Style point layers
In Layer style
, you can create custom visualizations in your scenes by applying smart mapping styles to your data. Change the appearance of feature or scene layers with point data using point styles. You can choose styles that use attributes to apply continuous colors or individual colors to points, or choose styles that apply a single color to all the points.
2D Marker
Use the 2D Marker style when the location of the features takes priority. Retail store locations across the country or parks in a city are suitable for this style. For example, if you have hospital locations across your city, and you zoom out to a regional view, the markers stay the same size on the screen and the user can readily identify the hospital locations in your city.
Follow the steps in the Style layers workflow.
For Marker, choose from a gallery of shapes and icons for your marker.
Choose either Basic Shapes or Icons from the drop-down menu. For example, markers under can show different points in a scene, such as airports or gas stations.
You can also upload a custom marker from your desktop. See Upload a custom marker.
For Color, click the color picker.
Do any of the following:
Click Fill color
to see the fill color options:Choose a color in the color picker.
Create a custom color by the Hex, RGB, or HSV values.
Under Saved, you can apply saved colors. Click
or
to add or remove a color.Click Done to apply the settings and return to the previous pane.
The most recent fill colors are shown.
Click No color
to choose no fill color. The Fill transparency setting becomes disabled.Click Fill transparency to set the transparency with the slider or by entering values.
Click Outline color to see the outline color options:
or
to add or remove a color.Click Done to return to the previous pane.
The most recent outline colors are shown.
Click No color
to choose no outline color. The Outline transparency and Outline width settings become disabled.Note:
Markers under Icons do not include outline options.
Click Outline transparency to set the transparency with the slider or entering values.
Click Outline width to set the outline width using the slider or by entering values.
Click Cancel to return to the previous pane without applying the color settings.
For Size, change the size of the marker by manually entering the size in pixels.
For Callout, see Insert callouts.
For Labels, see Apply labels.
For Declutter, click the toggle button to remove overlapping features as you navigate the scene.
For Improve perspective, click the toggle button to turn perspective scaling on and off for screen-size point markers.
When Improve perspective is on, objects such as icons, labels, and callouts integrate better in the 3D scene by having a smaller size the farther away they are from the camera position.
3D Object
Use the 3D Object style to symbolize real-world-sized objects in your scene. You can set an attribute to provide the real-world size of those objects. A good example of this is displaying trees in a city park where you can size each tree feature by the height attribute.
For Marker, choose from a gallery of 3D objects.
Choose from 3D objects grouped into themes. For example, with Vegetation markers, you can display a variety of plants and trees. If your organization configured web styles, you can select custom markers from styles created from ArcGIS Pro.
To get the complete set of 3D symbology in your scenes, such as vegetation, install the web style setup. For additional information, see Scene Viewer requirements.
Click Fill color
or
Click No color
For Size, set the size of the 3D objects. Click the drop-down menu and do any of the following steps:
Under Fixed size, click <Fixed size> to enter a uniform size. As you zoom in and out, click the Fit to view
button to adjust the 3D objects to the appropriate size in the current view.Under Expression, create an expression to set the size of the 3D objects:
Click Create expression to open a window to create an Arcade expression.
Provide a title for the new expression at the top.
Create a custom expression in the editor.
After the expression is created, click Edit
to edit the expression.Choose the measurement unit.
Under Attributes, click an attribute from the list to set the size of the 3D objects. Choose the measurement unit.
When an expression or attribute is selected under Choose the main attribute to visualize in the style gallery, the size is set to the values of the chosen expression or attribute. The Size drop-down menu is unavailable. You can still, however, modify the unit.
To enable the Size drop-down menu, return to the style gallery and select <none> under Choose the main attribute to visualize.
Optionally, click the Rotation drop-down menu to rotate your 3D objects based on an attribute.
Rotate your 3D objects using either the Geographic (Clockwise from 12) or Arithmetic (Counterclockwise from 3) method. If you don't want to rotate your objects, choose <None> from the drop-down menu.
2D Counts and Amounts
Use the 2D Counts and Amounts style if you have data, such as demographic data, and want to display it with 2D markers. For example, you can display average income levels in communities with a sequence of colors and objects, such as from light color and small size to dark color and large size. There is a selection of color ramps and solid colors from which to choose to best fit your scene.
The 2D Counts and Amounts pane appears with the Mapped Attribute box displaying the chosen expression or attribute.
Move the upper and lower slider handles to adjust the color and size based on the chosen expression or attribute.
See Counts and Amounts slider considerations for more information.
