Map service log codes
This topic lists codes for log messages that you'll see when working with map services. Each list of codes is followed by one or more examples showing how the logs would look with some of the messages.
This topic has two main parts:
  • MapServer messages—A set of errors, warnings, and detailed messages written by the map service.
  • Carto messages—A set of detailed messages about the map drawing. Carto messages are available when the Verbose logging level is enabled.
MapServer messages
This following table lists log messages generated by map services and explains some of their common causes. Detailed log messages range from code 10000 through 10799, while errors and warnings range from 10800 through 10999.
Code number
Text
10000
GetDocumentInfo has started.
Provides a set of map service properties that can be used to describe the general content of the service.
10001
GetDocumentInfo has completed.
Use this code to determine how long it takes this method to process.
10002
GetMapCount has started.
Returns the number of maps (data frames) in a map service.
10003
GetMapCount has completed.
10004
GetMapName has started.
Returns the name of the map (data frame) as indicated by the index value provided.
10005
GetMapName has completed.
10006
GetDefaultMapName has started.
Name of the active map (data frame) in a map service.
10007
GetDefaultMapName has completed.
10008
GetServerInfo has started.
Returns information about the present state of a map (data frame).
10009
GetServerInfo has completed.
10010
Begin ExportMapImage.
Generates a dynamic map image from a data frame (map) in a map service.
10011
End ExportMapImage.
Use this message to determine how long it takes the server to dynamically draw a map image. Using the ArcGIS REST API, this message can be mined over a period of time and used to derive service performance statistics.
10012
ExportScaleBar has started.
Generates a scale bar image for a data frame (map) in a map service.
10013
ExportScaleBar has completed.
10014
Find has started.
Searches the attributes of one or more layers in a data frame, in a map service for a given search string.
10015
Find has completed.
10016
Identify has started.
Returns map features and their attribute values based on a spatial search.
10017
Identify has completed.
10018
QueryFeatureCount has started.
Returns the number of the features that meet the query filter selection criteria for the specified layer ID.
10019
QueryFeatureCount has completed.
10020
QueryFeatureIDs has started.
Returns a set of feature IDs that meet the query filter selection criteria for the specified layer ID.
10021
QueryFeatureIDs has completed.
10022
QueryFeatureData has started.
Returns a record set of features (geometry and attributes) that meet the query filter selection criteria for the specified layer ID.
10023
QueryFeatureData has completed.
10024
QueryFeatureCount2 has started.
Returns the count of the features that meet the query filter selection criteria for the specified layer description.
10025
QueryFeatureCount2 has completed.
10026
QueryFeatureIDs2 has started.
Returns the IDs of the features that meet the query filter selection criteria for the specified layer description.
10027
QueryFeatureIDs2 has completed.
10028
QueryFeatureData2 has started.
Returns a record set of features that meet the query filter selection criteria for the specified layer description.
10029
QueryFeatureData2 has completed.
10030
QueryHyperlinks has started.
Returns feature geometry and associated hyperlink URL for visible layers within a defined map extent.
10031
QueryHyperlinks has completed.
10032
ComputeScale has started.
Calculates the scale of the specified map (data frame) at the given map extent for an image with the given size.
10033
ComputeScale has completed.
10034
ComputeDistance has started.
Calculate the distance between two points in a map (data frame).
10035
ComputeDistance has completed.
10036
ToMapPoints has started.
Converts points from screen coordinates to map coordinates.
10037
ToMapPoints has completed.
10038
FromMapPoints has started.
Converts map coordinates to screen coordinates.
10039
FromMapPoints has completed.
10040
GetLegendInfo has started.
Returns legend information, such as layer name, group heading, classification labels, and symbol swatches, for layers in a map.
10041
GetLegendInfo has completed.
10042
GetSQLSyntaxInfo has started.
Returns SQL syntax information for the specified layer.
10043
GetSQLSyntaxInfo has completed.
10044
GetSupportedImageReturnTypes has started.
Returns the supported formats for retrieving images generated by a map service.
10045
GetSupportedImageReturnTypes has completed.
10046
IsFixedScaleMap has started.
