Configure ArcGIS Navigator
To configure the ArcGIS Navigator app, follow these steps:
Download mobile map packages from My Esri or create custom mobile map packages in ArcGIS Pro. Host them on a web server.
Register the mobile map packages with the organization.
Members can then sign in to the organization with the Navigator app, download map packages for their work, and navigate offline. See the ArcGIS Navigator help for details.
Manage mobile map packages
Navigator users who are signed in to your organization see the mobile map packages that you have made available for download. You can obtain map packages created by Esri from My Esri or create your own map packages in ArcGIS Pro and upload them to your organization. To make mobile map packages available to Navigator app users, you must register them first.
ArcGIS Enterprise comes with a Navigator Maps group owned by esri_nav. This group is prepopulated with items created by Esri. You can browse the contents of the Navigator Maps group to see each item's description, thumbnail, and other information.
Follow these steps to access the items in the Navigator Maps group:
Sign in to the organization.
Open Groups > My Organization's Groups.
Click the Navigator Maps group.
This opens the item page for the group.
To see all items in the group, click View All Group Content.
You can click any of the items to open its item page.
When the organization is first created, these items are not linked to any map packages. To populate the items with content or update an item's content, download map packages from My Esri, host them on your own web server, and register the hosted packages.
Use the mobile map package tool (managemmpks) that is installed with Portal for ArcGIS to register these packages. You can also use this tool to update, unregister, and list the mobile map packages in your organization as needed.
Download mobile map packages provided by Esri
To download the mobile map packages provided by Esri, follow these steps.
Log in to My Esri and click My Organizations > Downloads > Data and Content.
Type Navigator in the search text box and choose the sort option you want from the Sort By drop-down list.
Scroll through the list of mobile map packages to find the files you want.
Click Download for each mobile map package you want to provide to Navigator app users. Download the files one at a time.
Place the downloaded map packages in a location that is web accessible. For example, if you're using IIS as your web server, you can place the downloaded files in the
c:\inetpub\wwwroot\folder or another location that is configured as a virtual directory.The URL to the web server where you place map package files is the base URL you will provide when using the
managemmpkstool to register and manage packages.Enable the
.mmpkextension as MIME type. For example, if using IIS as your web server, follow these steps.Open IIS Manager.
In the Connections pane, select your server in the tree view and double-click MIME Types.
In the Actions pane, click Add.
For File name extension, type .mmpk.
For MIME type, enter application/mmpk.
Restart your web server.
Register mobile map packages
Once you have acquired mobile map packages and hosted them on a web server, register them with your ArcGIS Enterprise organization. Any updates to the mobile map packages must also be communicated with the organization. Each mobile map package corresponds to an item in the organization. Registering your mobile map packages updates these items to reference the URL of the .mmpk files on your web server.
You can register and manage mobile map packages with the managemmpks tool. This tool is installed with Portal for ArcGIS in the <Portal for ArcGIS installation directory>/tools/managemmpks directory. You will be prompted for the portal administrator user name and password when you run the managemmpks tool.
You can register and manage mobile map packages with the managemmpks tool. This tool is installed with Portal for ArcGIS in the <Portal for ArcGIS installation directory>\tools\managemmpks directory. You will be prompted for the portal administrator user name and password when you run the managemmpks tool.
The managemmpks tool allows you to register one or more mobile map packages at a time. The tool takes the item names as input, not the names of the map packages. Therefore, you need to know the names of the existing items before you register. To get this list, you can use the --preinstalled command with the managemmpks tool, or browse the contents of the Navigator Maps group.
Type managemmpks --help to get help with the tool syntax.
Once you know the item names you want to register, follow these steps to register the map packages hosted on your web server:
Log in to the machine where Portal for ArcGIS is installed.
Start a terminal session and authenticate as the user who installed Portal for ArcGIS.
Open a command prompt window using the Run as administrator option.
