View the analysis history
Analysis history tracks analysis runs in a web map, including successful and unsuccessful runs. You can view detailed information about each analysis run and reopen the analysis with the same settings you previously used. You can use analysis history to troubleshoot errors, reopen tools and raster functions with the settings used in a previous run, and document or share an analysis workflow. The analysis history is visible to users who view a shared web map.
When you run a tool or raster function in a web map, an entry is added to the Analysis pane under History.
History entries
Each history entry maintains detailed information about the analysis run, including the following:
  • The input, output, and other parameter settings.
  • Any environment settings.
  • When the analysis was run, when the analysis finished running, and how long it took to run.
  • The run ID if applicable. This is a unique identifier for most analysis runs.
  • Whether the analysis completed successfully or failed.
    The status of an analysis run is saved when you save a web map. If you last saved a web map and the analysis is still running, you won't see an updated status the next time you open the map.
  • Any information, warning, or error messages.
  • Links to created items.
Cancel an analysis
To cancel an analysis that is still running, complete the following steps:
  1. On the Settings (light) toolbar, click Analysis .
  2. Click History .
  3. Click Cancel .
    A dialog box appears where you can confirm the cancellation.
  4. If you are sure you want to cancel, click Cancel analysis. To continue with the analysis, click Keep running.
Not all analyses can be canceled. Analyses that cannot be canceled will have an information icon instead of a cancel button.
Manage history
If you open a saved web map at a later time to continue your work, the analysis that you previously ran in the web map will be available in the analysis history. You can complete the following operations on any analysis history item:
  • View details—Shows the messages, inputs and outputs, analysis run parameters, analysis run time, and credits.
  • Reopen analysis runs—Reopens the tool or raster function with populated parameters.
  • Remove analysis runs from history—Deletes the history entry from the history. This does not delete the resulting layers and outputs.
View the analysis details
The analysis details store information about each analysis run, including the result layer created from a successful run, messages that can be used to troubleshoot errors, and a summary of the analysis parameters.
To view the details of an analysis, complete the following steps:
  2. Click History .
    All successful and unsuccessful analyses runs from the web map are listed. You can learn more about an individual analysis run.
  3. Click Options.
  4. Click View details.
    For successful analysis runs, the analysis details open on the Results tab. For runs that failed or were canceled, the analysis details open on the Messages tab.
  5. Click the Results tab.
    The Results tab displays the result layer from the selected analysis run. You can use the Results tab to zoom to the result layer or open the result table, add the layer or table to the map, or open the item page.
  6. Click the Messages tab.
    The Messages tab provides information about when the analysis was run, the run time, the number of credits consumed for successful runs, and error messages for unsuccessful runs.
  7. Click the Parameters tab.
    The Parameters tab provides a summary of the configurations used to run the analysis.
Some input parameter values may not appear exactly as they appear in the tool or raster function pane, such as the following:
  • If you use a processing extent from another layer, the layer URL is not displayed. Instead, the extent values for the layer that was specified are provided.
  • If you use a processing extent derived from the display extent, the extent values from the display extent at the time the analysis was run are provided.
  • If you use an output spatial reference from another layer, the layer URL is not displayed. Instead, the spatial reference for the layer that was specified is provided.
  • Some parameters may show a JSON or list representation of the input values.
Reopen an analysis run
To reopen an analysis run, complete the following steps:
  2. Click History .
  3. Click Options.
  4. Click Open tool.
    The tool or raster pane appears with the configurations used when the analysis was run.
You must provide a new output name to rerun the tool or raster function.
Renaming a sketch layer will break existing references to the layer by previous tool runs. The input layer will show an error if the tool pane is reopened from the analysis history.
If you open a tool or raster function that had a filter applied to an input layer, the filter will not be honored when you rerun the analysis. An analysis only honors the filter that is currently applied to the layer in the map.
If a map has been shared with you and you don't have the privileges or license required to rerun a tool or raster function, you can't reopen it from the analysis history. Similarly, some tools have parameters that require specific privileges or licenses to run them. You can reopen these tools, but the parameter will be set to a value that you have privileges for.
Remove an analysis run
To remove an analysis run from the analysis history, complete the following steps:
  2. Click History .
  3. Click Options.
  4. Click Remove.
The analysis run is removed from the analysis history.
Save the analysis history
The analysis history is saved when you save a web map.
If you save a map while an analysis is running, the status for that analysis run is saved as in progress. To avoid having erroneous states, save the map after the analysis run has completed.
Share the analysis history
When you save a web map, the history is saved with it. When you share a web map with history, users can view details of the history and reopen parameters.
If you share a web map with everyone, the history can be viewed by users outside of your organization.
If you don't have the privileges or license required to run a tool or raster function, you can't reopen it.
Some tools have parameters that require specific privileges or licenses to run them. You can reopen these tools, but the parameters will be set to a value that you have privileges for.