Determines whether a map (data frame) has a cache. The cache may be a single fused map or a layer cache.
10047
IsFixedScaleMap has completed.
10048
HasSingleFusedMapCache has started.
Determines whether a map (data frame) has fused cache. Each map in a map service can only have one fused cache.
10049
HasSingleFusedMapCache has completed.
10050
GetTileCacheInfo has started.
Get cache configuration properties for a given map.
10051
GetTileCacheInfo has completed.
10052
GetTileImageInfo has started.
Get information about the image format of the cache tiles.
10053
GetTileImageInfo has completed.
10054
GetMapTile has started.
Returns the image tile from a fused map cache for a specific location.
10055
GetMapTile has completed.
10056
HasLayerCache has started.
Determines whether a given layer in a map (data frame) has a layer cache.
10057
HasLayerCache has completed.
10058
GetLayerTile has started.
Returns the image tile from a layer cache for a specific location.
10059
GetLayerTile has completed.
10060
GetVirtualCacheDirectory has started.
Gets the virtual directory containing the cache tiles for a given layer within a map (data frame).
10061
GetVirtualCacheDirectory has completed.
10062
GetCacheName has started.
Gets the cache name for a given layer within a map (data frame).
10063
GetCacheName has completed.
10064
GetCacheDescriptionInfo has started.
Gets the cache description information for a given map. This includes cache control info, tile cache info, tile image info, and cache type info.
10065
GetCacheDescriptionInfo has completed.
10066
GetCacheControlInfo has started.
Gets the cache control information for a given map. This is primarily used to determine whether client caching is allowed.
10067
GetCacheControlInfo has completed.
10068
GetServiceConfigurationInfo has started.
Returns a set of name-value pairs that contain information on map service configuration restrictions.
10069
GetServiceConfigurationInfo has completed.
10070
ExportLayout has started.
Generates an image of the layout, based on the given page description object, and writes the image to a specified file on disk.
10071
ExportLayout has completed.
10072
ExportLegend has started.
Exports a legend to an image file. This is not available through an internet connection to a map service.
10073
ExportLegend has completed.
10074
ExportNorthArrow has started.
Exports a north arrow to an image file. This is not available through an internet connection to a map service.
10075
ExportNorthArrow has completed.
10076
FromPagePoints has started.
Converts a page coordinate to a screen location. This is not available through an internet connection to a map service.
10077
FromPagePoints has completed.
10078
ToPagePoints has started.
Converts a screen location to a page coordinate. This is not available through an internet connection to a map service.
10079
ToPagePoints has completed.
10080
ApplyMapDescription has started.
Applies the current state of the map description to the map server object. This is not available through an internet connection to a map service.
10081
ApplyMapDescription has completed.
10082
RefreshServerObjects has started.
Updates the server info based on the current state of the underlying fine-grained objects. This is not available through an internet connection to a map service.
10083
RefreshServerObjects has completed.
10084
Find for layer <layer name> has started.
Searches the attributes for a specific layer in a data frame, in a map service for a given search string.
10085
Find for layer <layer name> has completed.
10086
Identify for layer <layer name> has started.
Returns map features and their attribute values based on a spatial search for a specific layer.
10087
Identify for layer <layer name> has completed.
10088
QueryHyperlinks for layer <layer name> has started.
Returns feature geometry and an associated hyperlink URL for a specific layer within a defined map extent.
10089
QueryHyperlinks for layer <layer name> has completed.
10090
GetLegendInfo for layer <layer name> has started.
Returns legend information, such as layer name, group heading, classification labels, and symbol swatches, for a specific layer in a map.
10091
GetLegendInfo for layer <layer name> has completed.
10092
MapReaderOpen has started.
Opens an MXD or PMF file stored at the specified path.
10093
MapReaderOpen has completed.
10094
Preparation for method: <method name> has started.
10095
Preparation for method: <method name> has completed.
10096
QueryOperation_Start
This message is used for QueryFeatureData and QueryFeatureData2.
10097
QueryOperation_End
10098
ImageGeneration_Started
This creates the image file from the map service.
