Using Styled Layer Descriptors with WMS services
Styled Layer Descriptors (SLDs) allow you to publish symbolization schemes for your WMS service using an XML specification defined by the Open Geospatial Consortium, Inc. (OGC). Alternatively, clients of your service can use their own SLDs to apply the symbols they choose.
SLD files and SLD styles
An SLD file is an XML file that follows the OGC SLD syntax so that it can be understood in server-client communication.
SLD styles are physically saved in the SLD file. Logically, one such SLD style defines symbolization rules for specified sets of features within a specified WMS layer. One style can have multiple rules, and each rule can have one filter that describes which features should be rendered and multiple symbolizers that describe how those features should be rendered.
Here is a sample SLD XML document:
<sld:StyledLayerDescriptor version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
  ESRI_StatesCitiesRivers_USA @
  http://sampleserver1.arcgisonline.com/arcgis/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/WMSServer?
 <sld:NamedLayer>
   layer "2" is the "cities" point layer in the WMS service
  <sld:Name>2</sld:Name>
  <sld:UserStyle>
    style should be applied on layer "2", reference the style by it's name "pointSymbolizer"
   <sld:Name>pointSymbolizer</sld:Name>
   <sld:Title>pointSymbolizer</sld:Title>
   <sld:FeatureTypeStyle>
    <sld:Rule>
     <sld:PointSymbolizer>
      <sld:Graphic>
       <sld:Mark>
        <!-- uses a circle to mark a city -->
        <sld:WellKnownName>circle</sld:WellKnownName>
        <!-- fill circle with color #666666 -->
        <sld:Fill>
         <sld:CssParameter name="fill">#666666</sld:CssParameter>
         <sld:CssParameter name="fill-opacity">1</sld:CssParameter>
        </sld:Fill>
        <!-- circle boundary with color #666666 -->
        <sld:Stroke>
         <sld:CssParameter name="stroke">#666666</sld:CssParameter>
         <sld:CssParameter name="stroke-opacity">1</sld:CssParameter>
         <sld:CssParameter name="stroke-width">1</sld:CssParameter>
        </sld:Stroke>
       </sld:Mark>
       <!-- circle opacity 1.0 -->
       <sld:Opacity>1</sld:Opacity>
       <!-- circle size "3" -->
       <sld:Size>3</sld:Size>
       <sld:Rotation>0</sld:Rotation>
      </sld:Graphic>
     </sld:PointSymbolizer>
    </sld:Rule>
   </sld:FeatureTypeStyle>
  </sld:UserStyle>
 </sld:NamedLayer>
</sld:StyledLayerDescriptor>
The implementation of WMS SLD in ArcGIS Server is based on the OGC Styled Layer Descriptor (SLD) Implementation Specification. To get a general overview of SLD, see the Styled Layer Descriptor page on the OGC website.
WMS Styled Layer Descriptor (SLD) support in ArcGIS Server
ArcGIS Server supports the WMS Styled Layer Descriptor (SLD) version 1.0.0 implementation specification. For a general overview of the SLD, see the Styled Layer Descriptor page on the OGC website.
The specific elements of the SLD supported and unsupported by ArcGIS Server WMS services are listed below.
