Understand credits for spatial analysis
Credits are the currency used across ArcGIS and are consumed for specific transactions, such as performing spatial analysis. In ArcGIS Enterprise, most tools can be run without consuming credits. Credits are only consumed if ArcGIS Enterprise is configured to use services from ArcGIS Online and a tool is run using the ArcGIS Online service. The credits will be consumed from the ArcGIS Online organization from which the service originates.
Credits will only be consumed for successful analysis jobs. Credits will not be consumed when the analysis fails or is cancelled.
If your organization has enabled credit budgeting and the expected number of credits exceeds the number of credits allocated to you, an error message appears and prevents you from submitting the job.
Tools that consume credits
Depending on your ArcGIS Enterprise service configuration, the following tools may be run using services from ArcGIS Online:
Tool
Credits used
Summarize Nearby
ArcGIS Online routing services (used if a travel mode is chosen for Measurement type)
0.5 credits per service area
Geocode Locations from Table
ArcGIS World Geocoding Service (used if Esri World Batch Geocoder is chosen for Locator)
40 credits per 1,000 geocodes
Enrich Layer
ArcGIS GeoEnrichment Service
10 credits per 1,000 attributes (data variables multiplied by total feature records)
Find Hot Spots
ArcGIS GeoEnrichment Service (used if Esri Population is chosen for Divide by)
Find Outliers
Choose Best Facilities
0.1 credit per allocated demand point
Generate Travel Areas
Plan Routes
1 credit per vehicle route
Find Closest
0.5 credits per closest facilities route
Calculate Travel Cost
0.005 credits per route
Custom web tools
Custom web tools created in ArcGIS Notebooks consume credits for tools using services from ArcGIS Online as described in Tools that consume credits.
Custom web tools created in Notebooks are hosted as tool items.
Learn more about custom web tools
