed from the item page.
Organization categories
Click Set up categories to define hierarchical categories for organizing content. If you choose to set up categories for your organization, you can create your own custom categories or use standard category sets from ArcGIS (presented in ArcGIS Living Atlas), the International Organization for Standardization (ISO), or INSPIRE as a starting point. Once categories have been configured, they can be used to organize items in your organization so that members can more easily find the content they need when searching or browsing.
You can add, delete, rename, or reorder the categories at any time by clicking Configure categories. Your edits are applied to any items that were categorized previously.
Item classification
Assign your organization a classification schema to allow members to classify items based on their level of sensitivity, which can help protect confidential and proprietary information. To assign a classification schema, you must be a member of the default administrator role or a custom role that includes the Organization website privilege and use a valid JSON file that outlines your schema. Once assigned, you can update or delete the classification schema if needed.
For more information and instructions, see Configure classification schema.