10099
ImageGeneration_End
10138
Extent:<XMin>,<YMin>,<XMax>,<YMax>;Size:<size 1>,<size 2>;Scale:<scale value>
In an ExportMapImage request, this code returns the extent (in map service units), size (in pixels), and scale (representative fraction) of the requested map image.
103023
Symbol Drawing
The map symbol is drawn as part of the method Map.Draw.
103024
Data Access
Symbolizing
Execute Query
The data representing the symbol is accessed, symbolization is initialized, and a query is run to obtain the feature symbology.
10800
MapServerFailed
A number of errors may occur during the MapServer:Connect method. Details of the specific error should be written within the text of the message.
10801
The layer <layer name> in Map: <map name> is invalid.
This would occur when there is a layer with a broken link in the map being served. The map should be checked for layers having broken links to their data. These should be repaired and the map service refreshed after the repair.
10802
InvalidLicense
10803
Unsupported request name
10804
The requested capability is not supported.
These are the capabilities set by the server administrator.
10805
Invalid or Invisible field in SubField of the QueryFilter
This message results when the QueryFilter in a QueryFeatureData or QueryFeatureData2 contains an invalid field. An invalid field can be either a field that is marked as not visible in the original map document being served or by specifying a field in the query that does not exist in the map service.
10806
Service is Disconnected From Data
This warning would occur when attempting to perform one of the following methods on a map service layer that is not connected to its data source: Find, Identify, QueryFeatureCount, QueryFeatureCount2, QueryFeatureIds, QueryFeatureIds2, QueryFeatureData, QueryFeatureData2, QueryHyperlinks, GetLegendInfo, and GetSQLSyntaxinfo.
10807
The document contains secure (password-protected) layers.
Maps containing secure layers cannot be served. To successfully serve the map, layers requiring a password must be removed from the map.
10808
File <file name> is invalid. File <file name> does not exist. Access to file <file name> is denied.
To successfully serve a map document, the map document must be valid and accessible to the ArcGIS Server account. Something may have corrupted the file, and the map document may need to be re-created. The permissions to the map document and the directory it resides in should also be checked.
10809
PMF File <file name> is only readable by the ArcReader application.
PMFs (Published Map File) can be configured such that only ArcReader can open the document. PMFs configured in this way cannot be served. To serve such a map, a new PMF must be authored such that applications other than ArcReader can open the PMF.
10810
This PMF cannot be served because the following functionality in it has been disabled: <name of functionality>
PMFs (Published Map File) can be configured such that the PMF restricts specified functionality. This functionality can include export, find, identify, change views, access hyperlinks, change layer visibility, measure, query, query value, and view the TOC. Whenever functionality has been disabled when publishing a PMF, the PMF cannot be served. To serve such a map, a new PMF must be authored such that no functionality is disabled.
10811
PMF File <file name> is password protected and cannot be used for a server.
PMFs (Published Map File) that are password protected cannot be served. To serve the map, a new PMF must be authored without password protection.
10812
PMF File <file name> has timed out.
PMFs (Published Map File) can be authored with a timeout option. Once the date of the timeout has been exceeded, the PMF cannot be opened, and a map service based on such a PMF can no longer be served.
10813
Unable to read the specified PMF document.
To successfully serve a PMF (Published Map File), the PMF must be valid and accessible to the ArcGIS Server account. The PMF may need to be re-created. The permissions to the PMF file and the directory it resides in should also be checked.
10814
Cannot open PMF file <file name>. Probable cause: The PMF file is inaccessible to Server.
10815
PMF File <file name> contains a Globe and cannot be opened by the MapServer.
PMFs (Published Map File) can contain globes. Such PMFs cannot be used to author a map service. To create a map service, the globe must be removed from the map and the PMF republished.
10816
PMF Document <file name> cannot be opened.
10817
PMFInvalidFileType
10818
PMFUnknownError
10819
MissingParameter
A request made to the map service is missing a required parameter.
10820
OutputDirectoryNotFound
The Output directory is where the server creates temporary files for the map service. This directory is specified by the server administrator when publishing a map service and is part of the map service configuration. This directory must exist and be accessible to the ArcGIS Server account. Check the existence and the accessibility of this directory.