Supported SLD elements
The following SLD elements are supported by ArcGIS Server WMS services:
  • <sld:CssParameter>
  • <sld:Extent>
  • <sld:ExternalGraphic>
  • <sld:FeatureTypeConstraint>
  • <sld:FeatureTypeStyle>
  • <sld:Fill>
  • <sld:Font>
  • <sld:Format>
  • <sld:Graphic>
  • <sld:GraphicFill>
  • <sld:Halo>
  • <sld:Label>
  • <sld:LabelPlacement>
  • <sld:LayerFeatureConstraints>
  • <sld:LinePlacement>
  • <sld:LineSymbolizer>
  • <sld:Mark>
  • <sld:MaxScaleDenominator>
  • <sld:MinScaleDenominator>
  • <sld:Name>
  • <sld:NamedLayer>
  • <sld:NamedStyle>
  • <sld:ogcFilter>
  • <sld:OnlineResource>
  • <sld:Opacity>
  • <sld:PerpendicularOffset>
  • <sld:PointPlacement>
  • <sld:PointSymbolizer>
  • <sld:PolygonSymbolizer>
  • <sld:PropertyName>
  • <sld:Radius>
  • <sld:Rotation>
  • <sld:Rule>
  • <sld:Size>
  • <sld:Stroke>
  • <sld:StyledLayerDescriptor>
  • <sld:TextSymbolizer>
  • <sld:Title>
  • <sld:UserStyle>
  • <sld:Value>
  • <sld:WellKnownName> (supported values are square, circle, triangle, star, cross, x)
Unsupported SLD elements
The following SLD elements are not supported by ArcGIS Server WMS services:
  • <ogc:PropertyName>
  • <sld:AnchorPoint>
  • <sld:AnchorPointX>
  • <sld:AnchorPointY>
  • <sld:BrightnessOnly>
  • <sld:ChannelSelection>
  • <sld:ColorMap>
  • <sld:ColorMapEntry>
  • <sld:ContrastEnhancement>
  • <sld:Displacement>
  • <sld:DisplacementX>
  • <sld:DisplacementY>
  • <sld:GammaValue>
  • <sld:Geometry>
  • <sld:Histogram>
  • <sld:Normalize>
  • <sld:RasterSymbolizer>
  • <sld:ReliefFactor>
  • <sld:ShadedRelief>
  • <sld:SourceChannelName>
Feature symbolizer and geometry type
At 10.7, feature symbolizers LineSymbolizer, PolygonSymbolizer, and PointSymbolizer can be used to symbolize any type of feature geometry. For example, a PointSymbolizer can be used to symbolize a polygon feature. The following table lists the behavior when the symbolizer used does not match its native geometry type:
Line
Polygon
Point
LineSymbolizer
  • Outline symbolized using Stroke specified in LineSymbolizer.
  • Transparent fill.
  • Solid dash using Stroke specified in LineSymbolizer.
PolygonSymbolizer
  • Solid dash using Stroke specified in PolygonSymbolizer.
  • Square marker symbol filled using Fill and outline using Stroke specified in PolygonSymbolizer.
  • The GraphicFill element is not supported.
PointSymbolizer
  • Single marker symbol symbolized using symbol specified in PointSymbolizer and placed at the center of the line.
  • The Graphic element is not supported.
  • Single marker symbol symbolized using symbol specified in PointSymbolizer and placed in polygon centroid.
Publishing multiple styles with SLDs
You can use the following workflow to publish multiple styles for WMS layers using SLD:
  1. Create a WMS service with system-generated capabilities files.
  2. Create an SLD XML document that defines multiple styles for each layer in the WMS service.
  3. Bind the SLD XML with the WMS service.
To accomplish this, follow these steps:
In ArcGIS Server Manager:
  1. Publish a WMS service, following the guidelines highlighted in WMS services.
  2. Create an XML document in SLD syntax that defines additional styles for each WMS layer you want to publish. You can save this SLD XML document to the local disk or make it accessible as a URL.
  3. Open Manager and log in. If you need help with this step, see Log in to Manager.
  4. Click Services > Manage Services.
  5. In the Manage Services module, locate your service and click Edit . If you don't see your service in the list, it may be in a subfolder under the Site (root) folder.
  6. In the Edit module, click Capabilities.
  7. In the capabilities list, click WMS and verify that WMS is enabled.
  8. In the WMS configuration list, you will see the SLD Path or URL text box. Type the URL of your SLD XML document or use the file browser to locate your SLD XML on disk.
  9. Click Save and Restart. The edits to your service are applied immediately.
Notes:
To make sure the SLD XML is correctly bound with the WMS service, do one of the following:
  • Issue a WMS GetCapabilities request in the browser. In the XML response, there should be one <Style> element being advertised for each additional style you defined in the SLD for each WMS layer.
  • Examine the folder <map_service_output_directory>\<service_name_MapServer>\wms\. There should be one legend image file being generated for each additional style you defined in the SLD for each WMS layer.
  • The WMS service will need to download and process the file if the SLD path is pointing to a URL. In cases of errors, the WMS service will not advertise styes defined in the external SLD.
Using external SLDs from the client side
With WMS services, users are not limited to the styles published on the server. Clients can reference an applicable SLD file in the WMS GetMap request so that the WMS service renders the map using their own styles.
Using an external SLD from the client side involves the following steps:
  1. Create an SLD XML document that defines multiple styles for each layer in the WMS service, or you can use a public SLD XML if it's applicable to your WMS service.
  2. Make the SLD XML accessible through a URL that is accessible to the server (if you use a public SLD XML, make sure it's accessible as a URL).
  3. Change the values of the LAYERS and STYLES parameters in the original WMS HTTP GetMap request to indicate which style the WMS server should use to render each layer.
