Print maps that contain secured services
You can use the PrintingTools service to print maps that contain secured services.
Web-tier authentication
If your ArcGIS Server site is federated and its ArcGIS Web Adaptor does not use web-tier authentication (IWA, client-certificate authentication, Basic, and so on), printing secured services will work as expected. The same is true for deployments that do not use web-tier authentication systems.
However, if your ArcGIS Server site's Web Adaptor uses web-tier authentication, the PrintingTools service and custom print services will not be able to print any of your site's services. This restriction exists for both federated and stand-alone ArcGIS Server sites.
Short-term tokens
If you secure your services using short-term tokens (the default), the user will be asked to provide the name and password on opening the web app. The token is then passed to the PrintingTools service when the user requests a map to be printed.
The Print service does not support IP-based tokens.
Embed credentials into a service
In some cases, when publishing your own print service that contains secured services, you need to embed credentials into the print service that it can use when requesting maps from the secured services.
If you embed a long-term token in your web app code, the authentication information cannot be passed to the PrintingTools service. Regardless of your server configuration, you need to embed credentials into the print service.
If you enforce security at the web server tier, and your ArcGIS Server site is federated, printing maps with the PrintingTools service is supported by default with no additional steps required. However, if you have a stand-alone installation of ArcGIS Server and you enforce security at the web server tier, you need to embed credentials.
Caution:
It is not recommended that you embed credentials in a custom print service without fully understanding the security impact. If you choose to publish your own service for printing with embedded credentials, it's recommended that you apply ArcGIS Server security rules to restrict who can access the service. This prevents anonymous users from generating printable map images that display your secured services.
To embed credentials in a custom print service from ArcGIS Pro, you can use the ImportCredentials function in ArcPy. You can't embed credentials for custom print services published to federated servers. The ImportCredentials function is only supported for stand-alone servers.
