View software authorization metadata in Manager
You can use ArcGIS Server Manager to view the license level, license expiration date, software version, and extensions you've authorized to work with ArcGIS Server. To view software authorization metadata, follow these steps:
Open Manager and log in.
Click Site > Software Authorization.
In the Software Authorization module, review the software authorization metadata.
The extensions information is retrieved from your ArcGIS Serverauthorization file. If you've authorized an extension but don't see it in the list, contact Esri Support to ensure that your authorization file is valid and includes access to the desired extension.
If you want to modify the edition, level, and extensions for which your server is licensed, run the authorizeSoftware script from the <ArcGIS Server installation directory>/arcgis/server/tools directory. Once you've updated your licensing, you'll need to restart ArcGIS Server for the changes to take effect.
If you want to modify the edition, level, and extensions for which your server is licensed, launch the Software Authorization Wizard from Programs > ArcGIS > ArcGIS Server > Software Authorization. Once you've updated your licensing, you'll need to restart ArcGIS Server for the changes to take effect.