  4. Send the SLD XML to the WMS server and request the map by adding one more key-value parameter pair (SLD=<sld_xml_url>) to the end of a WMS HTTP GetMap request string.
How SLD_BODY works
An alternative to sending SLD styles to the server is to use the standard WMS GetMap request parameter SLD_BODY. Unlike the parameter SLD, the value of SLD_BODY contains the actual XML body of an SLD document. By using SLD_BODY, it is possible for a client to dynamically modify the WMS layer styles without the SLD document being exposed through a public URL.
Currently, few desktop WMS clients support SLD_BODY. Most of the practical use cases for SLD_BODY are in web clients such as OpenLayers and the ArcGIS Maps SDK for JavaScript, with which application developers have the flexibility to modify the GetMap request to append SLD_BODY.
Using SLD_BODY from the client side involves the following steps:
  1. Create an SLD XML document that defines multiple styles for each layer in the WMS service, or you can use a public one, as long as you can access the SLD XML.
  2. Change the values of the LAYERS and STYLES parameters in the original WMS HTTP GetMap request to indicate which style the WMS server should use to render each layer.
  3. Send the SLD XML to the WMS server and request the map by adding one more key-value parameter pair (SLD_BODY=<sld_xml_body>) to the end of the WMS HTTP GetMap request string.
SLD_BODY examples
Sample request 1:
http://gisserver.example.com:6080/arcgis/services/OGC/SanFrancisco/MapServer/WMSServer?LAYERS=highways&STYLES=style_sld_body&TRANSPARENT=true&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&CRS=CRS%3A84&SLD_BODY=%3Csld%3AStyledLayerDescriptor%20xmlns%3Asld%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22%20version%3D%221.0.0%22%20xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%20http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.0.0%2FStyledLayerDescriptor.xsd%22%20xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%20xmlns%3Agml%3D%22http%3A%2F%2Fwww.opengis.net%2Fgml%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Ehighways%3C%2Fsld%3AName%3E%3Csld%3ANamedStyle%3E%3Csld%3AName%2F%3E%3C%2Fsld%3ANamedStyle%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Estyle_sld_body%3C%2Fsld%3AName%3E%3Csld%3ATitle%3Eroad_types%3C%2Fsld%3ATitle%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Csld%3AName%3Ecalles%3C%2Fsld%3AName%3E%3Csld%3ATitle%3Ecalles%3C%2Fsld%3ATitle%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FFFF00%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linejoin%22%3Eround%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linecap%22%3Eround%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3Csld%3ARule%3E%3Csld%3AName%3Eautopista%3C%2Fsld%3AName%3E%3Csld%3ATitle%3Eautopista%3C%2Fsld%3ATitle%3E%3Cogc%3AFilter%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3EROAD_TYPE%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3EMajor%20Roads%2FHighways%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%230000FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linejoin%22%3Eround%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linecap%22%3Eround%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3Csld%3ARule%3E%3Csld%3AName%3Erampa%3C%2Fsld%3AName%3E%3Csld%3ATitle%3Erampa%3C%2Fsld%3ATitle%3E%3Cogc%3AFilter%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3EHWYNAME%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ERAMP%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%2300FF00%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linejoin%22%3Eround%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linecap%22%3Eround%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&BBOX=-122.64942090625,37.6087920625,-122.25391309375,37.8724639375&WIDTH=1152&HEIGHT=768
Response to sample request 1:
Sample request 2:
http://gisserver.example.com:6080/arcgis/services/OGC/SanFrancisco/MapServer/WMSServer? LAYERS=pizzastores&STYLES=style_sld_body&TRANSPARENT=true&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&SLD_BODY=%3Csld%3AStyledLayerDescriptor%20xmlns%3Asld%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22%20version%3D%221.0.0%22%20xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%20http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.0.0%2FStyledLayerDescriptor.xsd%22%20xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%20xmlns%3Agml%3D%22http%3A%2F%2Fwww.opengis.net%2Fgml%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Epizzastores%3C%2Fsld%3AName%3E%3Csld%3ANamedStyle%3E%3Csld%3