Create and install a patch bundle
The patchnotification utility provides an option to create a patch bundle for ArcGIS Enterprise components. These patch bundles can be installed in any environment, but are most useful for disconnected environments that cannot access the patch information directly. For more information about the patchnotification utility, see About the patch notification utility.
To create a patch bundle, the machine on which you run the patchnotification utility must have:
One or more ArcGIS Enterprise installed components
Internet access
The bundled output can then be installed on the same or a different machine in your environment, for example, one without internet access.
Parameters
The following parameters can be used when creating a patch bundle with the patchnotification utility. Parameters can be used to filter patches by product or ArcGIS Enterprise component and to select which patches to include in the bundled output.
| Parameter | Description |
--plan-create |
Creates a patch bundle. |
--products |
Filters patches by product or component. |
--select |
Prompts for patch selection. |
--output |
Specifies the output bundle location. |
Parameter options
When creating a patch bundle, consider the following parameter options:
--productsaccepts component names such asserverandportal.Omit
--productsto use all installed components.Use
--products listto display accepted component names.Omit
--selectto include all matching patches.Existing output files are not overwritten.
After specifying your desired parameters, the utility will download all relevant patches within a single patch bundle.
View patches in a bundle
To view the patches in a bundle that you've already created without installing them, run the following command:
./patchnotification --plan-install --bundle /transfer/patch-bundle.zip --show
patchnotification.bat --plan-install --bundle /transfer/patch-bundle.zip --show
The utility displays the patches included in the bundle and exits without performing any installation.
Create a patch bundle
You can create a patch bundle that contains all available patches or just those for a specific component. Steps are provided for both workflows.
Sign in to the machine where the ArcGIS Enterprise component is running.
You can launch the
patchnotificationutility from the installed programs menu or from the command line. For additional information about running the utility, see Use the patch notification utility.To create a patch bundle that contains only selected patches, specify the component name in your command. For example, if you want to create a bundle for only ArcGIS Server, specify the product as
server.patchnotification.bat --plan-create --products server --select --output /transfer/patch-bundle.zip./patchnotification --plan-create --products server --select --output /transfer/patch-bundle.zipTo create a bundle to only contain all available patches, run the following command:
patchnotification.bat --plan-create --output /transfer/patch-bundle.zip./patchnotification --plan-create --output /transfer/patch-bundle.zip
Install a patch bundle
To install the contents of a patch bundle, run the following command:
The utility validates the bundle and installs the patches included in the bundle.
Install a patch bundle on a disconnected machine
After you've created a patch bundle, you can install it on a machine that does not have access to patch repositories or the internet. To do so, complete the following steps:
Create a patch bundle on a connected machine.
Transfer the patch bundle to the machine you'd like to apply it to.
Use the following command to install the bundle:
patchnotification.bat --plan-install --bundle /transfer/patch-bundle.zip./patchnotification --plan-install --bundle /transfer/patch-bundle.zip
Configure download and installation settings
By default, downloaded files are stored in the system temporary directory and patch folders are retained after installation.
You can configure the download and installation settings by specifying a different location for downloaded files and choosing whether to retain or delete patch folders after installation. Use the following parameters with the patchnotification utility:
Change the download location
To change the location where downloaded files are stored, use the graphical interface or specify a download directory from the command line:
patchnotification.bat -d <download_location>
./patchnotification -d <download_location>
Delete patch folders after installation
To automatically remove downloaded patch folders after successful installation, run the following command:
patchnotification.bat -o always
./patchnotification -o always
The default behavior is to retain patch folders after installation. To retain the patch folders, run the following command:
patchnotification.bat -o never
./patchnotification -o never
Additional considerations
If your ArcGIS Enterprise deployment includes multiple machines, such as a highly available Portal for ArcGIS deployment or multi-machine ArcGIS Server site, apply the same patch level to all participating machines.
Maintain consistent patch levels across all machines in the deployment.
