Printing in web applications
There are several ways to generate a printable document from a web application. ArcGIS Enterprise includes a geoprocessing service called PrintingTools. Web applications invoke the PrintingTools service and get a printable document in return. You can also create a custom print service using your own layouts rather than those in the default PrintingTools service. For advanced printing, you can use a Python script to convert the web map into an ArcGIS Pro Project (.aprx), then export the map or layout inside the project to a variety of formats for printing.
Printing can be configured for ArcGIS Enterprise, web app templates, and for applications created using the ArcGIS web APIs. See Configure the organization to print maps in the Portal Administrator Guide for more information about providing your organization, including any applications created with web app templates, with printing capabilities.
The PrintingTools service
PrintingTools is a preconfigured service in the Utilities folder that creates a printable document using one of a set of predefined map layouts. These include basic designs using 8.5 by 11 inch, 11 by 17 inch, A3, and A4 paper sizes in both portrait and landscape orientations. Each layout contains a north arrow, scale bar and ratio, legend, date, and title. The supported output formats from the PrintingTools service are PDF, PNG32, PNG8, JPG, GIF, EPS, SVG, SVGZ, TIFF and AIX.
The PrintingTools service is stopped by default. You must use ArcGIS Server Manager to start the service if you want to support printing workflows. Once the PrintingTools service has started, you can access it using a URL with the following format: https://webadaptorhost.example.com/webadaptorname/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task.
The ArcGIS web APIs offer widgets that can communicate with the PrintingTools service to get a printable map. You provide the URL of the PrintingTools service and the widgets do the rest of the work. For more information on using the PrintingTools service with ArcGIS Enterprise, see Configure the organization to print maps.
When your map service is cached, the PrintingTools service may use a resolution that is too low (for example, 96 DPI) for large format or high quality printing. To print at higher resolutions, it is recommended that you enable dynamic layers on your cached map service. This allows the print service to obtain map images (through an export map request) at the desired resolution (for example, 300 DPI) instead of the lower resolution tiles. To learn more, see About dynamic layers.
The Get Layout Templates Info task provides the size of the layout page and the size of a map frame. It also shows whether the following layout elements are available:
  • Legend
  • Title text
  • Copyright text
  • Author text
  • Custom text elements
You can also add this task to custom print services.
It is not recommended to use your own layout templates with the PrintingTools service. Instead, you should publish a custom print service.
Legends
Whether you use PrintingTools or a custom print service, the legends in your printed output will behave similarly. When printing feature services, the legend in the printed document will only include legend entries for the features found in the map extent, whereas legends for other service types will include all of the legend entries for the features regardless of the map extent.
Print services will automatically adjust legends to only display patches for features that are visible in the current extent. This applies to map services published from ArcGIS Pro to ArcGIS Enterprise and does not require any additional configuration.
Learn more about using legend items in ArcGIS Pro
Unicode characters
The default layout templates in the PrintingTools service do not use fonts supporting Unicode characters. You may thus run into issues with titles or legend items, specifically with international characters. To remedy this, consider publishing a custom print service using your own layout templates, and set a font that supports Unicode characters:
  • While working with the legend element in ArcGIS Pro, you can set a font supporting Unicode characters for the default legend item.
Custom print services
If you want to use your own map layouts, you can publish your own service for web map printing similar to PrintingTools. This can be done from ArcGIS Pro 2.1 and later. You configure this service to reference your own folder that you've prepared with various map layouts — Layout Files (.pagx) in ArcGIS Pro.
You can find instructions to publish your own custom tools for printing in the topic Share a print service web tool with custom layouts from ArcGIS Pro. In this workflow, you share a web tool to your organization, which is powered by a geoprocessing service published to a federated ArcGIS Server site.
These workflows also explain what to do if you later decide you want to update your layouts. Your update approach will vary based on whether or not you registered your layouts folder with the server before publishing, and the workflows contain instructions for both scenarios.
Note that there are additional considerations in these topics for publishing and consuming custom printing tools in ArcGIS Enterprise. The custom print service must be published as a synchronous geoprocessing service and the URL for the print service must use HTTPS for ArcGIS Enterprise to accept it as the print service. For more information on using a custom print service or web tool in ArcGIS Enterprise, see Configure the organization to print maps.
Custom print services can print layouts that use multiple map frames or data frames.
  • Print services published as part of a web tool from ArcGIS Pro update the map associated with the map frame you have named "WEBMAP_MAP_FRAME" (case sensitive).
However, if the map or data frames have some relationship between them, such as an extent rectangle, that relationship is honored by the print service. For example, suppose you have a layout with two map frames: a main map and an overview map. The overview map includes an extent rectangle showing the current extent of the main map. When a web user requests a map with your layout, the main map will show the current web map view, and the overview map's extent rectangle will display the extent of the main map as expected.
It is recommended to remove all layers from the map associated with the "WEBMAP_MAP_FRAME". However, in some advanced cases, you might need to have layers in the map, and the printing service does not remove them.
Advanced printing using Python
For advanced printing scenarios, you do not use PrintingTools at all. Rather, you can use the ConvertWebMapToArcGISProject function in the Python arcpy module. When the document is converted, the full web map exists in the ArcGIS Pro Project (.aprx). The map or layout in the ArcGIS Pro Project can then be further modified before finally being printed or exported to a common format such as PDF.
These convert functions are commonly used to replace service layers with local vector data, create map books, control the appearance of the legend, and export different formats using advanced options.
To make your Python script available to a web application, you can expose the script through an ArcGIS Server geoprocessing service. See Advanced printing for web maps to learn more.