AName%2F%3E%3C%2Fsld%3ANamedStyle%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Estyle_sld_body%3C%2Fsld%3AName%3E%3Csld%3ATitle%3Epizza%3C%2Fsld%3ATitle%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Csld%3AName%3Edefault%3C%2Fsld%3AName%3E%3Csld%3APointSymbolizer%3E%3Csld%3AGraphic%3E%3Csld%3AExternalGraphic%3E%3Csld%3AOnlineResource%20xlink%3Atype%3D%22simple%22%20xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22%20xlink%3Ahref%3D%22http%3A%2F%2Fzeon%2Fresources%2Fsld%2Fsanfrancisco%2Fimages%2Fpizza.gif%22%2F%3E%3Csld%3AFormat%3EGIF%3C%2Fsld%3AFormat%3E%3C%2Fsld%3AExternalGraphic%3E%3Csld%3AOpacity%3E1%3C%2Fsld%3AOpacity%3E%3Csld%3ASize%3E12%3C%2Fsld%3ASize%3E%3Csld%3ARotation%3E0%3C%2Fsld%3ARotation%3E%3C%2Fsld%3AGraphic%3E%3C%2Fsld%3APointSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&BBOX=-122.64942090625,37.6087920625,-122.25391309375,37.8724639375&WIDTH=1152&HEIGHT=768
Response to sample request 2:
Sample request 3:
http://gisserver.example.com:6080/arcgis/services/OGC/SanFrancisco/MapServer/WMSServer? LAYERS=blockgroups&STYLES=style_sld_body&TRANSPARENT=true&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326&SLD_BODY=%3Csld%3AStyledLayerDescriptor%20xmlns%3Asld%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22%20version%3D%221.0.0%22%20xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%20http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.0.0%2FStyledLayerDescriptor.xsd%22%20xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%20xmlns%3Agml%3D%22http%3A%2F%2Fwww.opengis.net%2Fgml%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Eblockgroups%3C%2Fsld%3AName%3E%3Csld%3ANamedStyle%3E%3Csld%3AName%2F%3E%3C%2Fsld%3ANamedStyle%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Estyle_sld_body%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Csld%3AName%3E0%20-%20784%3C%2Fsld%3AName%3E%3Csld%3ATitle%3E0%20-%20784%3C%2Fsld%3ATitle%3E%3Cogc%3AFilter%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3APropertyIsBetween%3E%3Cogc%3APropertyName%3EPOP1990%3C%2Fogc%3APropertyName%3E%3Cogc%3ALowerBoundary%3E%3Cogc%3ALiteral%3E0%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3ALowerBoundary%3E%3Cogc%3AUpperBoundary%3E%3Cogc%3ALiteral%3E784%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3AUpperBoundary%3E%3C%2Fogc%3APropertyIsBetween%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23FFFF80%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF3300%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linejoin%22%3Eround%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linecap%22%3Eround%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3C%2Fsld%3ARule%3E%3Csld%3ARule%3E%3Csld%3AName%3E785%20-%201571%3C%2Fsld%3AName%3E%3Csld%3ATitle%3E785%20-%201571%3C%2Fsld%3ATitle%3E%3Cogc%3AFilter%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3APropertyIsBetween%3E%3Cogc%3APropertyName%3EPOP1990%3C%2Fogc%3APropertyName%3E%3Cogc%3ALowerBoundary%3E%3Cogc%3ALiteral%3E785%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3ALowerBoundary%3E%3Cogc%3AUpperBoundary%3E%3Cogc%3ALiteral%3E1571%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3AUpperBoundary%3E%3C%2Fogc%3APropertyIsBetween%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23F7C348%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%230033FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linejoin%22%3Eround%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linecap%22%3Eround%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3C%2Fsld%3ARule%3E%3Csld%3ARule%3E%3Csld%3AName%3E1572%20-%204737%3C%2Fsld%3AName%3E%3Csld%3ATitle%3E1572%20-%204737%3C%2Fsld%3ATitle%3E%3Cogc%3AFilter%20xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3APropertyIsBetween%3E%3Cogc%3APropertyName%3EPOP1990%3C%2Fogc%3APropertyName%3E%3Cogc%3ALowerBoundary%3E%3Cogc%3ALiteral%3E1572%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3ALowerBoundary%3E%3Cogc%3AUpperBoundary%3E%3Cogc%3ALiteral%3E4737%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3AUpperBoundary%3E%3C%2Fogc%3APropertyIsBetween%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23C46D1B%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%2333FF00%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E1%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linejoin%22%3Eround%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-linecap%22%3Eround%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&BBOX=-122.64942090625,37.6087920625,-122.25391309375,37.8724639375&WIDTH=1152&HEIGHT=768
Response to sample request 3:
