Set transparency and visible range
You can set the transparency and visible range of layers in a map.
Set transparency
Changing the transparency, or opacity, of a layer in a map allows you to see more, or less, of the underlying layers. The transparency of any layer can be adjusted from 0 percent to 100 percent. The more transparent a layer is, the less visible it appears on the map and the more visible the other layers appear. For example, you can highlight a specific layer in the map by making it fully visible and adding transparency to the other layers.
You can set the transparency for the entire layer or if the data includes numeric or date attributes, based on one of these attributes.
Tip:
To fine-tune how layers are drawn in relation to one another, you can use blend modes. You can also combine transparency with feature-specific effects to highlight a subset of features in a layer.
Set transparency for the layer
Set transparency for the layer in the Properties pane
Tip:
For recommendations on applying transparency to high-density datasets, see Best practices for visualizing high-density data.
To set transparency for the layer, complete the following steps:
  1. Confirm that you are signed in and, if you want to save your changes, that you have privileges to create, update, and delete content.
  2. In Map Viewer, open the map containing the layer, or add the layer directly.
  3. In the Layers pane, click the layer to select it.
  4. On the Settings (light) toolbar, if necessary, click Properties .
  5. In the Transparency section, move the transparency slider to the left (less transparent) or right (more transparent).
  6. If you own the map, click Save and open and click Save on the Contents (dark) toolbar to save the transparency setting to the map.
Set transparency based on attribute values
When styling a layer using most smart mapping styles, you can set the transparency per feature in a layer if you have numeric or date data associated with the locations. Setting the transparency based on attribute values in the data allows you to vary how much transparency is applied to each location based on a numeric attribute. For example, if a layer contains income data, you can adjust the transparency of each location proportional to its income.
Setting transparency based on an attribute value is not supported for categorical imagery layers.
To set transparence based on attribute values, complete the following steps:
  1. Follow the first five steps in the Apply a style workflow.
  2. In the Styles pane, choose a drawing style and click Style options.
  3. In the Style options pane, click Transparency by attribute and turn on the Set transparency based on attribute values toggle button.
    The Transparency by attribute option is not available for some smart mapping styles, including Dot Density and Heat Map.
  4. From the Attribute drop-down menu, choose the numeric or date attribute to use as the basis for the transparency.
    Tip:
    You can use a custom attribute expression written in ArcGIS Arcade instead of an attribute field. Click Use expression , and use the editor window to create the expression.
    You can also use existing expressions to build new expressions; however, some variables may not work in all profiles—for example, an expression created for pop-ups may not work for styles. To use an existing expression, select it from the Suggestions tab under Existing.
  5. Optionally, choose an attribute from the Divided by drop-down menu to use to standardize or normalize the data, such as dividing population by area or costs by total population.
  6. Adjust the position of the slider handles to change how the transparency gradient is applied. Alternatively, click the numeric values next to the slider handles and type precise values. To see details in the histogram more closely, click Magnify slider . To go back to the original slider positions at any time, click Reset slider positions .
  7. For Transparency range, adjust the percent of transparency for the high and low ends of the ramp. Note that 0 percent transparency is a solid color (fully opaque).
  8. Optionally, turn off the Include in legend toggle button to hide the transparency ramp in the legend.
  9. If you own the map, click Save and open and click Save on the Contents (dark) toolbar to save the transparency setting to the map.
Set the visible range
Multiscale maps allow you to view geographic data across a range of scales—also known as zoom levels—from buildings to the entire globe. Specifying the zoom level at which content is drawn is known as setting the visible range. Because most data does not need to be shown across all zoom levels, it is a good practice to confirm, and if necessary, change the visible range. Your map may contain many layers, each with its own visible range. You can also specify a visible range for labeling features in a layer.
If you are adding data to a map that includes a predefined visible range, the map will use that visible range. To update the visible range, you can set it manually. As a result, when you zoom in and out on the map, different layers on the map may turn on or off depending on their suggested visible range.
Tip:
When a layer is out of range, its name appears in a lighter gray color in the Layers pane than the layers that are in range.
To set the visible range, complete the following steps:
  5. In the Visibility section, do any of the following to set the maximum zoom level:
    • Drag the handle on the slider to the maximum zoom level. Use the maximum zoom scale drop-down menu below the slider to choose the zoom level, for example, World or Country.
    • Click the drop-down menu below the slider, click Custom, and type the maximum zoom level.
    • Click the drop-down menu below the slider, and click Current map view to use the current extent of the map.
  6. Repeat the previous step for the minimum zoom level.
  7. If you own the map, click Save and open and click Save on the Contents (dark) toolbar to save the visible range setting to the map.
Control display filters
Display filters limit which features of a layer are displayed on the map. There are two types of display filters: scale-based display filters and manual display filters. Scale-based display filters are applied by changing the map scale, and manual display filters are controlled by selecting an active display filter in the Visibility section of the Properties pane. Unlike applying filters, display filters only impact the map display. The features filtered from the display by display filters are still available for query and analysis. Features filtered by filter expressions are not available to the layer at all.
Use display filters when you want to draw a subset of features, but you want to retain access to all features. When a display filter is active, all features in the layer remain in the layer's attribute table and can be selected, identified, edited, and used in analysis. However, because only visible features are labeled, display filters affect the labeling of features in a layer.
In Map Viewer, you can control manual and scale-based display filters that have been authored on a layer in ArcGIS Pro.
Display filters are only available in maps and are not available in scenes. If display filters have been disabled at the map level, layer-level display filters cannot be modified and will not be reflected on the map.
To control display filters, complete the following steps:
  5. In the Visibility section, under Display filter, turn on the Enable display filter toggle button if it is not enabled, then click the display filter option you want to show.
    The display filter is applied to the map.
    Scale-based display filters change as the map scale is adjusted.
  6. If you own the map, click Save and open and click Save on the Contents (dark) toolbar to save the display filter settings to the map.
