Manage collaborations as guest
As a guest organization participating in a distributed collaboration, you can view a list of collaboration participants, edit your organization's collaboration contact, manage the collaboration's item retention policy and web-tier authentication settings, and leave the collaboration. For information on managing collaboration workspaces, see Manage workspaces as a guest.
View collaboration properties
To view a collaboration's properties from its collaboration card, complete the following steps:
Sign in to your organization as a member of the default administrator role or a custom role with administrative privileges to manage the organization's collaborations.
At the top of the site, click Organization and click the Settings tab.
Click Collaborations on the side of the page.
Under the Distributed section, find the collaboration whose properties you want to view. Optionally, do any of the following to help you find the collaboration:
Type search terms in the search box.
Click Status and select a sort type and direction.
The collaboration card displays the following properties:
The status of the most recent scheduled or immediate synchronization across the collaboration's workspaces, which can be either of the following:
Healthy—All items were successfully synchronized.
Sync failure—Some or all items failed to be synchronized.
The date the collaboration was created.
Your organization's participation type in the collaboration, which is Guest.
Acceptance pending if the collaboration host has not imported your invitation response.
View collaboration participants
To the view a list of collaboration participants, complete the following steps:
Under the Distributed section, find and select the collaboration whose participants you want to view. Optionally, do any of the following to help you find the collaboration:
The collaboration window appears.
In the Guest organizations section, view the list of collaboration participants.
Optionally, click on a guest organization to view the following details:
Organization name
Organization environment
Contact person’s name and email
Edit collaboration contact
To edit your organization's collaboration contact, complete the following steps:
Under the Distributed section, find and select the collaboration whose contact you want to change. Optionally, do any of the following to help you find the collaboration:
In the Guest organizations section, find your organization, click More options
, and click Edit contact person
.The Change contact person window appears.
Find and select a new contact and click Save.
Edit a collaboration's item retention policy
A collaboration's item retention policy determines what happens to collaboration items when the collaboration or any of its workspaces is deleted.
The item retention policy is configured at the collaboration level and applies to all associated collaboration workspaces.
To edit a collaboration's item retention policy, complete the following steps:
Under the Distributed section, find the collaboration whose item retention policy you want to edit. Optionally, do any of the following to help you find the collaboration:
Click More options
and click Edit item retention policy
.The Edit item retention policy window appears.
For Items sent from my organization, select one of the following options:
Remove from participants—Items sent from your organization are removed from all collaboration participants.
Let participants decide—Collaboration participants decide whether to keep the items sent from your organization.
For Items received by my organization, select one of the following options:
Remove from my organization—Items received by your organization are removed.
Keep if permitted by contributing participants—You can keep the items received by your organization until the sending participants revoke permission to retain them.
Click Save.
Edit a collaboration's web-tier authentication information
To edit the host organization's web-tier authentication information, complete the following steps:
Under the Distributed section, find the collaboration for which you want to edit the host organization's web-tier authentication information. Optionally, do any of the following to help you find the collaboration:
Click More options
and click Edit web authentication
.The Edit web authentication window appears.
Select Yes if the host organization requires web-tier authentication and choose one of the following authentication types:
Credentials—Provide the credentials for the host organization’s web-tier authentication.
Certificate—Upload the host organization’s PKI certificate and provide its password.
Click Save.
Leave a collaboration
To leave a collaboration, complete the following steps:
Under the Distributed section, find the collaboration you want to leave. Optionally, do any of the following to help you find the collaboration:
Click More options
and click Leave collaboration
.The Leave collaboration window appears, which displays a summary of the collaboration's item retention policy.
Optionally, click Edit item retention policy and specify what happens to collaboration items when you leave the collaboration.
Click Leave collaboration.
Administrators of the host organization will be notified that your organization has left the collaboration.