10821
OutputDirectoryAccessDenied
10822
PropertyFilePathUndefined
This error occurs when MapServer cannot find the property for FilePath in the property set.
10823
IsCacheMissing
IsCached is a map service configuration indicating whether the map service has a cache. Check the configuration file to make sure this setting is present and is set appropriately.
10824
CacheOnDemandMissing
CacheOnDemandMissing is a map service configuration indicating whether the map service provides on-demand caching. Check the configuration file to make sure this setting is present and is set appropriately.
10825
IgnoreCacheMissing
IgnoreCacheMissing is a map service configuration indicating whether the map service is to ignore an existing cache. Check the configuration file to make sure this setting is present and is set appropriately.
10826
ClientCachingAllowedMissing
ClientCachingAllowedMissing is a map service configuration. Check the configuration file to make sure this setting is present and is set appropriately.
10827
MapServer::OnStart() failed: can't create temp directory name.
MapServer creates a directory for each map service underneath the arcgisoutput directory. These directories are used for WMS files if the WMS capability is enabled for the service. This error may occur if the ArcGIS Server account cannot create the directory. Make sure that the ArcGIS Server account has proper permission to the arcgisoutput directory.
10828
MapServer::OnStop() failed: can't create temp directory name.
10829
Invalid service configuration. A service disconnected from data cannot ignore cache.
A map service disconnected from its data needs to use a cache. In cases in which the map service is disconnected from its data, the property IgnoreCache must be false.
10830
Invalid service configuration. A service cannot be in Cache On Demand mode and disconnected from the data.
A map service using Cache On Demand cannot be disconnected from its data.
10831
Invalid service configuration. A service cannot be in Cache On Demand mode and ignore cache.
A map service using Cache On Demand needs to use a cache. When a map service is using Cache On Demand, the property IgnoreCache must be false.
10832
MapServer construction failed. Unable to obtain pointer to IServerEnvironment.
10833
Does not have Server Object administration privileges.
10834
Unable to connect to the cache
10835
The configuration could not be started because the WMS capability requires an assigned output directory. Please assign an output directory to this service.
10836
MapNotFound
Many requests require a map name as a parameter. This error occurs when the value of the map name in a MapServer request does not match a valid available map service name.
10837
General Geodatabase error
There are a number of things that can cause an error within the geodatabase. This Map Server error wraps any geodatabase error in a single Map Server error code.
10838
No Layer found with ID: <ID number>
LayerID supplied was incorrect.
10849
An invalid where clause or definition expression has been requested: "<where clause or definition expression>"
This message is logged if database-specific functions and syntax are used in a query. If this message is continually logged, it may indicate a potential security threat or SQL injection attack.
To learn more, see About standardized queries.
Example
This example explains error messages you may see if you sent a query to a map service using a nonexistent field name.
Method
Message
Elapsed
Code
MapServer.QueryFeatureData
10022
Preparation for method: QueryFeatureData has started.
10094
Preparation for method: QueryFeatureData has completed.
0.00111
10095
Query Operation for method: QueryFeatureData has started.
10096
GeoDatabase Error: A column was specified that does not exist.
10837
0.01171
10023
Method failed.HRESULT = 0x80040358 : This is a FACILITY_ITF error that is specific to the interface that returned this error. See the documentation of the interface that returned this error for information about this HRESULT.
0.0138
100005
Two errors are returned. One, using code 10837, is generated by MapServer. Code 10837 is a generic code used by MapServer for all errors generated by the geodatabase. The text of the message will be "GeoDatabase Error:" followed by whatever text the geodatabase provides. In this example, the geodatabase-generated text is "A column was specified that does not exist."
Another error message, code 100005, is also reported for the same issue. This message is a system-generated message. This redundancy is expected.
Carto messages
When logging is set to Verbose, map services provide messages from two sources: methods from the MapServer and methods from Carto. Carto is the package of objects that draws the map. The Carto messages refer to subprocesses that occur within a map server context when a client calls ExportMapImage.
Code number
Text
103000
Beginning of layer draw: <layer name>
The layer draw is part of the geography phase.
