Uninstall ArcGIS Data Store
You can uninstall ArcGIS Data Store for any of the following reasons:
You've moved the data store to another machine and no longer need ArcGIS Data Store installed on the old one.
You decide you do not want a standby machine in the relational store or you want to remove one of the machines from a spatiotemporal big data store, so you remove the data store machine and uninstall ArcGIS Data Store.
You no longer want to use ArcGIS Data Store.
Uninstalling ArcGIS Data Store also unregisters the data store from your GIS Server site. Hosted feature layers that used the data in the data store and caches used by any scene layers you published to your portal will no longer function once you uninstall the software. However, the data still exists because the data store directory remains on the server after you uninstall ArcGIS Data Store. If you later decide you need the feature layers, you can reinstall ArcGIS Data Store and register the data store with the same GIS Server site.
First, remove daemons. Then use one of the uninstallation methods below to uninstall ArcGIS Data Store from a machine.
Remove daemons before uninstalling ArcGIS Data Store
If you configured ArcGIS Data Store to start with the operating system, you must remove the daemons before you uninstall.
Connect to the ArcGIS Data Store machine as the root user.
Remove the daemons by running the commands appropriate for the operating system.
- If the operating system supports systemd, run these commands to remove links in
/etc/systemd/system/multi-user.target.wants
systemctl disable arcgisdatastore.service rm -f /etc/systemd/system/arcgisdatastore.service- If ArcGIS Data Store is installed on a Red Hat Enterprise Linux Server that supports SysV, run the following commands:
chkconfig --del arcgisdatastore rm -f /etc/rc.d/init.d/arcgisdatastore- If ArcGIS Data Store is installed on a SUSE Linux Enterprise Server that supports SysV, run the following commands:
insserv -r arcgisdatastore rm -f /etc/init.d/arcgisdatastore- If the operating system supports systemd, run these commands to remove links in
Now you can proceed with uninstalling ArcGIS Data Store from a machine.
Uninstall using a script
To uninstall ArcGIS Data Store using a script, run the uninstall_ArcGISDataStore script, as described below.
Sign in to the data store server with the account that installed ArcGIS Data Store.
Open a command shell and launch the
uninstall_ArcGISDataStorescript.This script is in the root of the ArcGIS Data Store installation directory.
The uninstallation interface opens.
Click Uninstall to proceed.
When the uninstallation process completes, click Done to exit.
Uninstall silently
To uninstall ArcGIS Data Store without being prompted for input (silently), use the following command line syntax:
<ArcGIS Data Store installation directory>/uninstall_ArcGISDataStore -s
You upgraded ArcGIS Data Store and want to remove the files for specific data store types that were never configured on a particular machine. You might do this if security practices at your organization require you to remove certain files.
Caution:
Before uninstalling ArcGIS Data Store, shut down all nonessential applications.
Use one of the following methods to uninstall ArcGIS Data Store from a machine:
Uninstall with the user interface
Complete the following steps to uninstall all data store types using the user interface:
On Microsoft Windows desktop, click Start > Control Panel (switch to Classic View, if necessary) and Programs and Features.
Select ArcGIS Data Store from the Programs list.
Select Remove to remove ArcGIS Data Store from this machine.
Uninstall ArcGIS Data Store silently
To completely uninstall ArcGIS Data Store from a machine without being prompted for input (silently), run the msiexec command with the /qb option, and use /x to specify the software code appropriate to the version of the software you are uninstalling.
To uninstall ArcGIS Data Store 12.1 silently, run the following command from the command line:
msiexec /x {0D10FFF3-8380-4E15-952E-DC031EB3940D} /qb
To uninstall ArcGIS Data Store 12.0 silently, run the following command from the command line:
msiexec /x {E62C9D19-53FE-45C2-B9C5-C86C7C703B8F} /qb
To uninstall ArcGIS Data Store 11.5 silently, run the following command from the command line:
msiexec /x {622B3833-6239-4857-96D5-4294D1E85F94} /qb
To uninstall ArcGIS Data Store 11.4 silently, run the following command from the command line:
msiexec /x {4AC2C588-DFDC-449E-8DFF-3701C3C3824A} /qb
To uninstall ArcGIS Data Store 11.3 silently, run the following command from the command line:
msiexec /x {E4FC0BED-0F94-49D4-9AF5-BBA64AED3787} /qb
To uninstall ArcGIS Data Store 11.2 silently, run the following command from the command line:
msiexec /x {A02634B0-03FD-4DF3-A5C6-BACBE5DF3979} /qb
To uninstall ArcGIS Data Store 11.1 silently, run the following command from the command line:
msiexec /x {391B3A39-0951-43E3-991D-82C82CA6E4A4} /qb
To uninstall ArcGIS Data Store 11.0 silently, run the following command from the command line:
msiexec /x {ABCEFF81-861D-482A-A20E-8542814C03BD} /qb
Uninstall specific types of data stores
You can remove data store types that you did not configure and do not need. For example, if you installed all data store types on a machine but only configured the relational store on that machine, you can uninstall all the other types.
To uninstall a data store type that you do not use, you can modify the ArcGIS Data Store installation using a wizard or by running the ArcGIS Data Store setup file from a Windows command prompt.
Do not uninstall a data store type that you configured with a hosting server.
Modify the ArcGIS Data Store installation using a wizard
To use the ArcGIS Data Store installation wizard to uninstall a data store type from an ArcGIS Data Store installation, you can use the Windows options to modify software installations—Apps & features or Programs and Features—to modify the ArcGIS Data Store installation.
In the ArcGIS Data Store installation wizard, choose Modify on the Program Maintenance dialog box and click Next.
On the Select Features dialog box, next to the data store type you want to uninstall, click the drop-down menu and click the remove button.
You can uninstall multiple types at once, but do not uninstall data store types that are configured with a hosting server.
Click Next.
Click Install on the Ready to Modify the Program dialog box to uninstall the data store or stores that you chose to remove from the installation.
If ArcGIS Data Store is installed on more than one machine, repeat these steps on the other ArcGIS Data Store machine or machines to remove the same data store type.
Run the setup file from a command prompt
You can run the setup file from a Windows command prompt to uninstall any data store types that you did not configure.
Run the command prompt as an administrator, change to the directory where the ArcGIS Data Store setup file resides on the machine, and run the Setup.exe file with the REMOVE option. The syntax is as follows:
Setup.exe /qb ACCEPTEULA=YES USER_NAME=<ArcGIS Data Store account username> PASSWORD=<ArcGIS Data Store account password> REMOVE={Relational | Spatiotemporal | TileCache | Object | Graph}
For example, type the following to remove the object and graph stores for an ArcGIS Data Store installation for which the ArcGIS Data Store account username and password are mydomain/myaccount and Mypassw0rd, respectively:
Setup.exe /qb ACCEPTEULA=YES USER_NAME=mydomain/myaccount PASSWORD=Mypassw0rd REMOVE=Object,Graph
If ArcGIS Data Store is installed on more than one machine, run the same command on the other ArcGIS Data Store machine or machines to remove the same data store type.
