ArcGIS Data Store deployment modes
The data stores that you deploy with ArcGIS Data Store can be deployed on a single machine or on more than one machine to deliver high availability, scalability, or both. For some types of data stores, the deployment mode you define affects how many machines the data store can contain.
Each data store type has a default mode in which it is deployed. When you create a data store using the Data Store configuration app, the default mode is always used. To create a data store using a mode other than its default mode, you must use the configuredatastore utility.
The following table lists default modes and other options for each ArcGIS Data Store type:
Data store type |
Default mode |
Other mode option |
Notes |
Graph store |
Single instance |
Cluster |
You can change the mode of a graph store from single instance to cluster mode by adding at least two machines to the graph store. You must use the Legacy:Primary-standby mode is no longer supported for the graph store. When you upgrade ArcGIS Data Store to this release, a graph data store configured in primary-standby mode is converted to single instance mode. |
Object store |
Single instance |
Cluster |
Single instance mode supports a single machine. Cluster mode must be deployed with three or more machines. You can change the mode of an object store from single instance to cluster mode by adding at least two more machines to the object store. You must use the |
Relational store |
Primary-standby |
Relational stores can include one or two machines. |
Spatiotemporal big data store |
Cluster |
Spatiotemporal big data stores can contain a single machine or three or more machines. |
Single machine
If you don't need ArcGIS Data Store to be highly available or scalable, you can create each type of data store on a single machine using its default deployment mode.
If you deploy a data store on a single, dedicated machine, ensure that machine has a large amount of disk space and memory.
Considerations
The relational store is deployed in primary-standby mode and the spatiotemporal big data store is deployed in cluster mode, and either one can be extended beyond a single machine at any time.
A single-machine object store deployment performs slightly better than a cluster of object store machines, but only if that single machine has an adequate amount of memory and disk space for all the caches stored in it. You can change the mode of the object store after you deploy it if you later decide you require high availability.
The graph store can also be a single-machine deployment. You can change the mode of the graph store after you deploy it if you later decide you require high availability.
Prior to ArcGIS Data Store 11.2, only single instance mode was available for the graph store. Even when you upgrade your deployment from 11.1 or earlier, the graph store is still in single instance mode.
In primary-standby mode, the relational store can each contain up to two machines. Both machines contain the same data. Hosted web layers access the data on the primary machine. If the primary machine fails, the standby machine becomes the primary machine, and hosted layers access the data on the new primary machine. This allows continuous access to the layers while you, as the ArcGIS Data Store administrator, recover or replace the machine that failed.
The first machine on which you install ArcGIS Data Store and create a relational store is the primary data store machine. You can install and configure one other relational store machine with the same GIS Server site, making this second data store machine the standby machine. Data is replicated from the primary to the standby machine. The standby becomes primary if the primary machine fails.
See Add machines to a data store for more information about implementing a primary-standby relational store.
Failover scenarios
The following is a list of situations for which the standby machine becomes the primary data store. Note that the following situations involve hardware or software failures.
The primary data store stops working. ArcGIS Data Store attempts to restart the data store on the primary machine. If it cannot restart, the data store fails over to the standby.
The primary's web app stops running and attempts to restart the web app on the primary machine. In the rare case that this does not work, the data store fails over to the standby machine.
The primary machine is unavailable. This can happen if the computer crashes, is unplugged, or loses network connectivity. ArcGIS Data Store fails over to the standby machine if three consecutive attempts to connect to the primary machine fail.
The only human-initiated situations that cause a failover are if the primary data store machine is deliberately taken offline, or the ArcGIS Server site administrator runs the makePrimary REST command on the standby machine.
Shutting down a Microsoft Windows machine that is serving as the primary ArcGIS Data Store machine does not cause the data store to fail over because Windows shuts down all services before shutting down the machine. Therefore, if you need the data store to be available while that machine is offline, manually promote the standby machine to primary first and then shut down the former primary ArcGIS Data Store Windows machine.
Additional information
Keep the following in mind:
Primary-standby mode allows hosted layers to be highly available.
You cannot scale beyond two machines.
Even if you use a cloud relational store, you can configure primary and standby relational store machines to provide high availability for additional system stores.
Cluster mode
Cluster mode is available for the object store, graph store, and spatiotemporal big data store to enable high availability. Cluster mode also allows you to scale the deployment to include additional machines as storage needs increase.
In cluster mode, each data store must contain a minimum of three machines. Therefore, install ArcGIS Data Store on three or more machines, configure the same type of data store on each machine, and specify the same hosting GIS Server site when creating the data store.
Cluster mode behavior differs for each type of data store for which it is supported. Use the links below for descriptions of cluster behavior for each data store type:
Graph store clusters
Object store clusters
Spatiotemporal big data store clusters
Even if one machine is lost, data is available on at least one other machine. As long as the other machine is available, the hosted layer is still usable.
You must include a minimum of three machines in a cluster.