103001
End of layer draw: <layer name>
Use this code to determine how long it takes a layer to draw.
103002
Beginning of group layer draw: <layer name>
The group layer draw is part of the geography phase.
103003
End of group layer draw: <layer name>
Use this code to determine how long it takes all the member layers of a group layer to draw.
103004
Beginning of geography phase
This is the phase in which the features of individual layers draw. This phase includes running a query (code 103021) against the layer's data along with the drawing of layer features. Also, for layers based on feature classes, a count of features being drawn is reported (code 103019).
103005
End of geography phase
Use this code to determine how long it takes all layers in the map to draw.
103006
Beginning of annotation phase
This is the phase in which graphics, labeling, and annotation draw.
103007
End of annotation phase
Use this code to determine how long it takes graphics, labeling, and annotation in the map to draw.
103008
Beginning of selection draw phase
This is the phase in which selected features draw.
103009
End of selection draw phase
Use this code to determine how long it takes selected features in the map to draw.
103010
Beginning of graphic selection draw phase
This is the phase in which selected graphics draw.
103011
End of graphic selection draw phase
Use this code to determine how long it takes selected graphics in the map to draw.
103012
Beginning of custom draw phase of the map
This is the phase in which custom features or elements draw. This is also known as the "after draw". These features or elements are often generated by extension software. It is important to note that these are not custom layers.
103013
End of custom draw phase of the map
Use this code to determine how long it takes the custom features or elements in the map to draw.
103014
Beginning of the graphics drawing
This is part of the annotation phase.
103015
End of graphics drawing
Use this code to determine how long it takes graphics in the map to draw.
103016
Beginning of the labeling
103017
End of the labeling
Use this code to determine how long it takes labeling in the map to draw.
103018
Labeling Layers:
This is the list of layers in the map that are being labeled. Also included is the list of layers that provide barriers to label placement.
103019
Feature count:
This is the count of features drawn for a particular layer at a given extent.
103020
Graphic count:
This is the count of graphics drawn for a particular layer at a given extent.
103021
Executing query
Use this code to determine how long it takes for a layer based on a feature class to query the database when drawing.
103022
Drawing as masking layer
The layer being used as a masking layer.
103800
LayerDrawingError
Indicates that a drawing error has occurred.
Example: Connect to a map service (Desktop client)
This example explains detailed messages you may see when connecting to a map service from ArcGIS Desktop. The logs have been edited to highlight specific MapServer-related messages and to remove Info messages.
When ArcGIS Desktop connects to a map service (HTTP connection), several requests are made: GetDefaultMapName, GetServerInfo, IsFixedScaleMap, GetSupportedImageReturnTypes, and GetLegendInfo. The first request is GetDefaultMapName.
Method
Message
Elapsed
Code
MapServer.GetDefaultMapName
10006
0.00032
10007
GetDefaultMapName returns the name of the active map in the map service. In this example, it took MapServer 0.00032 seconds to complete the GetDefaultMapName request. The next request is GetServerInfo.
Method
Message
Elapsed
Code
MapServer.GetServerInfo
10008
0.06732
10009
GetServerInfo returns information about the current state of the map, such as which layers are visible (turned on). In this example, it took MapServer 0.06732 seconds to complete the request. Next is GetCacheDescriptionInfo.
Method
Message
Elapsed
Code
MapServer.GetCacheDescriptionInfo
10064
0.0003
10065
GetCacheDescriptionInfo returns cache description information for a given map. This includes cache control info, tile cache info, tile image info, and cache type info. In this example, it took MapServer 0.0003 seconds to complete the request. After making a GetCacheDescriptionInfo request, ArcGIS Desktop makes a HasSingleFusedMapCache request.
Method
Message
Elapsed
Code
MapServer.HasSingleFusedMapCache
10048
0.0003
10049
HasSingleFusedMapCache determines whether the map service has a fused cache. In this example, it took MapServer 0.0003 seconds to complete the request. The next request is IsFixedScaleMap.
Method
Message
Elapsed
Code
MapServer.IsFixedScaleMap
10046
0.00032
10047
IsFixedScaleMap determines whether the map service has a cache. This could be either a fused or multilayer cache. In this example, it took MapServer 0.00032 seconds to complete the request. The next request is GetSupportedImageReturnTypes.
