Check for and install software patches and updates
Esri periodically releases software patches and updates for all ArcGIS products, including ArcGIS Enterprise. Patches and updates are announced on the Patches and Updates page on the Esri Support website. You can also check whether updates are available using a patchnotification utility installed with the software.
About the patch notification utility
With the patchnotification utility, you can review available patches, view installed patches and QFEs, validate patch checksums, install available patches, and create patch bundles for use on machines that are connected to or disconnected from the internet.
The utility reports available patches and updates for ArcGIS Enterprise components, including servers and extensions, but excluding ArcGIS Web Adaptor. It also returns information for other ArcGIS products. The utility displays installed patches and QFEs for components installed on the machine.
If multiple ArcGIS Enterprise components are installed, the utility reports patch information for all supported components on the machine. The utility reports the following:
Installed products and ArcGIS Enterprise components
Available patches and updates
Installed patches and QFEs
Product-specific patch details
A link to the Esri Support site for patch information
To review patch descriptions, installation requirements, and additional information, use the provided link.
Access requirements
When using the patchnotification utility to determine the full list of available patches, the utility must have internet access to access the following URL:
https://downloads.esri.com/patch_notification/patches.json
The machine running the patchnotification utility must have access to sites on the esri.com domain over HTTPS (port 443).
To download patches as appropriate, the utility requires access to these locations:
https://gisupdates.esri.com/https://downloads.esri.com/https://support.esri.com/https://content.esri.com/
These URLs cannot be accessed directly and are instead root URLs for endpoints where downloads and patches can be retrieved.
Use the patch notification utility
You can use the patchnotification utility to download and install software patches and updates, such as specific patches, security patches only, or all available patches.
Steps for using the patchnotification utility include reviewing available patches, installing them, and configuring patch download location and retention policy.
To check for and install updates, complete the following steps:
Sign in to the machine where the ArcGIS Enterprise component is installed.
Open the
patchnotificationutility.You can open the utility from the list of installed programs or from the command line (
./patchnotification). To start the tool in console mode, use the-ccommand (./patchnotification -c).The location of the utility depends on the ArcGIS Enterprise components that are installed on the machine. For example, if ArcGIS Server is installed, you can access the utility from the list of installed programs by clicking ArcGIS > ArcGIS Server > Check for ArcGIS Enterprise Updates or from the command line by navigating to the
<ArcGIS Server installation directory>/tools/patchnotificationdirectory.Note:
If your system does not include a display, the utility automatically opens in console mode. The utility running in console mode does not support individual patch installation.
You can open the utility from the Start menu or from the command line (
patchnotification.bat). To start the tool in console mode, use the-ccommand (patchnotification.bat -c).The location of the utility depends on the ArcGIS Enterprise components that are installed on the machine. For example, if ArcGIS Server is installed, you can access the utility from the list of installed programs by clicking Start > All Programs > ArcGIS > ArcGIS Server > Check for ArcGIS Enterprise Updates or from the command line by navigating to the
<ArcGIS Server installation directory>\tools\patchnotificationdirectory.Review the update information. If other ArcGIS Enterprise components are installed on the machine, information for those components also displays. Installed patches are available at the bottom of the dialog box. Click any link on the dialog box to obtain more information and instructions for downloading and installing the update.
To apply a specific patch, click the download button next to the patch you want to install from the utility dialog box. The patch downloads automatically and the patch installation dialog box appears when the download is complete. Follow the instructions to complete patch installation. Optionally, click the Install Security Patches or Install All Patches button on the right side of the dialog box to apply the corresponding updates. If you're running the utility from the command line or in console mode, use
-i secto install only security patches, and-i allto apply all available patches.By default, all downloaded files will be saved and kept in the system temp location, and downloaded patch folders will never be deleted. To change either of these properties, click the Settings button at the bottom of the utility and click the Install Settings tab.
To change the default download location for patches, specify the new download location in the Download folder path. If you're running the utility from the command line or in console mode, use
-dto specify a new download location.To specify that downloaded files and folders be deleted after a successful patch installation, click the Delete patch folder menu and select Always delete after successful installs. If you're running the utility from the command line or in console mode, use
-o alwaysto delete the patch folder after each successful patch installation. By default, this setting is set to-o never.
If the component is installed on multiple machines, such as a portal configured for high availability, apply the same patch or update to all machines.
Click OK to close the patchnotification dialog box.
Configure proxy settings
If your machine accesses the internet through a forward proxy, configure proxy settings before checking for updates.
If you're running the utility from the user interface, follow these steps:
Open the
patchnotificationutility.Click the Settings button at the bottom of the utility dialog box.
On the Proxy Settings dialog box, select Connect through a Proxy Server.
Specify the host name, port, and user credentials (if necessary) of the proxy server.
Click OK to connect to the proxy server.
If you're running the utility from the command line or in console mode, specify the proxy server using the -p command (./patchnotification -p http://<user>:<password>@forwardproxy.server.com:<port>).
Configure trusted certificates for an SSL inspection proxy
If your forward proxy performs SSL inspection, the root or intermediate certificate authority (CA) certificate used by the proxy must be trusted by the Java environment used by the patchnotification utility.
Import the required root or intermediate CA certificate into the ArcGIS Enterprise component with which the patchnotification utility is bundled.
For Portal for ArcGIS, see Import a certificate into the portal.
For ArcGIS Server, see Configure ArcGIS Server with an existing CA-signed certificate.
