Configure maps and scenes
Members of the default administrator role or custom roles with the appropriate administrative privileges can choose which basemaps your organization uses to create maps, scenes, and apps. You can also set the default basemap, extent, and units.
  1. Verify that you are signed in as a member of the default administrator role or custom role with administrative privileges to manage the organization website.
  2. At the top of the site, click Organization and click the Settings tab.
  3. Click Map and scene on the side of the page.
  4. Configure any of the following map settings:
Basemap gallery for maps and scenes
To specify the basemap gallery used in Map Viewer, under 2D Group, click the Edit button to open the drop-down menu and select the group that contains the maps that will be used as basemaps:
  • Choose Esri default to use only default vector basemaps.
  • Specify a custom basemap gallery group in your organization to include basemaps shared with it.
If you specified a custom basemap gallery group, you can click Share basemaps to share the Esri default basemaps with the group.
To specify the basemap gallery used in Scene Viewer, under 3D Group, click the Edit button to open the drop-down menu and select the group that contains the web scenes that will be used as basemaps:
If you specified a custom basemap gallery group, you can click Share 3D basemaps to share the Esri default basemaps with the group.
For both 2D and 3D custom groups, you can also change how the basemaps are sorted in the gallery by selecting a field and a sort option from the drop-down menus under Sort order. If you change the sort field or order here, the items on the group page, as well as in embedded galleries or gallery apps, are also changed.
You can specify a different basemap gallery for Map Viewer than for Scene Viewer. The Scene Viewer basemap gallery only displays basemaps that are supported in Scene Viewer. Basemaps must meet Scene Viewer tiling scheme requirements to display in the Scene Viewer basemap gallery.
Custom 3D basemaps are not supported in Scene Viewer. The 3D Group section can be used to select a subset of 3D basemaps provided by Esri for use with Scene Viewer.
By default, 3D basemaps provided by Esri are available and can be used in web scenes. To hide these basemaps from users, turn off the Use 3D basemaps toggle button in the 3D Group section.
Map and scene defaults
If you chose a custom 2D basemap group for the Basemap gallery setting, choose a basemap from that group that you want opened when users create a map with Map Viewer. Similarly, if you chose a custom 3D basemap group for the Basemap gallery setting, choose a basemap from that group that you want opened when users create a scene with Scene Viewer. If you chose Default as the basemap gallery (for both maps and scenes), the default Esri basemap will be displayed for new maps and scenes. If you chose None for the default 3D basemap, the default 2D basemap will be used in new scenes.
Scene Viewer only uses the specified default basemap if it is a supported web scene.
The default basemap opens at the default extent you set. To set the default extent to the extent of your currently selected default basemap, click Use map extent as default. To set a different extent, click Edit extent in the Default extent section. Choose from the following options:
  • To create an extent based on the default extent specified for the organization, click Organization's extent.
  • To navigate to a place or address, under Use location search, type keywords in the search box. Keywords can include addresses, street intersections, places, points of interest, and longitude and latitude coordinates. The extent centers on the place or address you specify.
  • To draw a shape representing the extent, click Draw Extent and drag a box on the map. Make changes to the extent as needed by dragging any of the vertices of the extent box or clicking inside the box and dragging it to a new location.
  • To create an extent by specifying coordinate values (in decimal degrees) for the extent boundaries, click Coordinates and type the coordinates in the Top, Bottom, Left, and Right boxes.
Once you have set the extent, click Save.
Under Units, choose U.S. Standard or Metric as the default units for the map scale bar, measure tool, directions, and analysis. U.S. Standard sets the units to miles, feet, and inches; Metric sets the units to kilometers, meters, and centimeters. Users can set the units they see through their settings page.
Google Photorealistic 3D basemap (preview)
The Google Photorealistic 3D basemap (preview) provides a seamless, high-resolution 3D model of the real world, allowing you to create engaging and realistic 3D scenes.
To enable the Google Photorealistic 3D basemap, you must first configure the setting in your ArcGIS Online organization by completing the following steps:
  1. Verify that you are signed in to your ArcGIS Online organization as a member of the default administrator role or a custom role assigned the set of privileges to manage the organization's website settings.
  4. Under Google Photorealistic 3D basemap, turn on the Allow members to use Google Photorealistic 3D basemap toggle button.
    This creates a Google Map Tiles API key that is managed by your ArcGIS Online organization.
  5. Turn on the Allow use in ArcGIS Enterprise and custom applications toggle button.
  6. Under Allowed referrers, click Add allowed referrers.
  7. Provide your ArcGIS Enterprise organization URL and click Add referrer.
Once you've completed these steps in your ArcGIS Online organization, you can enable the Google Photorealistic 3D basemap for your ArcGIS Enterprise organization by clicking Enable and providing your ArcGIS Online administrator account credentials. When enabled, the Google Photorealistic 3D basemap is supported in ArcGIS Pro 3.6 and later, Scene Viewer, and select apps, including ArcGIS Dashboards, ArcGIS Experience Builder, ArcGIS Instant Apps, and ArcGIS StoryMaps.
The Google Photorealistic 3D basemap usage is tracked by session, and each organization has access to up to 20,000 sessions during the preview period. A session starts when you add the basemap to a 3D-capable app and ends after three hours or when you close the app. In a web browser, refreshing the page does not reset the session unless you turn off or manually clear the browser cache. Sessions are tracked at the organization level and cannot be monitored for individual organization members. They also cannot be tracked separately between ArcGIS Online and ArcGIS Enterprise because the Google Map Tiles API key that tracks the session count is shared across both environments.
The Google Map Tiles API key is managed by your ArcGIS Online organization, where you can view its overall session usage by completing the following steps:
  4. Under Google Photorealistic 3D basemap, click Session usage to view the session usage chart.
    You can view session usage over the last 7, 14, or 30 days.
It is recommended that you periodically generate a new Google Map Tiles API key. Refer to the ArcGIS Online documentation for instructions on generating a new API key.
Web styles
Web styles are collections of symbols created in ArcGIS Pro and stored as items. Apps such as Map Viewer and Scene Viewer can use web styles to symbolize features with 2D or 3D symbols.
To include web styles in Map Viewer symbol galleries or in Scene Viewer, do the following:
  1. Create one or more groups.
  2. Share the web style items with the group or groups you created.
    If you are using the group to include 2D web styles in Map Viewer symbol galleries, you must also share the web style items with the public.
  3. At the top of the site, click Organization and click the Settings tab.
    You must be signed in as a default administrator or custom role with administrative privileges to manage the organization website.
  4. Click Map and scene on the side of the page.
  5. Do any of the following:
    • For 2D web styles, click the box under 2D web style group and choose the group you created for the 2D web styles.
    • For 2D sketch web styles, click the box under 2D sketch web style group and choose the group you created for the 2D sketch web styles.
    • For 3D web styles, click the box under 3D web style group and choose the group you created for the 3D web styles.
    The web style items in the specified group are added to the symbol galleries.