Method
Message
Elapsed
Code
MapServer.GetSupportedImageReturnTypes
10044
0.0003
10045
GetSupportedImageReturnTypes provides the list of supported image formats. In this example, it took MapServer 0.00032 seconds to complete the request. The final request is GetLegendInfo.
Method
Message
Elapsed
Code
MapServer.GetLegendInfo
10040
GetLegendInfo on layer 'Layer #1' has started.
10090
GetLegendInfo on layer 'Layer #1' has completed.
0.00206
10091
GetLegendInfo on layer 'Layer #2' has started.
10090
GetLegendInfo on layer 'Layer #2' has completed.
0.00087
10091
GetLegendInfo on layer 'Group Layer member #1' has started.
10090
GetLegendInfo on layer 'Group Layer member #1' has completed.
0.001
10091
GetLegendInfo on layer 'Group Layer member #2' has started.
10090
GetLegendInfo on layer 'Group Layer member #2' has completed.
0.00086
10091
GetLegendInfo on layer 'Raster layer' has started.
10090
GetLegendInfo on layer 'Raster layer' has completed.
0.00087
10091
0.01252
10041
GetLegendInfo returns the legend information for each layer. Each layer that supports a legend has a started and a completed message. These messages are logged, including the time it takes to package the legend information for that layer.
Example: ExportMapImage
This example explains detailed log messages that you may see when you request a dynamic map image from a map service using the ExportMapImage method. The logs have been edited to highlight specific MapServer-related messages and to remove Info messages.
There are nine parts to the ExportMapImage process. These include (in order):
  1. Receipt of request
  2. Preparation of the map
  3. The Geography phase——drawing of each map layer
  4. The Annotation phase——drawing of graphics, labeling, and annotation
  5. Selection drawing
  6. Graphic selection
  7. After draw——drawing of custom features
  8. Image generation
  9. Process completed and result sent
After the ExportMapImage request is received by the server, the first step is to prepare the map.
Method
Message
Elapsed
Code
MapServer.ExportMapImage
10010
Preparation for method: ExportMapImage has started.
10094
Preparation for method: ExportMapImage has completed.
0.14895
10095
Preparation includes applying the MapDescription to the map and setting up the map to draw. This includes applying any necessary geotransformations or applying a selection to any of the layers. In this example, the preparation took 0.14895 seconds. The next step is to draw the map. Drawing the map encompasses a number of phases. The first phase is the geography phase.
Method
Message
Elapsed
Code
Map.Draw
Beginning of geography phase.
103004
This is the phase in which the features of individual layers draw. Here is an example for a layer named "Layer 3".
Method
Message
Elapsed
Code
Map.Draw
Beginning of layer draw: Layer 3
103000
FeatureLayer.Draw
Executing query.
0.00332
103021
UniqueValueRenderer.Draw
Feature count: 51
103019
Map.Draw
End of layer draw: Layer 3
0.10421
103001
Layer 3 is a feature layer. Therefore, a query against the database is run (code 103021). The elapsed time for this query is 0.00332 seconds. This time is included in the elapsed time for the entire draw (code 103001). Do not add this time to the "End of layer draw" (code 103001) time. The count of features being drawn in this layer, that is, the number of features within the specified map extent, is reported as 51. Also, notice that the type of renderer is reported within the method. In this example, Layer 3 is using a unique value renderer.
When the layer is a nonfeature layer, only the Beginning of layer draw (code 103000) and End of layer draw (code 103001) are reported. Here is an example for a raster layer.
Method
Message
Elapsed
Code
Map.Draw
Beginning of layer draw: Raster layer
103000
Map.Draw
End of layer draw: Raster layer
0.64353
103001
Below is an example of the log messages for a group layer along with the message indicating the end of the geography phase (code 103001).
Method
Message
Elapsed
Code
Map.Draw
Beginning of group layer draw: Group Layer
103002
GroupLayer.Draw
Beginning of Layer Draw: Group Layer member #2
103000
FeatureLayer.Draw
Executing query.