From the command line, browse to the
tools/managemmpksfolder of the Portal for ArcGIS installation directory.From the command line, browse to the
tools\managemmpksfolder of the Portal for ArcGIS installation directory.Run the following
managemmpkstool with the--registercommand to register all mobile map packages listed in a text file, comma separated values file, or as comma separated list of package item names:managemmpks --register --url <base_URL> {--file <package_names_list.txt> | --packages <package_name1,package_name2>}.The following example uses a list of mobile map package item names to register mobile map packages accessed through the URL
http://mapcdn.esri.com/navigator/mmpk:managemmpks --register --url http://mapcdn.esri.com/navigator/mmpk --packages Alabama,Czech_RepublicWhen you use the
--packagescommand, you must insert underscores (_) to replace the spaces in item names that contain multiple words, as shown for the Czech Republic item in the previous example.In this example, a text file—
us_states_package_list.txt—containing a list of the item names is provided for mobile map package (.mmpk) files accessed throughhttp://mapcdn.esri.com/navigator/mmpk.managemmpks --register --url http://mapcdn.esri.com/navigator/mmpk --file us_states_package_list.txtWhen you use a text or comma separated values (CSV) file to register the mobile map packages, you do not need to replace spaces in item names with underscores. For example, the file could contain the following entries:
Alabama Czech Republic South America Southern Cone Region
Navigator app users can download map packages for navigation.
Update mobile map packages
Esri updates the mobile map packages on My Esri on a regular basis. You can also update the mobile map packages you generate in ArcGIS Pro. After you obtain these updated files and place them in the mobile map package file directory you access through the base URL, use the managemmpks tool with the --refresh command to update the package contents. You can provide a text or CSV file containing the mobile map package names or a comma-separated list of item names. The syntax is managemmpks --refresh {--file <package_names_list.txt> | --packages <name1,name2>}.
In this example, updated farmland and pop_density mobile map packages were placed where the base URL can access them.
managemmpks --refresh --packages farmland,pop_density
Update the content for the items in the Navigator Maps group whenever new .mmpk files are available, but do not change their associated base URL. Once you run the --refresh command, Navigator app users will see that the files have been updated and can download the updated files.
Unregister mobile map packages
To unregister mobile map packages, use the --unregister command with the managemmpks tool. You can specify a text or CSV file list of packages using the --file command or include a comma-separated list of item names using the --packages command.
In this example, the Albania mobile map package is unregistered.
managemmpks --unregister --packages Albania
When you use the --packages command, you must insert underscores (_) to replace the spaces in organization item names that contain multiple words, such as Czech Republic.
The following example shows unregistering the mobile map packages listed in the text file, package_list.txt:
managemmpks --unregister --file package_list.txt
When you use a text or comma separated values (CSV) file to unregister mobile map packages, you do not need to replace spaces in item names with underscores. For example, the file could contain the following entries:
Alabama
Czech Republic
List all mobile map packages
Use the --list command with the managemmpks tool to generate two lists: one of registered mobile map packages and one of unregistered mobile map packages. Use the --dir command to specify an output directory in which to create text files of these lists. The file name is autogenerated by the managemmpks tool. You can then use these text files as input for registering and unregistering .mmpk files.
In this example, the list of mobile map packages is output to the directory /usr/temp.
In this example, the list of mobile map packages is output to the C:\temp directory.
./managemmpks.sh --list --dir /usr/temp
managemmpks --list --dir C:\temp
Two files are created in the directory you specify.
registered-<YYYMMDD-hhmmss>.txt—This file contains the names of registered items.unregistered-<YYYMMDD-hhmmss>.txt—This file contains the names of unregistered items.
List installed mobile map packages
Use the --preinstalled command with the managemmpks tool to list the mobile map packages that come with your organization. You can output a text file containing this list. You can then use the text file as input for registering and unregistering .mmpk files.
To return a list of the map packages in your command prompt or terminal, specify the --preinstalled command as shown in this example.
managemmpks --preinstalled
If you want to output the list to a file, specify a file name as shown in the following example:
managemmpks --preinstalled > myoutputfile.txt
