View machine information in Manager
For each ArcGIS Server machine participating in your site, you can view information such as the name of the machine, current status, time at which the machine was last started, and the machine's operating system platform using ArcGIS Server Manager.
To view machine information, follow the steps below.
  1. Open ArcGIS Server Manager and log in. If you need help with this step, see Logging in to Manager.
  2. Click Site > Machines.
  3. On the Machines module, locate the name of the machine for which you want to view information and click Info .
  4. On the Machine Information dialog box, review the following:
    • Name: The fully qualified name of the ArcGIS Server machine.
    • Status: Indicates whether the current status of the ArcGIS Server machine is started or stopped.
    • Running Since: Indicates the time at which the ArcGIS Server machine was last started.
    • Platform: Indicates the operating system platform that is currently running on the ArcGIS Server machine.
  5. When you're finished reviewing machine information, click OK.
    At 10.6.1 and later, you can view hardware information for a given machine using the Hardware Configuration resource in the ArcGIS Server Administrator Directory.