0.02128
103021
SimpleRenderer.Draw
Feature count: 168
103019
GroupLayer.Draw
End of Layer Draw: Group Layer member #2
0.02934
103001
GroupLayer.Draw
Beginning of Layer Draw: Group Layer member #1
103000
FeatureLayer.Draw
Executing query.
0.00898
103021
SimpleRenderer.Draw
Feature count: 13
103019
GroupLayer.Draw
End of Layer Draw: Group Layer member #1
0.01678
103001
Map.Draw
End of group layer draw: Group Layer
0.04732
103003
Map.Draw
End of geography phase.
1.01074
103005
In this example, the group layer, "Group Layer", has two member layers: "Group Layer member #1" and "Group Layer member #2". Each member layer is drawn and messages are logged based on layer type as previously described. Notice that the end of group layer draw has a code (103003) different than the end of layer code (103001). The elapsed time for the group layer draw is the sum of the elapsed time of all the member layers within the group layer.
The next phase in drawing the map is the annotation phase. This phase includes drawing graphics, annotations, and the labeling of map features.
Method
Message
Elapsed
Code
Map.Draw
Beginning of annotation phase.
103006
If there are graphics within the map extent being drawn, a count will be reported (code 103020).
Method
Message
Elapsed
Code
Map.Draw
Beginning of the graphics drawing.
103014
CompositeGraphicsLayer.Draw
Graphic count: 3.
103020
Map.Draw
End of the graphics drawing.
0.00128
103015
In the example above, there are three graphics within the map extent being drawn, which takes 0.00128 seconds to process. It's important to note that even if there are no graphics in the map there will still be a minimal amount of processing that the software will need to do to cycle through each phase.
Next in the annotation phase is "on-the-fly" feature labeling. Any number of layers can be labeled with any number of placement rules defined. Every time a map extent changes, features are relabeled. This requires the labeling engine to recalculate label positions based on the rules set in the served map document. Each layer in the map that is going to be labeled is listed (code 103018), along with a list of layers being used as barriers to label placement.
Method
Message
Elapsed
Code
Map.Draw
Beginning of the labeling.
103016
Map.Draw
Layers being labeled: Group Layer member #1,Layer #1. Barriers in labeling.
103018
Map.Draw
End of the labeling.
0.20395
103017
Map.Draw
End of annotation phase.
0.21024
103007
In this example, there are two layers being labeled: "Group Layer member #1" and "Layer #1". None of the layers are used as barriers.
The last three phases are the selection draw phase, the graphics selection draw phase, and the custom draw phase. The selection draw refers to any map features that are selected. In the example below, there are six features selected. In most cases, there will be very little for the map server to process for any of these three phases.
Method
Message
Elapsed
Code
Map.Draw
Beginning of the selection draw phase.
103008
Map.Draw
End of the selection draw phase.
0.20223
103009
Map.Draw
Beginning of graphics selection draw phase.
103010
Map.Draw
End of graphics selection draw phase.
0.00029
103011
Map.Draw
Beginning of the custom draw phase of the map.
103012
Map.Draw
End of the custom draw phase of the map.
0.00028
103013
The final step in the ExportMapImage process is image generation.
Method
Message
Elapsed
Code
Image Generation for method: ExportMapImage has started.
10098
Image Generation for method: ExportMapImage has completed.
0.25913
10099
End ExportMapImage.
1.84224
10011
In this example, it took 0.25913 seconds for the image (in this example, a PNG) to be generated. The overall ExportMapImage took 1.84224 seconds to process.
It is important to note that there will be a difference in how long it takes a MapServer request to be processed and how long it takes a binary request to be processed for the same request. This difference is related to the amount of time it takes for the server to write the response to the stream.
Example: QueryFeatureData
This example shows detailed log messages that you may encounter when you query data in a map service using the QueryFeatureData method. The logs have been edited to highlight specific MapServer-related messages and to remove Info messages.
Method
Message
Elapsed
Code
10022
10094
0.00111
10095
10096
Query Operation for method: QueryFeatureData has completed.
0.95778
10097
0.96118
10023
