Work with layers in scenes
With the Layer Manager tool
on the Designer toolbar, you can configure layers in a scene such as layer style, properties, and options.
To work with layers, complete the following steps:
Verify that you are signed in to the portal and open Scene Viewer.
On the Designer toolbar, click Layer Manager
to open the Layer Manager pane.Configure the layers in the scene.
Click Save
to save the changes to the layers.
You can configure the layers with the Layer Manager tool
using the following layer elements:
Layer element |
Description |
Layer style |
Style and explore layers through smart mapping styles and discover themes and patterns in the data. |
Layer properties |
Depending on the layer type, change the layer properties in scenes, such as configure pop-ups, set visibility ranges, and define filters. |
Layer options |
Adjust the layer options such as layer order, visibility, and group layers. |
Configure ground |
Configure ground in a scene by changing elevation layers or how you display and interact with the ground. |
When you hover over a layer, you can set the visibility of the layer by turning the visibility toggle button on or off. Layers that are visible in the scene display the Visible layer button
, while hidden layers display the Hidden layer button
