AO_100049: There are no features in the processing extent for any input layers
The input layer geometry is not within or intersecting the extent layer.
Solution
To troubleshoot and resolve the error, do the following:
  • If the tool has an extent layer option, verify that the input layer is within the bounding areas of the chosen extent layer.
  • Verify which option is used in the Processing extent environment setting. If an option other than Full extent is used, verify that the input layer contains features within the specified extent. If there are no features within the processing extent, update the environment setting and run the tool again.