For Marker, choose from a gallery of 2D shapes and icons.
Click Fill color
to see the fill color options:Under Category, select the types of color ramps from which you want to choose.
Click Flip ramp colors
to flip the colors.Click Done to return to the previous pane.
or
Click No color
Click Solid color to change the ramp to a solid color and display the fill options.
Under Fill color do any of the following:
or
Click one of the recent fill colors.
Click No color
For Size(Min - Max), choose how you want to size your markers.
Scene Viewer automatically provides a default range of pixel sizes. The Size(Min - Max) fields show the minimum and maximum size for your range of markers in pixels.
3D Counts and Amounts
Use the 3D Counts and Amounts style to symbolize your point data with real-world dimensions. For example, if you have data of city assets such as fire hydrants, you can present the hydrants as tall cylinders based on water capacity. Consequently, the hydrants with a larger capacity will have a darker color and larger size than those with lower capacity.
The 3D Counts and Amounts pane appears with the Mapped Attribute box displaying the chosen expression or attribute.
For Marker, choose a 3D model with simple geometry such as cones or cylinders.
Click Fill color
or
For Size(Min - Max), choose how you want to size your 3D objects.
As you zoom in and out, click the Fit to view button
to adjust the 3D objects to be appropriately sized in the current view. The Size(Min - Max) fields show the minimum and maximum real-world sizes of your objects.- For example, if you have a point layer with traffic counts for intersections displayed as tall cylinders, you may need to change the size of the cylinders as you zoom in and out. To do this, first click the Fit to view button
to scale the cylinders to your current view. Then fine-tune the cylinders by changing the Size(Min - Max) values.
Setting the Size option using an expression or attribute is unavailable for point layers.
For Rotation, you can rotate your objects based on an attribute.
2D Types
Use the 2D Types style when you have point data with either text or numeric attributes. You can show attribute values with different markers, colors, and sizes. For example, you can use the 2D Types style to display points of interest in a city with unique symbology.
The 2D Types pane appears with the Mapped Attribute box displaying the chosen expression or attribute.
Modify the Attribute Values list.
The most common attribute values are listed. The remaining attribute values are automatically grouped into the Other section. By default, the attribute values are listed in descending order by number of features, which is listed next to it. The total number of features is displayed at the top of the list.
Click an attribute value to modify.
Change the symbology.
Drag the attribute value to change the order in the list and in the legend.
Rename an attribute value by selecting it and clicking the name
Click Select all at the top of the list to modify all values.
To return to modifying an individual value, click a value or click Select one at the top of the list.
Modify attribute values in the Other section.
Drag individual attribute values in and out of the main list
Click Select all to drag all values.
Click the show
or hide
buttons to show or hide features that are in the Other section. By default, these attribute features are hidden. Features that are hidden and dragged to the main list become visible in the scene and in the legend.
Tip:
Ideally, your layer should show fewer than 10 values; more than 10 are difficult for users to distinguish.
For Marker, choose from a gallery of markers.
Choose either Basic Shapes or Icons from the drop-down menu. For example, markers under Icon can show different points in a scene, such as airports or gas stations.
Click Fill color
or
Click No color
to choose no fill color. The Fill transparency becomes disabled.Click Fill transparency to set the transparency with the slider or by entering values.
or
Click No color
to choose no fill color. The Outline transparency and Outline width settings become disabled.Note:
For Declutter , click the toggle button to remove overlapping features as you navigate the scene.
3D Types
Use 3D Types when you have point data with either text or numeric attributes. You can show individual symbology with different 3D objects, colors, and sizes. For example, you can use the 3D Types style to uniquely show 3D objects for different types of street furniture.
The 3D Types pane appears with the Mapped Attribute box displaying the chosen expression or attribute.
Click the show
or hide
Tip:
Click Fill color
or
Click No color
For the Size option in the table, set the size of the 3D objects.
As you zoom in and out, you can click the Fit to view button
to adjust the 3D objects to the appropriate size in the current view.When an expression or attribute is selected in the Size option under All markers, you can no longer individually set the 3D object sizes in the table. Change the Size option to <None> to set the sizes individually.
For the Size option under All markers, use an expression or attribute to size the 3D objects.
Under No attribute, click <None> to enter a uniform size in the table.
Under Expression, create an expression to set the sizes:
Under Attributes, click an attribute from the list to set the sizes. Choose the measurement unit.
For the Rotation option under All markers, set rotation of the objects by attribute.
Click the Rotation drop-down menu and choose an attribute on which to base the rotation.
