OGC support in ArcGIS Enterprise
Using Open Geospatial Consortium (OGC) web services, you can make your maps and data available in open, internationally recognized formats over the web to anyone using a supported client application. OGC maps and data can be used by both web-based clients such as Map Viewer and desktop clients such as ArcGIS Pro.
OGC publishing capabilities in ArcGIS Server
OGC defines several types of services for serving different kinds of data and maps. ArcGIS Enterprise supports the following OGC service types:
Web Map Service (WMS) for serving collections of layers as map images
Web Map Tile Service (WMTS) for serving map layers as cached map tiles
Web Feature Service (WFS) and OGC API Features Service for serving data as vector features
Web Coverage Service (WCS) for serving data as raster coverages
Web Processing Service (WPS) for serving geospatial processing
You publish these services by enabling capabilities on certain types of ArcGIS Server services. When you create the service, you must explicitly enable the OGC capabilities; they are not enabled by default.
The following table shows which service types can expose OGC capabilities:
Service type |
WCS |
WFS/OGC Features |
WMS |
WMTS |
WPS |
Map services |
Geodata services |
Image services |
Geoprocessing services |
Consuming OGC services
You can consume OGC services, whether they're hosted inside or outside your organization, using Esri software:
ArcGIS Maps SDK for JavaScript
ArcGIS Maps SDKs for Native Apps
Securing OGC services
OGC services are secured by managing the security of their parent services. For example, when you deny a certain role access to a map service, a user in that role will not be able to access the map service through SOAP, Representational State Transfer (REST), or any OGC interfaces (WMS, WMTS, WFS, WCS, WPS, OGC Features).
ArcGIS Server supports a number of authentication schemes. Services that are expected to be accessed through OGC interfaces should be secured using HTTP Basic, HTTP Digest, or client-certificate authentication. Most OGC clients will understand and work with these authentication schemes and may need additional logic to work with ArcGIS tokens.
ArcGIS Server supports a number of authentication schemes. Services that are expected to be accessed through OGC interfaces should be secured using HTTP Basic, HTTP Digest, Integrated Windows Authentication, or client-certificate authentication. Most OGC clients will understand and work with these authentication schemes and may need additional logic to work with ArcGIS tokens.
Securing OGC services with web-tier authentication will only work with servers that have not been federated with a Portal.
Further reading
The links below contain more information about publishing OGC services to ArcGIS Server sites:
You can learn more about OGC services at the Open Geospatial Consortium website.
