AO_1536: The analysis options you selected require a minimum of 60 points to compute hot and cold spots
The input layer requires at least 60 points to perform hot spot analysis.
Solution
To resolve the error, do one of the following:
  • Use an input layer with 60 or more points.
  • Verify if there is a filter on the data. If there is, remove or edit the filter so the layer includes at least 60 points.
  • Verify which option is used in the Processing extent environment setting. If an option other than Full extent is used, verify that the input layer contains at least 60 features within the specified extent. If there are not 60 features within the processing extent, update the environment setting and run the tool again.
