Remove a federated server site
If you don't want your server to be federated with ArcGIS Enterprise anymore, remove the federated server from the organization. Your hosted service items remain in the organization but they are disconnected from their services in the server site. This means that members will not be able to access, share, or use these services in the organization. Additionally, any existing services that were imported during the federation process are removed from the organization and are no longer available. The services remain accessible through the server site until you explicitly delete them using a program such as ArcGIS Server Manager.
Caution:
Unfederating an server site should not be done as part of upgrading or routine troubleshooting. It is not easily undone and may have irreversible consequences. Removing a hosting server from ArcGIS Enterprise renders existing hosted web layers unusable. Adding the hosting server back does not return the hosted services to a usable state. Only unfederate a site if you have a clear understanding of the impact.
Only sites that fill a limited number of roles can run as stand-alone ArcGIS Server sites. For example, ArcGIS Knowledge Server sites cannot function as stand-alone sites, and unfederating them makes them unusable.
After unfederating, log in to ArcGIS Server Manager and restore the security settings you were using before you federated.
To remove an ArcGIS Server site from your organization, follow the steps below.
  1. Sign in to the ArcGIS Portal Directory administrator location as an administrator of your organization. The URL is in the format https://webadaptorhost.example.com/arcgis/portaladmin, where arcgis is the name of the Web Adaptor registered with the portal.
  2. Click Federation > Servers.
  3. Choose the server you want to unfederate.
  4. Click Unfederate.
  5. If you no longer want ArcGIS Server services to be available to any application, log in to Manager and delete the services. Hosted services published by organization members are located in the Hosted folder.
    Caution:
    If you do not perform this step, ArcGIS Server services and hosted services published by organization members continue to run on the server.
  6. Log in to Manager with the primary site administrator account, and reset the user and role stores to the settings they were using before you federated the server. When you log in, you'll notice that the unfederation operation has reverted ArcGIS Server security to the built-in user and role store. Set it to the store that you want, and reapply permissions on your services if necessary.
    If the primary site administrator account is disabled, you need to re-enable it before you can log in. To learn more, see Configure ArcGIS Server security.
